Other Parts Discussed in Thread: BQ40Z50, EV2400, , BQPRODUCTION, BQ41Z90
I'm trying to calibrate a board I made with bq40z50 using Advanced BQMester and download Golden image.
Can I use the EV2400?
Hello HJ_KIM,
We don't support The ADVANCED-BQMTESTER tester as it is legacy now, however that being said it also appears that the "ADVANCED-BQMTESTER" doesn't support bq40z50 along with not being able to natively support the EV2300.
Thank you,
Alan
Hello.
We can produce BQ40Z50 board with BQPRODUCTION and EV2300. Also, we did actual work. Please check the attached PDF.
Currently, EV2300 seems to be discontinued, is that correct? Is there a way to get it?
And we are going to mass-produce BQ40Z50-R5 and BQ41Z90. Please check what programs and tools should be used to download FW, BQ parameter, and calibration data during mass-production.
Hello HJ_KIM,
We don't sell the EV2300 on TI, however I've attached the link Octopart that have site where you can purchase ev2300 at your own risk. Another thing to note is that the user is expected to come up a solution to program the gauge and I've attached this I've also attached a document for talking to the gauge as well.
Gauge Communication:
https://www.ti.com/lit/an/slua801/slua801.pdf?ts=1743800106067&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FBQ40Z50
Octopart:
https://octopart.com/search?q=EV2300¤cy=USD&specs=0
Thank you,
Alan
