I've looked at the content that everyone discussed earlier, and it was mentioned that there are some parts of the Fault table in the Datasheet that need to be corrected.
When I conducted the experiment using the EVM board, the test item was overcurrent, and the load was provided by an E-LOAD. However, I found that the Vout value seems to not match the modified formula.
When overcurrent occurs, along with short to GND and thermal shutdown, the final fault behavior is the same. Does this mean it's impossible to distinguish which type of fault it is?
Thank you,
YuFang Chen
