TPS2493: Calculation sheet help
Part Number: TPS2493
Other Parts Discussed in Thread: TPS1663, TPS2663
I am having a hard time using the calculation tool at least for the Start up section. The SOA/Derated keeps coming back red.I dont need to use the external dv/dt control.TPS2493_Dynamixel.xlsx
  • Hello Dennis,
    SoA section coming red because of fault timer. Based on MOSFET SOA you have entered; fault timer is too high. Please select a higher SoA MOSFET.
    You can check TPS1663/TPS2663 which has integrated FET which can full fill your system requirement.
    Amrit
