BQ40Z50: bq40z50R5_tooltips CycleCnt jumps to 65535
Part Number: BQ40Z50
Other Parts Discussed in Thread: BQSTUDIO, , BQ78350-R1A, BQ78350
Hi Support,
Following on from our Golden File program, calibrate and functional test routine, we run a few condition cycles to ensure packs perform as expected.
The packs are cycled using a programmable power supply, electronic load and control PC that also logs data using bqstudio.
We are finding that during the condition cycling, the CycleCnt value on some packs unexpectedly jumps to 65535, as captured on line 1372 of the attached log file.
This appears to be an issue with related threads elsewhere in this forum, but it is unclear what the cause or resolution is.
Has there been further progress on resolving, or narrowing down the cause of this?
Although I only have a small dataset thus far, on first observation, it appears more likely to occur for batteries with higher error counts in the *.err log file.
Thank you,
Jeremy.
D00D_Cycle_1.log
