UCD90320: IOUT_CAL_GAIN rounding
Part Number: UCD90320
We stumbled upon the same problem described in the post below. We tried setting the value to 2000, but it was rounded to 2030 by the TI Fusion tool.
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1008765/ucd90320-ti-fusion-digital-power-designer-tool---iout-cal-gain-parameter-issue
One thing we tried doing is manually entering the equivalent LINEAR11 value into the generated TIFSP, and re-importing that into Fusion, which doesn't complain.
Thus, my question is, is the rounding error simply a limitation of the Fusion tool? Is what we have done a valid way to store the value we want?
Adrianna
  • Hi, Adrianna,
    Device rounds iout cal gain to the closet value it supports. Try using SMBus/I2C/SAA debug tool to write the value to device, and then read back the value to see if read-back value is the same as written value.
    Anne Ngo
