TPSF12C1: CM choke model parameter
Part Number: TPSF12C1
Hi support team all.
The following post seems to provide a guide on how to input the equivalent circuit parameters of a CM choke coil into a tool, but if I know the model name of your CM choke coil, can you provide a guide?
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1436532/tpsf12c1-q1-tpsf12cx-mathcad-lcm1-nanocrystalline-parameters-definition?tisearch=e2e-sitesearch&keymatch=TPSF12C1%25E3%2580%2580LMAG2#
The model name is as follows:
https://www.chemi-con.co.jp/en/products/detail-inductor.php?part_number=LDFL039172VJUV0E
Could you please provide model parameters?
Higa
  • Hi Higa,
    As this is a nanocrystalline choke, you might refer to this article: www.how2power.com/newsletters/2403/articles/H2PToday2403_design_TexasInstruments_part3.pdf
    See also the collateral listed here, https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1257197/faq-tpsf12c1-and-tpsf12c3-power-supply-filter-ic-faqs, in particular the quickstart calculator that also helps with choke modeling.
    Tim
  • Hi Hegarty-san
    Thank you for your reply.
    I have checked the following document.
    Also, when generating an equivalent model in the calculation tool, it seems that the LR circuit is modeled three times, but the impedance characteristics of the CM choke coil used by my customer are as follows. It seems to me that three circuits are insufficient to model this. What do you think?
    In particular, it is unable to express a wide range above 1 MHz.
    Higa
  • Hi Higa,
    A 3-stage RL is adequate to model most chokes. I see two distinct slopes on the inductive impedance above, so you should be fine. The cap in parallel with the RL circuits in the model sets the high-frequency rolloff.
    You can use the quickstart calculator to help with choosing the modeling components.
    Tim
  • Hi Hegarty-san
    My customer is currently preparing to evaluate this product.
    However, he is unable to model the CM choke coil and is about to give up on the evaluation.
    Would you be able to support me in modeling it?
    I have actually tried using a tool, but I just can't get it to model at frequency bands above 1 MHz.
    Higa
  • Higa,
    You mean you can't model the choke impedance above 1MHz? Please send the quickstart calculator with the values you have so far. Note this is not super important, as the AEF only provides attenuation to ~3MHz.
    By the way, another option is to measure impedance amplitude and phase data over frequency for the choke and paste it into the quickstart file.
    Tim
  • HI Hegarty-san
    Thank you for your kind support.
    I attach quickstart calculator file.
    Higa1884.TPSF12Cx-Q1_quickstart_calculator_A9_PFC4kW.xlsm
  • Thank you, Higa. I'll take a look and reply asap.
  • Hello Hegarty-san
    Our customers are in little bit hurry.
    It would be very helpful if you could update the information.
    Higa
  • Hi Higa,
    My colleague, Naresh Adepu, will take a look at this, as he normally covers our AEF devices.
    Tim
  • 1884.TPSF12Cx-Q1_quickstart_calculator_A9_PFC4kW_solved.xlsm
    Hi Higa,
    Please find attached the excel sheet in the model that we are able to come up with for the customer's choke data.
    comparing the model and the choke data you provided - they closely match.
    could you please ask the customer to use this
    Thanks and Regards,
    Naresh
  • HI Naresh-san
    I have a question.
    In the document below, the formula for calculating Ri is as follows.
    From this formula, Ri ≠ Ri + 1.
    The result you presented was R2 = R3, so it doesn't fit the above formula, but is it possible that Ri = Ri + 1 in some cases?
    What are the conditions for this?
    It's very difficult to understand, so my customer doesn't seem to be able to figure it out.
    Also, after setting the optimal values ​​for the other parameters, is it correct to understand that
    INJ pin voltage swing at Fsw < VDD supply voltage?
    Higa
  • Hi Naresh-san
    Do you have any update?
    Higa
  • Hello Diasuke Higa
    I will get back on this
  • Hi Adepu-san
    This is a request from a customer. Could you please help us derive other optimal filter settings using the equivalent model of the CM choke coil you created?
    Since it has taken a considerable amount of time since we first contacted you about this, there is a possibility that we may lose this opportunity.
    We would appreciate your support.
    Higa
  • Hello Higa,
    When you mention about document, what document are you referring to? (In the document below, the formula for calculating Ri is as follows. )
    Is the customer planning to use the model for any simulation? could you check with him on which tool he uses?
    The model which is attached here is the closet to accurate that we could get at this moment. Could you please ask the customer to use this?
    Thanks and Regards
    Naresh
  • Hi Naresh,
    This is Conor, a colleague of Higa. Thank you for always following up on EMI filters!
    I downloaded the Excel file you attached and checked the contents. This is very helpful for introduction before the customer evaluates it. So I have a few questions about the Excel file.
    [Question 1]
    I think it is fine to leave LGRID and RGRID at 0 in Step 3. However, I entered LGRID = 1µH and RGRID = 50mΩ as realistic initial values, referring to the User’s Guide. Is it appropriate to modify only the above from the Excel items you sent me and run the macro to verify it? If there are any other items that need to be modified based on the customer’s specifications, please comment. As far as I can see from the Excel parameters, each parameter seems to be reasonable as an initial value.
    [Question 2]
    When I ran the macro based on the contents of Question 1, an error occurred in the INJ pin voltage amplitude. The INJ pin voltage amplitude is about 50Vpp, which is a significant error value for VDD = 12V. The INJ pin voltage amplitude should be kept at 7.5V (=12-4.5V). Possible solutions include lowering the CINJ, but do you have any advice?
    [Question 3]
    I will repeat what Higa asked.
    In the following document, equations (8) and (9) show a method of combining multiple RL parallel circuits in series when modeling nanocrystalline chokes. In this equation, Ri ≒ Ri+1, but in your answer, R2 = R3. Could you please comment the reason for this?
    A three-stage RL circuit is used to model the impedance characteristics of nanocrystalline chokes. ​The purpose of this model is to reproduce the decrease in inductance and the increase in loss components (resistance) in the high frequency band. ​Since changes in reactance have a significant effect on the phase characteristics, especially in the high frequency band, is it correct to think that the overall impedance characteristics are optimized by adjusting the inductance while keeping the resistance constant?
    Conor
  • Hi Naresh,
    I will also add a supplement to [Question 2]. If the INJ waveform is saturated, the following measures can be considered.
    • Increase the capacity of the Y capacitor (regulator side) to a value larger than the value currently used.
    • Improve saturation by lowering the gain of the AEF loop (increasing the RG resistor).
    See "Any tips for circuit optimization and debug?" in the FAQ URL.
    [FAQ] TPSF12C1 and TPSF12C3 power-supply filter IC FAQs
    Please comment if there are any other measures.
    Conor
  • Hi Conor,
    1. All the parameters mentioned in excel calculator are good initial values to start with. If you are aware of the GRID that you would use - then you can measure the effective impedance that the GRID offers, and you can use those values.
    2. If saturation of the INJ pin voltage is observed, increase the VDD supply voltage, the regulator-side CM choke and/or Y-capacitance, and/or the inject capacitance.
    3.  When we used the exact equation, Ri ≒ Ri+1, we saw that the model was not accurately matching the CM choke data that you provided. So, we would have to do few approximations and tweak and tune the values to get a better model. The equations are a good starting point, but you can do some tuning to improve the performance on top of it.
    Yes, the overall impedance characteristics are optimized by adjusting the inductance.
    Thanks and Regards,
    Naresh
