Good Morning,
I was using your reference design (attached below for reference) to design our system. Wanted to double check if the charging and discharging happens through the same pins (PACK+ and PACK-) ?
Good Morning,
Hello Mo,
That is correct. Your schematic looks fine as I see you are following the schematic shared in the datasheet. We also have this EVM User Guide you can use as reference as well.
Alexis
