The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
USB-PD-CHG-EVM-01: Screeching noise
Part Number: USB-PD-CHG-EVM-01
I am not sure why I hear a noise when I use this board to power downstream devices. I tried everything
-i thought its a grounding issue so removed all wires and now just power one board using barrel jack pig tails
-i have also removed the battery to eliminate any source of issue and just use USB C source (max 45W) and SYS output to ppwer my downstream. Everytime i power on i hear the screeching sound.
- when i power my load using its own power adapter that never happens.
Can someone please help. I do not know if I should proceed  with testing
  • Hi Aria,
    Can you attach your schematic or is this on the EVM?  What is your input voltage, battery voltage, charge current and load current?  Can you send a scope shot of the BQ2579x charger's VBUS, VSYS, SW1 and SW2 when this occurs, zoomed in to see at least 5 switching pulses?
    Jeff
