BQ40Z50-R2: SOH do not be at 100%, at initial setup and after full cycle
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: GPCRA0, BQSTUDIO
Since last message, this related post will be reported du to other post that brick the chip
We had agreed to wait until we had an operational platform again, which is now the case.
Initially, I couldn't set the SOH to 100% even though the configuration setup was clean, with an SOH of 90%.
I performed several cycles over long periods, but now the SOH has decreased instead of "auto-initializing" to 100% if there had been a learning process.
I don't understand how to set the SOH to 100% when the cells are new.
CM
  • Hello Cedric,
    This question has been assigned and please allow for time to process this question.
    Thank you,
    Alan
  • Hi Cedric,
    The SOH is reliant on the SOH FCC calculation, is it possible to share a short log file of right when the gauge is programmed so we can look at what this value is being calculated as?
    Also, please share the .gg file so we can look into the SOH parameters at this time as well.
    Anthony
    Thank you.
    Attached is the configuration file.
    Regarding the log, I didn't understand exactly what you were expecting? Isn't this the loading of the file?
    For the FCC, I had taken care to define it before programming:
    Design capacity: 8000mAh
    FCC Max: 8000mAh
    All the other parameters also seem consistent to me.
    I notice that FCC min (in lifetimes) is not initialized to 8000mAh, but 6891, a value likely derived from a calculation.
    I also tried to modify FCC Min directly (in lifetimes); I didn't get a refusal, so it was clearly allowed, and to read SOH immediately. Nothing changes, but I assume the refresh isn't immediate, and I don't know how to force it.
    The documentation gives some guidance on how SOH works, but it is unclear and did not help me.
    CMr5_250422.gg.csv
  • Hi Cedric,
    It seems like the gauge is underestimating the capacity since this is 90% upon initialization, based on this I do not think the FCC Max functionality would be applied since the FCC is not being calculated higher than the Design Capacity.
    You stated these cells are new, does the performance of this change if different cells are used? The SOH FCC still uses the resistance tables, so potentially the resistance of the cells could be less than what is being reflected in the resistance tables.
    Were the cells that were used to complete the learning cycle new as well?
    I believe we could use the GPCRA0 tool below to compare the resistance of the cells with what is in the resistance table at this time to see if this is causing an issue:
    https://www.ti.com/tool/GPCRA0
    Anthony
    Indeed, I had a feeling the same analysis would be true.
    That's why I was looking for what needed to be adjusted to set the starting point at 100%.
    From what I understand, this wouldn't be possible without having a precise custom battery model (i.e., creating a GG file specific to the cell). In other words, you can't have a "standard" chemistry (loaded into the chemistry library) and then adjust the capacity if the cell is larger. Is that correct?
    I don't have any other cells with this power; this is a specific project. I only have new cells.
    Some time ago, I looked into using the GPCRA0 tool, but quite frankly, it's incomprehensible, there's very little documentation, and apparently you need specific tools (Maccor/Arbin) and data exchange with Texas support. Is that correct?
    If, on the other hand, everything is possible with BQ Studio and an electronic load, then I can do it, but I would need more explanation about the implementation!
    Have you ever created a model yourself with the tool?
    Do you have detailed documentation explaining each step in detail?
    CM
    Today I try to do the procedure of GPC Maker (with bq studio)
    I discharge BMU pack from 88% to 0% on electronic load and I log U, I, T with bq studio.
    I make files like tutorial, but I can not make the zip file, BQ studio generate an error popup of mismatch rules.
    I do not understand the problem, all rules are respected.
    Could you try to find problem of attached files and finish the upload file ?
    CM
    ProcessingType=3
    ChemID=1189
    NumCellSeries=1
    ElapsedTimeColumn=0
    VoltageColumn=4
    CurrentColumn=8
    TemperatureColumn=12
    sysrate_rel_dis_rel.csv2063.gg.csv
  • Hi Cedric,
    If a learning cycle has been completed for the device to learn the capacity of the cell attached, then I believe there shouldn't be an issue reaching 100% SOH since the gauge has had the Qmax and resistance updated by the cycle. However, if the design capacity has been changed after the learning cycle has been completed, then this could be causing an issue. The Design Capacity should always reflect the nominal capacity of the cell attached, and shouldn't be changed.
    Thanks for confirming.
    Will do, I think there is an issue with the formatting of the .csv file, since this is how it looks when I open it:
    This information can be pulled from a standard bqStudio log file as well. If you share a bqStudio log of the testing, I can format it and input it to the tool from my side since you have given the other files already.
    Anthony
    All the parameters were set correctly initially. I even created a srec file to flash a new chip. Moreover, given last month's post (which we discussed together) where my chips were bricked due to leakage current in the temperature measurement, I had to replace the chips, so they were new.
    The settings, including DC and FCC, were therefore set correctly from the start; there have been no changes in the meantime.
    According to some notes in the docs, it appears that RA0 is not defined in all chemistries, and depending on the version, some parameters are missing (automatically replaced, an arbitrary fixed value?). I don't know if my chemistry is affected, but that could be a possible source of the problem; in any case, I'm not able to identify it.
    Regarding the CSV formatting, seeing your grid, I understand. When I open it with Excel, everything is normal!
    and notepad++ csv viewer
    In Europe
    - "comma separated" = ;
    - comma = ,
    in the US
    - "comma separated" = ,
    - comma = .
    So I replaced ; with , and , with .
    GPC Maker accepted the file, and I was able to generate the zip file. I uploaded it using the provided link, and I'm now waiting for the result.
    For your information, attached is the log file generated by bqstudio from which I created the csv file if that can help you.
    Data Log
    TimeStamp,Voltage,Current,Temperature,Cell 1 Voltage,Cell 2 Voltage,Cell 3 Voltage,Cell 4 Voltage,Cell 1 Current,Cell 2 Current,Cell 3 Current,Cell 4 Current,TS1 Temperature,TS2 Temperature,TS3 Temperature,TS4 Temperature
    2025-04-24 17:54:23.379,15798,0,24.4,3945,3947,3954,3951,0,0,0,0,24.4,24.0,24.0,24.4
    2025-04-24 17:54:28.386,15809,0,24.4,3948,3949,3957,3956,0,0,0,0,24.4,24.0,24.0,24.4
    2025-04-24 17:54:33.397,15671,-7598,24.4,3916,3921,3919,3914,-7612,-7598,-7591,-7585,24.4,24.0,24.0,24.4
    2025-04-24 17:54:38.663,15464,-14626,24.4,3867,3876,3864,3857,-14639,-14619,-14615,-14615,24.4,24.0,24.0,24.4
    2025-04-24 17:54:43.422,15421,-14638,24.4,3856,3865,3852,3847,-14654,-14644,-14632,-14629,24.4,24.0,24.0,24.4
    2025-04-24 17:54:48.437,15390,-14647,24.5,3849,3858,3845,3840,-14665,-14657,-14642,-14642,24.4,24.0,24.0,24.4
    2025-04-24 17:54:53.440,15367,-14664,24.4,3843,3852,3839,3834,-14677,-14671,-14653,-14662,24.4,24.0,24.0,24.4
    2025-04-24 17:54:58.693,15351,-14669,24.4,3839,3848,3834,3828,-14682,-14674,-14658,-14656,24.4,24.1,24.0,24.4
    2025-04-24 17:55:03.466,15336,-14676,24.4,3836,3845,3831,3826,-14688,-14685,-14667,-14669,24.4,24.0,24.0,24.4
    2025-04-24 17:55:08.476,15324,-14684,24.4,3833,3841,3828,3823,-14702,-14699,-14678,-14677,24.4,24.1,24.0,24.4
    2025-04-24 17:55:13.491,15313,-14703,24.4,3830,3838,3826,3821,-14717,-14718,-14693,-14694,24.4,24.1,24.1,24.4
    2025-04-24 17:55:18.723,15305,-14715,24.4,3828,3836,3823,3818,-14733,-14717,-14706,-14707,24.4,24.1,24.1,24.4
    2025-04-24 17:55:23.507,15294,-14728,24.4,3826,3833,3821,3814,-14743,-14735,-14716,-14721,24.4,24.1,24.2,24.5
    2025-04-24 17:55:28.519,15285,-14767,24.5,3823,3830,3818,3812,-14816,-14801,-14779,-14782,24.4,24.2,24.1,24.5
    2025-04-24 17:55:33.526,15274,-14881,24.5,3820,3827,3816,3809,-14887,-14894,-14865,-14879,24.4,24.2,24.2,24.5
    2025-04-24 17:55:38.771,15260,-15078,24.6,3817,3824,3813,3808,-15063,-15052,-15033,-15067,24.5,24.2,24.2,24.5
    2025-04-24 17:55:43.537,15253,-15067,24.5,3815,3822,3811,3804,-15075,-15046,-15085,-15079,24.5,24.2,24.2,24.6
    2025-04-24 17:55:48.551,15247,-15003,24.5,3814,3821,3810,3803,-14947,-14929,-14928,-14921,24.6,24.2,24.2,24.6
    2025-04-24 17:55:53.562,15241,-14896,24.6,3812,3819,3808,3802,-14914,-14891,-14893,-14890,24.6,24.2,24.2,24.6
    2025-04-24 17:55:58.789,15234,-14894,24.6,3810,3817,3806,3800,-14913,-14913,-14886,-14886,24.6,24.3,24.2,24.6
    2025-04-24 17:56:03.589,15226,-14904,24.7,3808,3815,3805,3799,-14916,-14897,-14892,-14892,24.7,24.2,24.2,24.6
    2025-04-24 17:56:08.603,15219,-14920,24.7,3806,3813,3803,3797,-14937,-14917,-14912,-14908,24.7,24.2,24.2,24.6
    2025-04-24 17:56:13.615,15212,-14903,24.7,3805,3811,3801,3795,-14913,-14891,-14889,-14886,24.7,24.3,24.2,24.7
    2025-04-24 17:56:18.823,15204,-14937,24.7,3803,3809,3800,3794,-14947,-14927,-14931,-14937,24.8,24.3,24.2,24.7
    2025-04-24 17:56:23.643,15196,-14967,24.8,3801,3806,3797,3791,-14997,-14969,-14962,-14966,24.8,24.3,24.2,24.7
    2025-04-24 17:56:28.655,15189,-14954,24.8,3799,3805,3796,3790,-14976,-14949,-14945,-14960,24.8,24.3,24.3,24.7
    2025-04-24 17:56:33.658,15181,-14965,24.9,3797,3803,3794,3788,-14981,-14962,-14953,-14963,24.9,24.3,24.3,24.8
    2025-04-24 17:56:38.835,15174,-14970,24.9,3795,3801,3792,3786,-14982,-14965,-14962,-14960,24.9,24.4,24.3,24.8
    2025-04-24 17:56:43.680,15167,-14964,25.0,3793,3799,3790,3784,-14979,-14962,-14950,-14950,25.0,24.4,24.4,24.8
    2025-04-24 17:56:48.687,15161,-14911,25.0,3792,3797,3789,3783,-14930,-14909,-14898,-14901,25.0,24.5,24.4,24.9
    2025-04-24 17:56:53.697,15154,-14918,25.1,3790,3795,3787,3781,-14927,-14916,-14900,-14904,25.1,24.6,24.4,25.0
    2025-04-24 17:56:58.898,15147,-14934,25.1,3788,3794,3786,3780,-14955,-14936,-14939,-14939,25.1,24.6,24.5,25.0
    2025-04-24 17:57:03.713,15139,-14934,25.2,3786,3792,3783,3778,-14955,-14934,-14924,-14928,25.2,24.6,24.6,25.1
    2025-04-24 17:57:08.728,15134,-14946,25.2,3785,3790,3782,3776,-14969,-14950,-14938,-14940,25.2,24.7,24.6,25.1
    2025-04-24 17:57:13.743,15127,-14911,25.2,3783,3788,3780,3775,-14913,-14896,-14884,-14880,25.2,24.7,24.7,25.1
    2025-04-24 17:57:18.913,15119,-14891,25.3,3781,3786,3778,3773,-14913,-14894,-14885,-14886,25.3,24.8,24.7,25.2
    2025-04-24 17:57:23.763,15114,-14872,25.3,3780,3785,3777,3771,-14894,-14876,-14865,-14872,25.3,24.8,24.8,25.2
    2025-04-24 17:57:28.778,15107,-14893,25.4,3778,3783,3775,3770,-14914,-14890,-14886,-14883,25.4,24.8,24.8,25.2
    2025-04-24 17:57:33.793,15101,-14901,25.5,3776,3781,3773,3768,-14921,-14899,-14895,-14893,25.5,24.9,24.8,25.3
    2025-04-24 17:57:38.929,15093,-14925,25.5,3775,3780,3772,3766,-14955,-14927,-14922,-14926,25.5,24.9,24.9,25.3
    2025-04-24 17:57:43.818,15086,-14943,25.5,3773,3777,3770,3764,-14941,-14926,-14913,-14918,25.5,25.0,24.9,25.4
    2025-04-24 17:57:48.826,15078,-14951,25.6,3771,3775,3768,3763,-14964,-14949,-14942,-14940,25.6,25.0,25.0,25.4
    2025-04-24 17:57:53.839,15074,-14882,25.6,3770,3774,3767,3763,-14900,-14879,-14868,-14866,25.7,25.0,25.0,25.5
    2025-04-24 17:57:58.960,15066,-14891,25.7,3768,3773,3765,3760,-14910,-14893,-14881,-14882,25.8,25.1,25.1,25.5
    2025-04-24 17:58:03.865,15058,-14909,25.8,3766,3770,3763,3759,-14927,-14903,-14899,-14901,25.8,25.1,25.1,25.5
    2025-04-24 17:58:08.867,15052,-14919,25.8,3765,3769,3761,3758,-14934,-14922,-14908,-14907,25.8,25.2,25.2,25.6
    2025-04-24 17:58:13.880,15045,-14920,25.9,3763,3767,3760,3756,-14936,-14925,-14910,-14915,25.9,25.2,25.2,25.6
    2025-04-24 17:58:18.994,15040,-14943,25.9,3762,3766,3758,3753,-14946,-14929,-14927,-14928,25.9,25.2,25.3,25.7
    2025-04-24 17:58:23.895,15032,-14916,25.9,3760,3764,3756,3753,-14935,-14928,-14912,-14912,26.0,25.3,25.3,25.8
    2025-04-24 17:58:28.897,15026,-14920,25.9,3758,3762,3755,3750,-14933,-14927,-14916,-14910,25.9,25.3,25.3,25.8
    2025-04-24 17:58:33.898,15018,-14959,25.9,3756,3761,3753,3748,-14974,-14967,-14950,-14953,26.0,25.3,25.4,25.9
    2025-04-24 17:58:39.022,15012,-14938,26.0,3755,3759,3751,3747,-14966,-14966,-14942,-14946,26.0,25.4,25.4,25.9
    2025-04-24 17:58:43.914,15006,-14928,26.0,3753,3758,3750,3746,-14935,-14941,-14920,-14923,26.0,25.4,25.5,26.0
    2025-04-24 17:58:48.926,14999,-14949,26.0,3752,3756,3748,3744,-14964,-14966,-14947,-14950,26.0,25.4,25.6,25.9
    2025-04-24 17:58:53.935,14993,-14941,26.1,3750,3754,3747,3742,-14960,-14953,-14935,-14938,26.1,25.5,25.6,26.0
    2025-04-24 17:58:59.029,14987,-14957,26.2,3749,3753,3745,3740,-14986,-14979,-14955,-14964,26.2,25.5,25.6,26.0
    2025-04-24 17:59:03.952,14981,-14941,26.2,3747,3751,3744,3739,-14956,-14931,-14926,-14926,26.2,25.6,25.7,26.1
    2025-04-24 17:59:08.956,14974,-14952,26.2,3746,3750,3742,3737,-14982,-14959,-14950,-14946,26.3,25.6,25.8,26.1
    2025-04-24 17:59:13.970,14968,-14978,26.3,3744,3748,3740,3736,-15003,-14973,-14962,-14956,26.3,25.7,25.8,26.2
    2025-04-24 17:59:19.059,14963,-14924,26.4,3743,3747,3739,3735,-14958,-14936,-14932,-14927,26.4,25.7,25.8,26.2
    2025-04-24 17:59:23.990,14956,-14958,26.4,3741,3745,3737,3733,-14978,-14958,-14950,-14943,26.4,25.8,25.9,26.3
    2025-04-24 17:59:28.997,14950,-15001,26.5,3739,3743,3736,3731,-14994,-14975,-14965,-14974,26.5,25.8,26.0,26.3
    2025-04-24 17:59:34.013,14945,-14947,26.5,3738,3742,3734,3730,-14966,-14952,-14945,-14946,26.5,25.8,25.9,26.4
    2025-04-24 17:59:39.107,14937,-15010,26.5,3736,3740,3732,3728,-15015,-15006,-14990,-14994,26.5,25.9,26.0,26.4
    2025-04-24 17:59:44.027,14933,-14951,26.6,3735,3739,3732,3727,-14956,-14954,-14939,-14938,26.6,25.9,26.0,26.4
    2025-04-24 17:59:49.033,14927,-15004,26.6,3734,3737,3729,3725,-15024,-15005,-14998,-15011,26.6,26.0,26.0,26.5
    2025-04-24 17:59:54.036,14920,-15019,26.7,3732,3736,3728,3724,-15050,-15029,-15021,-15019,26.7,25.9,26.1,26.5
    2025-04-24 17:59:59.138,14915,-15009,26.7,3732,3735,3727,3722,-15025,-15005,-15003,-15006,26.7,26.0,26.2,26.6
    2025-04-24 18:00:04.039,14909,-15023,26.7,3730,3733,3725,3721,-15013,-14996,-14995,-14992,26.7,26.0,26.3,26.6
    2025-04-24 18:00:09.052,14903,-15002,26.8,3728,3732,3724,3720,-15017,-14997,-14987,-14983,26.8,26.0,26.3,26.6
    2025-04-24 18:00:14.054,14897,-15047,26.8,3727,3730,3722,3718,-15054,-15038,-15034,-15023,26.8,26.1,26.3,26.7
    2025-04-24 18:00:19.229,14892,-15052,26.8,3725,3729,3721,3717,-15077,-15053,-15041,-15024,26.8,26.2,26.4,26.7
    2025-04-24 18:00:24.065,14886,-15034,26.9,3724,3728,3719,3715,-15045,-15021,-15034,-15031,26.9,26.2,26.4,26.7
    2025-04-24 18:00:29.079,14883,-14967,26.9,3723,3727,3718,3714,-14980,-14961,-14960,-14958,26.9,26.3,26.4,26.8
    2025-04-24 18:00:34.093,14877,-15009,27.0,3722,3725,3717,3713,-15012,-14984,-14983,-14981,27.0,26.3,26.5,26.8
    2025-04-24 18:00:39.273,14870,-15028,27.0,3720,3723,3715,3711,-15040,-15022,-15016,-14988,27.1,26.3,26.6,26.9
    2025-04-24 18:00:44.111,14867,-14979,27.1,3719,3722,3714,3710,-15001,-14980,-14979,-14980,27.1,26.4,26.6,26.9
    2025-04-24 18:00:49.111,14860,-15025,27.1,3717,3721,3712,3709,-15022,-15003,-15012,-15020,27.1,26.4,26.6,26.9
    2025-04-24 18:00:54.123,14856,-15007,27.1,3716,3720,3711,3708,-15010,-14996,-14987,-14986,27.1,26.5,26.6,26.9
    2025-04-24 18:00:59.288,14851,-14977,27.2,3715,3719,3710,3707,-14998,-14971,-14970,-14975,27.1,26.5,26.7,27.0
    2025-04-24 18:01:04.140,14845,-15018,27.2,3714,3717,3709,3705,-15045,-15019,-15003,-15000,27.2,26.5,26.7,27.0
    2025-04-24 18:01:09.153,14840,-15020,27.2,3713,3716,3707,3704,-15034,-15024,-15012,-15010,27.2,26.6,26.8,27.1
    2025-04-24 18:01:14.164,14836,-14967,27.3,3711,3715,3706,3703,-14976,-14971,-14948,-14956,27.3,26.6,26.8,27.1
    2025-04-24 18:01:19.319,14831,-14961,27.3,3710,3714,3705,3702,-14974,-14957,-14956,-14958,27.2,26.6,26.8,27.2
    2025-04-24 18:01:24.175,14825,-14988,27.3,3709,3712,3704,3702,-14997,-14991,-14970,-14968,27.3,26.7,26.9,27.2
    2025-04-24 18:01:29.185,14819,-15027,27.3,3708,3711,3702,3699,-15065,-15050,-15009,-15009,27.3,26.7,26.9,27.3
    2025-04-24 18:01:34.197,14816,-14954,27.4,3707,3710,3701,3698,-14986,-14975,-14961,-14958,27.4,26.8,27.0,27.4
    2025-04-24 18:01:39.335,14812,-15007,27.4,3706,3709,3700,3697,-15013,-14996,-14986,-14979,27.4,26.8,27.0,27.4
    2025-04-24 18:01:44.222,14806,-14988,27.4,3704,3707,3698,3696,-15004,-14999,-14982,-14975,27.5,26.8,27.1,27.4
    2025-04-24 18:01:49.238,14800,-15014,27.5,3703,3706,3697,3695,-15046,-15034,-15013,-15013,27.5,26.8,27.1,27.4
    2025-04-24 18:01:54.250,14796,-15000,27.5,3702,3705,3696,3694,-15017,-15011,-14985,-14990,27.5,26.9,27.1,27.5
    2025-04-24 18:01:59.368,14791,-15027,27.5,3701,3704,3695,3693,-15041,-15040,-15015,-15019,27.5,26.9,27.2,27.6
    2025-04-24 18:02:04.268,14786,-15023,27.6,3699,3703,3693,3692,-15022,-15018,-15011,-15021,27.6,27.0,27.2,27.6
    2025-04-24 18:02:09.268,14782,-15005,27.6,3698,3701,3692,3689,-15012,-15011,-14993,-14994,27.7,27.0,27.3,27.6
    2025-04-24 18:02:14.278,14777,-15003,27.7,3697,3700,3691,3688,-15024,-15017,-14992,-14996,27.6,27.0,27.4,27.7
    2025-04-24 18:02:19.382,14771,-15050,27.6,3696,3699,3690,3688,-15062,-15067,-15041,-15045,27.6,27.1,27.4,27.6
    2025-04-24 18:02:24.300,14768,-15011,27.8,3695,3698,3689,3686,-15030,-15050,-15021,-15028,27.7,27.1,27.4,27.8
    2025-04-24 18:02:29.315,14763,-15029,27.9,3694,3697,3688,3685,-15012,-15000,-14992,-14994,27.7,27.1,27.5,27.9
    2025-04-24 18:02:34.329,14759,-15002,27.9,3693,3696,3687,3684,-15018,-15003,-14991,-14996,27.8,27.2,27.5,27.9
    2025-04-24 18:02:39.396,14754,-15070,27.9,3692,3695,3685,3683,-15060,-15036,-15063,-15077,27.8,27.2,27.6,27.9
    2025-04-24 18:02:44.356,14750,-15056,27.9,3691,3693,3684,3681,-15094,-15064,-15054,-15084,27.9,27.3,27.6,27.9
    2025-04-24 18:02:49.366,14745,-15062,28.0,3689,3692,3683,3680,-15170,-15142,-15092,-15160,27.9,27.4,27.7,27.9
    2025-04-24 18:02:54.378,14740,-15127,27.9,3688,3691,3681,3679,-15165,-15130,-15152,-15149,27.9,27.4,27.6,27.9
    2025-04-24 18:02:59.445,14737,-15036,28.0,3688,3690,3681,3679,-15061,-15051,-15036,-15028,28.0,27.4,27.7,28.0
    2025-04-24 18:03:04.403,14732,-15051,28.1,3686,3689,3680,3677,-15093,-15061,-15047,-15045,28.0,27.5,27.8,28.1
    2025-04-24 18:03:09.413,14728,-15106,28.1,3686,3688,3679,3676,-15101,-15087,-15062,-15047,28.1,27.5,27.8,28.1
    2025-04-24 18:03:14.423,14724,-15109,28.2,3684,3687,3677,3675,-15126,-15096,-15076,-15083,28.2,27.6,27.9,28.1
    2025-04-24 18:03:19.462,14720,-15119,28.2,3684,3686,3676,3674,-15110,-15097,-15090,-15084,28.2,27.6,27.9,28.2
    2025-04-24 18:03:24.446,14715,-15104,28.2,3683,3685,3675,3673,-15081,-15049,-15119,-15108,28.2,27.6,28.0,28.2
    2025-04-24 18:03:29.458,14712,-15054,28.3,3682,3684,3674,3672,-15077,-15042,-15038,-15037,28.3,27.7,28.0,28.3
    2025-04-24 18:03:34.473,14708,-15053,28.3,3681,3683,3673,3671,-15064,-15051,-15034,-15041,28.3,27.6,28.0,28.3
    2025-04-24 18:03:39.483,14704,-15087,28.4,3680,3682,3672,3670,-15129,-15092,-15077,-15144,28.2,27.7,28.1,28.3
    2025-04-24 18:03:44.496,14701,-15025,28.3,3679,3681,3671,3669,-15040,-15018,-15015,-15009,28.3,27.8,28.1,28.3
    2025-04-24 18:03:49.509,14698,-15038,28.3,3678,3681,3670,3668,-15019,-15008,-15005,-15009,28.3,27.8,28.2,28.3
    2025-04-24 18:03:54.510,14695,-15004,28.4,3678,3680,3669,3668,-15019,-15005,-15000,-14994,28.3,27.9,28.2,28.4
    2025-04-24 18:03:59.520,14690,-15071,28.4,3677,3679,3669,3666,-15091,-15085,-15083,-15079,28.3,27.9,28.3,28.4
    2025-04-24 18:04:04.522,14686,-15048,28.4,3676,3677,3668,3665,-15080,-15059,-15060,-15056,28.4,27.9,28.3,28.4
    2025-04-24 18:04:09.535,14683,-15046,28.5,3675,3676,3667,3665,-15070,-15056,-15044,-15046,28.5,28.0,28.3,28.4
    2025-04-24 18:04:14.543,14680,-15025,28.5,3674,3676,3666,3664,-15047,-15030,-15017,-15033,28.5,28.0,28.4,28.5
    2025-04-24 18:04:19.557,14678,-15022,28.6,3674,3676,3665,3663,-15031,-15029,-15012,-15012,28.5,28.1,28.5,28.6
    2025-04-24 18:04:24.569,14673,-15056,28.6,3672,3674,3664,3662,-15078,-15066,-15055,-15052,28.6,28.1,28.5,28.6
    2025-04-24 18:04:29.572,14671,-15022,28.6,3672,3673,3663,3662,-15035,-15019,-15009,-15020,28.6,28.1,28.5,28.6
    2025-04-24 18:04:34.583,14667,-15002,28.6,3671,3673,3662,3661,-15014,-15001,-14995,-14993,28.6,28.2,28.6,28.6
    2025-04-24 18:04:39.598,14664,-15031,28.7,3670,3672,3661,3660,-15056,-15032,-15029,-15027,28.7,28.2,28.6,28.6
    2025-04-24 18:04:44.608,14661,-15040,28.7,3669,3671,3660,3659,-15056,-15037,-15036,-15028,28.7,28.3,28.6,28.6
    2025-04-24 18:04:49.615,14658,-15014,28.7,3669,3670,3660,3658,-15035,-15017,-15010,-15011,28.7,28.3,28.7,28.6
    2025-04-24 18:04:54.620,14654,-15046,28.7,3668,3669,3659,3657,-15064,-15058,-15046,-15044,28.8,28.3,28.7,28.7
    2025-04-24 18:04:59.626,14652,-15002,28.8,3668,3669,3658,3657,-15020,-15001,-14993,-14991,28.8,28.4,28.7,28.7
    2025-04-24 18:05:04.633,14648,-15049,28.8,3667,3668,3657,3657,-15069,-15060,-15044,-15048,28.8,28.5,28.8,28.8
    2025-04-24 18:05:09.647,14645,-15033,28.9,3666,3667,3656,3655,-15038,-15029,-15019,-15021,28.8,28.5,28.9,28.8
    2025-04-24 18:05:14.655,14642,-15045,29.0,3665,3667,3655,3655,-15069,-15068,-15045,-15045,28.9,28.5,28.9,29.0
    2025-04-24 18:05:19.669,14638,-15063,29.0,3665,3666,3655,3655,-15086,-15084,-15059,-15067,29.0,28.6,29.0,29.0
    2025-04-24 18:05:24.678,14636,-15026,29.0,3664,3665,3654,3654,-15054,-15049,-15028,-15032,29.0,28.6,29.0,28.9
    2025-04-24 18:05:29.681,14633,-15070,29.1,3663,3665,3653,3653,-15094,-15086,-15067,-15063,28.9,28.6,29.1,28.9
    2025-04-24 18:05:34.687,14631,-15004,29.1,3663,3664,3652,3652,-15020,-15009,-14997,-14991,29.1,28.7,29.1,29.0
    2025-04-24 18:05:39.700,14628,-15031,29.1,3662,3663,3652,3652,-15039,-15034,-15021,-15024,29.1,28.7,29.2,29.1
    2025-04-24 18:05:44.704,14625,-15046,29.2,3662,3663,3651,3651,-15070,-15070,-15049,-15042,29.2,28.8,29.2,29.1
    2025-04-24 18:05:49.706,14623,-15030,29.2,3661,3662,3650,3650,-15045,-15040,-15019,-15017,29.2,28.9,29.3,29.2
    2025-04-24 18:05:54.709,14620,-15075,29.3,3661,3662,3649,3649,-15073,-15080,-15054,-15049,29.3,29.0,29.3,29.4
    2025-04-24 18:05:59.715,14619,-15057,29.3,3660,3661,3649,3648,-15076,-15048,-15045,-15045,29.3,29.0,29.3,29.3
    2025-04-24 18:06:04.722,14617,-15027,29.4,3660,3661,3648,3648,-15043,-15019,-15014,-15019,29.3,29.0,29.4,29.3
    2025-04-24 18:06:09.736,14614,-15095,29.4,3659,3660,3648,3647,-15089,-15062,-15061,-15055,29.4,29.1,29.4,29.3
    2025-04-24 18:06:14.737,14611,-15125,29.5,3658,3659,3647,3646,-15111,-15094,-15110,-15096,29.4,29.1,29.5,29.3
    2025-04-24 18:06:19.784,14610,-15067,29.5,3658,3659,3647,3646,-15089,-15072,-15068,-15061,29.5,29.2,29.5,29.4
    2025-04-24 18:06:24.753,14607,-15111,29.6,3657,3658,3646,3645,-15152,-15130,-15124,-15135,29.6,29.2,29.6,29.4
    2025-04-24 18:06:29.765,14606,-15078,29.6,3657,3658,3646,3645,-15058,-15036,-15035,-15026,29.6,29.3,29.6,29.5
    2025-04-24 18:06:34.775,14605,-15019,29.7,3657,3657,3645,3645,-15040,-15015,-15011,-15019,29.6,29.3,29.7,29.6
    2025-04-24 18:06:39.787,14603,-15060,29.7,3657,3657,3645,3645,-15071,-15047,-15044,-15042,29.6,29.4,29.7,29.7
    2025-04-24 18:06:44.795,14601,-15037,29.7,3656,3656,3644,3644,-15066,-15035,-15039,-15036,29.6,29.4,29.8,29.5
    2025-04-24 18:06:49.796,14598,-15101,29.8,3655,3655,3643,3643,-15111,-15099,-15079,-15084,29.6,29.4,29.8,29.6
    2025-04-24 18:06:54.800,14598,-15001,29.9,3655,3655,3643,3644,-15014,-14993,-14978,-14983,29.7,29.5,29.9,29.6
    2025-04-24 18:06:59.809,14597,-14987,29.9,3656,3655,3643,3643,-15006,-14983,-14979,-14977,29.7,29.6,29.9,29.7
    2025-04-24 18:07:04.809,14595,-14991,29.9,3655,3654,3643,3643,-15008,-14987,-14984,-14983,29.9,29.6,30.0,29.7
    2025-04-24 18:07:09.823,14593,-14995,30.1,3654,3654,3642,3642,-15007,-14986,-14984,-14985,29.9,29.7,30.1,29.8
    2025-04-24 18:07:14.836,14591,-15007,30.1,3654,3653,3642,3642,-15014,-14999,-14994,-14997,30.0,29.7,30.2,29.8
    2025-04-24 18:07:19.850,14590,-15043,30.2,3653,3653,3641,3642,-15054,-15048,-15032,-15032,30.1,29.8,30.2,29.8
    2025-04-24 18:07:24.861,14587,-15056,30.2,3653,3652,3640,3641,-15070,-15049,-15041,-15054,30.1,29.8,30.3,29.8
    2025-04-24 18:07:29.877,14584,-15029,30.2,3652,3651,3640,3640,-15057,-15041,-15033,-15031,30.2,29.9,30.2,29.8
    2025-04-24 18:07:34.892,14582,-15070,30.3,3652,3651,3640,3640,-15079,-15059,-15054,-15064,30.2,29.9,30.3,29.8
    2025-04-24 18:07:39.903,14582,-15035,30.3,3652,3650,3640,3640,-15030,-15016,-15013,-15014,30.2,29.9,30.3,29.9
    2025-04-24 18:07:44.918,14579,-15053,30.4,3651,3650,3639,3639,-15076,-15058,-15056,-15056,30.2,30.1,30.4,29.9
    2025-04-24 18:07:49.930,14577,-15060,30.5,3650,3649,3638,3639,-15085,-15069,-15066,-15065,30.3,30.1,30.5,29.9
    2025-04-24 18:07:54.942,14575,-15025,30.5,3650,3649,3638,3639,-15041,-15023,-15020,-15021,30.4,30.2,30.6,30.0
    2025-04-24 18:07:59.957,14573,-15078,30.6,3649,3648,3638,3638,-15080,-15063,-15053,-15055,30.4,30.2,30.6,30.2
    2025-04-24 18:08:04.971,14571,-15087,30.6,3649,3647,3636,3638,-15070,-15059,-15051,-15057,30.6,30.2,30.7,30.2
    2025-04-24 18:08:09.971,14569,-15073,30.7,3648,3647,3636,3637,-15098,-15088,-15087,-15088,30.6,30.3,30.7,30.2
    2025-04-24 18:08:14.984,14568,-15058,30.8,3648,3646,3636,3637,-15074,-15058,-15050,-15054,30.7,30.3,30.8,30.2
    2025-04-24 18:08:19.994,14566,-15024,30.8,3648,3645,3636,3637,-15034,-15017,-15011,-15010,30.6,30.4,30.8,30.2
    2025-04-24 18:08:25.008,14565,-15002,30.9,3647,3645,3635,3637,-15017,-15002,-15000,-14999,30.7,30.5,30.9,30.2
    2025-04-24 18:08:30.019,14562,-15048,30.9,3647,3644,3635,3636,-15067,-15042,-15043,-15036,30.6,30.6,30.9,30.3
    2025-04-24 18:08:35.034,14560,-15043,31.0,3646,3643,3634,3636,-15064,-15041,-15034,-15031,30.7,30.6,31.0,30.4
    2025-04-24 18:08:40.045,14558,-15045,31.0,3646,3643,3634,3635,-15062,-15045,-15033,-15036,30.8,30.7,31.1,30.4
    2025-04-24 18:08:45.053,14556,-15012,31.1,3645,3642,3633,3635,-15020,-15009,-14995,-14999,30.9,30.7,31.1,30.5
    2025-04-24 18:08:50.064,14554,-15003,31.2,3645,3641,3633,3635,-15016,-14998,-14985,-14992,30.9,30.8,31.2,30.4
    2025-04-24 18:08:55.074,14552,-14996,31.2,3644,3640,3633,3635,-15011,-14998,-14983,-14989,30.8,30.8,31.2,30.4
    2025-04-24 18:09:00.082,14550,-15006,31.3,3644,3640,3632,3634,-15026,-15014,-14996,-15000,30.8,30.9,31.3,30.5
    2025-04-24 18:09:05.086,14547,-15013,31.3,3643,3639,3631,3634,-15051,-15035,-15016,-15019,30.9,31.0,31.4,30.6
    2025-04-24 18:09:10.095,14544,-15046,31.4,3642,3638,3631,3633,-15064,-15066,-15048,-15044,31.1,31.0,31.4,30.6
    2025-04-24 18:09:15.111,14542,-15050,31.4,3642,3637,3630,3633,-15064,-15059,-15033,-15038,31.1,31.1,31.5,30.6
    2025-04-24 18:09:20.124,14540,-15045,31.5,3641,3636,3630,3632,-15063,-15058,-15035,-15033,31.2,31.1,31.5,30.7
    2025-04-24 18:09:25.135,14537,-15051,31.6,3641,3636,3629,3632,-15070,-15059,-15042,-15039,31.3,31.2,31.6,30.8
    2025-04-24 18:09:30.144,14535,-15017,31.7,3640,3635,3628,3632,-15026,-15011,-15003,-15000,31.3,31.2,31.7,30.9
    2025-04-24 18:09:35.157,14533,-15001,31.7,3640,3634,3628,3631,-15014,-15004,-14985,-14990,31.3,31.3,31.7,30.9
    2025-04-24 18:09:40.165,14530,-14998,31.8,3639,3633,3628,3631,-15012,-15005,-14988,-14985,31.3,31.4,31.8,31.0
    2025-04-24 18:09:45.173,14528,-15008,31.9,3638,3632,3627,3630,-15024,-15015,-15001,-15002,31.3,31.4,31.9,31.1
    2025-04-24 18:09:50.174,14524,-15046,31.9,3638,3631,3626,3630,-15060,-15049,-15034,-15035,31.5,31.5,31.9,31.2
    2025-04-24 18:09:55.184,14521,-15069,31.9,3637,3630,3626,3629,-15087,-15077,-15058,-15064,31.5,31.5,32.0,31.2
    2025-04-24 18:10:00.193,14519,-15042,32.0,3636,3629,3625,3628,-15052,-15043,-15026,-15029,31.5,31.7,32.0,31.3
    2025-04-24 18:10:05.206,14516,-15020,32.1,3636,3628,3625,3628,-15030,-15033,-15015,-15017,31.6,31.7,32.1,31.3
    2025-04-24 18:10:10.214,14513,-15082,32.2,3635,3627,3624,3627,-15096,-15089,-15071,-15077,31.6,31.8,32.2,31.3
    2025-04-24 18:10:15.218,14509,-15086,32.2,3634,3626,3623,3627,-15097,-15095,-15075,-15071,31.7,31.8,32.2,31.4
    2025-04-24 18:10:20.221,14507,-15049,32.3,3633,3625,3622,3626,-15055,-15043,-15033,-15030,31.8,31.9,32.3,31.6
    2025-04-24 18:10:25.234,14503,-15040,32.3,3632,3624,3622,3626,-15050,-15038,-15029,-15031,31.9,32.0,32.3,31.7
    2025-04-24 18:10:30.247,14499,-15131,32.4,3631,3623,3621,3625,-15137,-15113,-15116,-15124,31.9,31.9,32.4,31.7
    2025-04-24 18:10:35.255,14494,-15194,32.5,3630,3621,3619,3624,-15228,-15209,-15207,-15208,31.9,32.1,32.4,31.8
    2025-04-24 18:10:40.269,14492,-15170,32.5,3629,3620,3619,3623,-15210,-15174,-15179,-15183,31.9,32.1,32.5,31.8
    2025-04-24 18:10:45.280,14491,-15136,32.6,3629,3619,3618,3623,-15141,-15123,-15128,-15125,32.0,32.2,32.6,31.8
    2025-04-24 18:10:50.292,14484,-15169,32.6,3628,3617,3617,3622,-15162,-15146,-15142,-15147,32.1,32.3,32.6,31.9
    2025-04-24 18:10:55.297,14480,-15208,32.7,3627,3616,3616,3621,-15216,-15196,-15193,-15187,32.1,32.3,32.7,31.9
    2025-04-24 18:11:00.301,14477,-15181,32.8,3626,3615,3616,3620,-15205,-15185,-15177,-15172,32.2,32.4,32.8,31.9
    2025-04-24 18:11:05.309,14473,-15170,32.8,3625,3613,3615,3620,-15187,-15168,-15161,-15156,32.3,32.4,32.8,31.9
    2025-04-24 18:11:10.317,14468,-15224,32.9,3623,3612,3614,3619,-15242,-15220,-15211,-15226,32.3,32.5,32.9,31.9
    2025-04-24 18:11:15.323,14463,-15278,32.9,3622,3610,3613,3618,-15285,-15273,-15269,-15264,32.4,32.6,32.9,31.9
    2025-04-24 18:11:20.330,14459,-15292,33.0,3621,3609,3612,3617,-15318,-15297,-15290,-15256,32.4,32.6,33.0,31.9
    2025-04-24 18:11:25.331,14455,-15267,33.1,3620,3607,3611,3616,-15328,-15302,-15301,-15289,32.4,32.7,33.1,31.9
    2025-04-24 18:11:30.345,14450,-15322,33.2,3619,3606,3610,3616,-15309,-15283,-15258,-15308,32.5,32.8,33.2,31.9
    2025-04-24 18:11:35.348,14446,-15272,33.2,3618,3605,3609,3615,-15287,-15259,-15261,-15293,32.6,32.8,33.2,32.1
    2025-04-24 18:11:40.359,14443,-15284,33.3,3617,3603,3608,3614,-15308,-15289,-15290,-15299,32.7,32.9,33.3,32.2
    2025-04-24 18:11:45.370,14438,-15253,33.4,3616,3602,3608,3613,-15264,-15242,-15230,-15227,32.8,32.9,33.3,32.2
    2025-04-24 18:11:50.379,14433,-15278,33.4,3614,3600,3606,3612,-15308,-15288,-15288,-15289,32.7,33.0,33.4,32.3
    2025-04-24 18:11:55.380,14429,-15244,33.5,3613,3599,3605,3611,-15290,-15260,-15251,-15249,32.7,33.1,33.5,32.3
    2025-04-24 18:12:00.380,14425,-15279,33.5,3612,3597,3604,3611,-15303,-15281,-15274,-15270,32.8,33.2,33.6,32.3
    2025-04-24 18:12:05.395,14420,-15267,33.6,3611,3596,3603,3610,-15295,-15286,-15268,-15261,32.8,33.2,33.6,32.3
    2025-04-24 18:12:10.405,14415,-15282,33.7,3609,3594,3602,3609,-15300,-15291,-15279,-15277,32.8,33.3,33.7,32.3
    2025-04-24 18:12:15.411,14410,-15285,33.7,3608,3592,3601,3608,-15313,-15292,-15289,-15280,32.8,33.3,33.8,32.4
    2025-04-24 18:12:20.415,14406,-15272,33.8,3607,3591,3600,3607,-15308,-15307,-15292,-15286,33.0,33.4,33.8,32.4
    2025-04-24 18:12:25.425,14400,-15286,33.8,3605,3589,3599,3606,-15313,-15300,-15285,-15286,33.2,33.4,33.9,32.4
    2025-04-24 18:12:30.426,14395,-15275,33.9,3604,3588,3598,3605,-15256,-15234,-15228,-15238,33.3,33.5,33.9,32.4
    2025-04-24 18:12:35.438,14390,-15278,34.0,3602,3586,3597,3604,-15311,-15290,-15278,-15289,33.3,33.6,34.0,32.5
    2025-04-24 18:12:40.453,14384,-15301,34.0,3601,3584,3596,3603,-15274,-15261,-15258,-15262,33.4,33.6,34.0,32.5
    2025-04-24 18:12:45.467,14377,-15285,34.1,3599,3582,3594,3602,-15327,-15317,-15309,-15311,33.5,33.7,34.1,32.5
    2025-04-24 18:12:50.475,14372,-15306,34.1,3598,3580,3593,3600,-15332,-15317,-15306,-15304,33.5,33.8,34.2,32.6
    2025-04-24 18:12:55.488,14366,-15307,34.2,3596,3578,3592,3599,-15332,-15313,-15304,-15296,33.5,33.8,34.3,32.7
    2025-04-24 18:13:00.501,14359,-15298,34.3,3595,3576,3590,3599,-15331,-15317,-15315,-15318,33.6,33.9,34.4,32.9
    2025-04-24 18:13:05.511,14353,-15306,34.4,3593,3574,3589,3597,-15322,-15309,-15297,-15293,33.6,33.9,34.4,33.0
    2025-04-24 18:13:10.522,14347,-15261,34.4,3591,3572,3588,3596,-15276,-15280,-15262,-15252,33.7,34.0,34.5,33.2
    2025-04-24 18:13:15.525,14340,-15292,34.5,3590,3569,3587,3595,-15258,-15252,-15243,-15239,33.8,34.0,34.5,33.3
    2025-04-24 18:13:20.538,14332,-15295,34.5,3588,3566,3585,3593,-15318,-15311,-15285,-15288,33.9,34.1,34.5,33.3
    2025-04-24 18:13:25.551,14324,-15284,34.6,3586,3563,3583,3592,-15334,-15327,-15305,-15309,33.9,34.1,34.7,33.3
    2025-04-24 18:13:30.565,14316,-15282,34.7,3584,3561,3581,3591,-15298,-15295,-15293,-15288,33.9,34.2,34.7,33.3
    2025-04-24 18:13:35.578,14308,-15304,34.8,3582,3557,3580,3589,-15315,-15317,-15291,-15311,34.0,34.3,34.7,33.3
    2025-04-24 18:13:40.585,14298,-15311,34.8,3580,3554,3578,3587,-15342,-15326,-15299,-15275,34.0,34.4,34.8,33.3
    2025-04-24 18:13:45.596,14289,-15304,34.9,3578,3550,3576,3585,-15279,-15278,-15267,-15302,34.1,34.4,34.9,33.3
    2025-04-24 18:13:50.598,14278,-15333,34.9,3575,3546,3574,3583,-15342,-15330,-15295,-15289,34.1,34.5,34.9,33.4
    2025-04-24 18:13:55.611,14268,-15317,35.0,3573,3542,3572,3582,-15330,-15352,-15335,-15343,34.1,34.5,35.0,33.4
    2025-04-24 18:14:00.611,14256,-15334,35.0,3570,3537,3569,3580,-15371,-15371,-15343,-15328,34.2,34.5,35.1,33.4
    2025-04-24 18:14:05.622,14244,-15323,35.1,3567,3533,3567,3578,-15343,-15337,-15317,-15320,34.2,34.6,35.1,33.6
    2025-04-24 18:14:10.630,14232,-15311,35.2,3564,3528,3564,3575,-15347,-15334,-15303,-15298,34.3,34.7,35.2,33.7
    2025-04-24 18:14:15.643,14218,-15368,35.2,3561,3522,3561,3573,-15384,-15388,-15349,-15347,34.4,34.8,35.3,33.8
    2025-04-24 18:14:20.656,14205,-15355,35.3,3558,3516,3559,3570,-15397,-15370,-15345,-15339,34.3,34.8,35.4,33.9
    2025-04-24 18:14:25.657,14188,-15361,35.4,3554,3509,3555,3568,-15404,-15398,-15380,-15356,34.4,34.9,35.4,33.8
    2025-04-24 18:14:30.668,14172,-15302,35.4,3551,3503,3552,3565,-15332,-15310,-15270,-15256,34.5,34.9,35.4,33.9
    2025-04-24 18:14:35.681,14156,-15243,35.5,3547,3496,3549,3563,-15248,-15238,-15226,-15226,34.5,35.0,35.5,33.9
    2025-04-24 18:14:40.689,14138,-15219,35.5,3543,3488,3546,3560,-15197,-15169,-15165,-15166,34.5,35.0,35.6,33.9
    2025-04-24 18:14:45.703,14118,-15244,35.6,3539,3480,3542,3557,-15264,-15240,-15235,-15236,34.5,35.1,35.6,33.8
    2025-04-24 18:14:50.718,14097,-15239,35.7,3534,3471,3538,3554,-15258,-15236,-15232,-15217,34.5,35.1,35.7,33.9
    2025-04-24 18:14:55.731,14075,-15241,35.7,3529,3462,3533,3550,-15256,-15238,-15231,-15235,34.5,35.2,35.8,34.0
    2025-04-24 18:15:00.741,14052,-15241,35.8,3524,3452,3529,3546,-15259,-15237,-15233,-15237,34.5,35.2,35.8,34.0
    2025-04-24 18:15:05.750,14027,-15238,35.9,3519,3441,3525,3542,-15257,-15231,-15227,-15224,34.7,35.3,35.9,34.0
    2025-04-24 18:15:10.765,14001,-15236,35.9,3513,3429,3520,3538,-15256,-15233,-15223,-15225,34.7,35.4,36.0,34.1
    2025-04-24 18:15:15.767,13974,-15236,36.0,3507,3418,3514,3534,-15246,-15230,-15222,-15228,34.5,35.4,36.0,34.3
    2025-04-24 18:15:20.778,13946,-15229,36.0,3501,3405,3509,3530,-15236,-15216,-15214,-15216,34.7,35.5,36.1,34.2
    2025-04-24 18:15:25.780,13917,-15246,36.1,3495,3392,3503,3525,-15263,-15242,-15231,-15239,34.7,35.5,36.1,34.2
    2025-04-24 18:15:30.788,13885,-15236,36.1,3489,3378,3497,3520,-15249,-15235,-15223,-15219,34.8,35.6,36.1,34.4
    2025-04-24 18:15:35.790,13853,-15236,36.2,3482,3363,3491,3515,-15254,-15239,-15222,-15229,34.8,35.6,36.2,34.5
    2025-04-24 18:15:40.803,13819,-15239,36.3,3475,3347,3484,3510,-15253,-15233,-15227,-15229,35.0,35.7,36.2,34.7
    2025-04-24 18:15:45.812,13783,-15241,36.3,3468,3331,3478,3504,-15257,-15233,-15232,-15229,35.0,35.6,36.3,34.7
    2025-04-24 18:15:50.824,13746,-15241,36.3,3460,3314,3470,3499,-15261,-15239,-15230,-15230,35.1,35.9,36.3,34.7
    2025-04-24 18:15:55.825,13708,-15243,36.4,3452,3296,3463,3493,-15265,-15250,-15243,-15235,35.1,35.9,36.4,34.8
    2025-04-24 18:16:00.832,13668,-15238,36.4,3444,3278,3456,3488,-15253,-15237,-15228,-15230,35.1,36.0,36.4,34.8
    2025-04-24 18:16:05.847,13626,-15235,36.5,3436,3257,3448,3482,-15253,-15239,-15232,-15228,35.2,36.0,36.5,34.7
    2025-04-24 18:16:10.859,13581,-15243,36.5,3427,3236,3441,3476,-15259,-15242,-15228,-15233,35.2,36.1,36.5,34.7
    2025-04-24 18:16:15.864,13535,-15247,36.6,3418,3213,3433,3471,-15257,-15237,-15232,-15229,35.2,36.1,36.5,34.7
    2025-04-24 18:16:20.879,13487,-15249,36.6,3408,3187,3425,3464,-15242,-15235,-15231,-15239,35.2,36.2,36.6,34.8
    2025-04-24 18:16:25.889,13435,-15241,36.6,3398,3161,3417,3459,-15258,-15239,-15235,-15237,35.2,36.2,36.6,34.7
    2025-04-24 18:16:30.890,13382,-15239,36.7,3388,3131,3408,3453,-15261,-15240,-15229,-15222,35.2,36.3,36.7,34.8
    2025-04-24 18:16:35.902,13323,-15246,36.7,3377,3098,3398,3447,-15258,-15245,-15226,-15233,35.3,36.3,36.7,34.7
    2025-04-24 18:16:40.907,13259,-15256,36.7,3365,3061,3388,3440,-15266,-15258,-15251,-15249,35.3,36.4,36.7,34.8
    2025-04-24 18:16:45.915,13188,-15257,36.8,3353,3019,3378,3434,-15273,-15259,-15240,-15246,35.3,36.4,36.8,34.8
    2025-04-24 18:16:50.928,13110,-15251,36.8,3341,2969,3367,3427,-15262,-15242,-15240,-15244,35.4,36.5,36.8,34.7
    2025-04-24 18:16:55.942,13019,-15240,36.9,3328,2909,3356,3420,-15259,-15240,-15239,-15235,35.5,36.5,36.9,34.7
    2025-04-24 18:17:00.953,12907,-15255,37.0,3314,2829,3344,3414,-15275,-15248,-15245,-15247,35.4,36.6,36.9,34.7
    2025-04-24 18:17:05.957,12765,-15257,37.0,3300,2725,3332,3406,-15285,-15255,-15256,-15246,35.5,36.6,37.0,34.7
    2025-04-24 18:17:10.966,12744,-14895,37.0,3302,2681,3334,3412,-15241,-15236,-15228,-15240,35.6,36.6,37.0,34.8
    2025-04-24 18:17:15.977,12972,0,37.0,3354,2754,3395,3476,0,0,0,0,35.6,36.7,37.0,34.7
    2025-04-24 18:17:20.985,13058,0,37.0,3366,2800,3407,3488,0,0,0,0,35.7,36.7,37.0,34.8
    2025-04-24 18:17:25.992,13102,0,37.0,3372,2823,3414,3495,0,0,0,0,35.6,36.7,37.0,34.7
    2025-04-24 18:17:30.996,14800,0,19.8,0,0,0,0,0,0,0,,,,,34.8
    2025-04-24 18:17:36.001,13155,0,37.0,3380,2850,3423,3504,0,0,0,0,35.6,36.8,37.0,34.9
    2025-04-24 18:17:41.015,13174,0,37.0,3383,2859,3426,3508,0,0,,,,,,
    2025-04-24 18:17:46.021,13189,0,37.0,3385,2866,3428,3510,0,0,0,0,35.5,36.7,37.0,34.9
    2025-04-24 18:17:51.028,13203,0,36.9,3387,2873,3431,3513,0,0,0,0,35.4,36.7,36.9,35.0
    2025-04-24 18:17:56.036,13215,0,36.9,3389,2879,3433,3515,0,0,0,0,35.4,36.6,36.9,34.9
    2025-04-24 18:18:01.044,13226,0,36.8,3391,2884,3435,3517,0,0,0,0,35.2,36.6,36.8,34.8
    2025-04-24 18:18:06.058,13239,0,36.8,3393,2889,3437,3519,0,0,0,0,35.2,36.6,36.8,34.8
    --------------------update of post after 3 hours this morning----------------
    today, I charged pack to full and process GPC maker with previous knowledge of this post
    I received report with gg file. In GPC maker, I do "option B" to update gg file with selected chemistry. I already do "option A", but chemistry will be very different, so I do not know if it is a good choice, and there is no gg file generated. I not tested option A.
    With option B, I reload gg file into card (then based on my own gg file by server update), and do reset of gauge to reload.
    I can see some difference of ra table, but not significant
    the SOH will be now 93% instead of 87%, but not yet 100%....
    the problem is then not resolved.
    What's your opinion?
    Have I missed anything?
    see attached report file received by TI server
    8154.GPCPackaged-report.zip
    CM
  • Hi Cedric,
    Thank you for sharing the results, this is interesting since based on the resistance table values reducing at this time and Qmax increasing at this time, this is most likely increasing the calculated FCC, which in turn will increase the SOH.
    What is the FCC now at the time that 93 is being received? Is there any change in the FCC at this time when a charge -> relax -> discharge cycle is completed?
    Anthony
  • thanks to quick reply,
    Here's the registry log, taken several hours after loading the gg file (just now!), then via GPC Maker and rebooting like tell in previous post.
    here : native log file and same data in excel to better read
    Fri Apr 25 20:15:30 CEST 2025
    Device Version Info = 4500_5_05
    BQZ Device Name = bq40z50R5
    BQZ Firmware Version = V5_05_BLD96
    Design Capacity = 8000
    Design Voltage = 14800
    Specification Info = 0x0031
    Manufacturer Date = 2025-2-20
    Serial Number = 0x0000
    Manufacturer Name = W3Embedded
    Device Name = bq40z50-R5
    Device Chemistry = LION
    Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,AvgTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,MaxTurboPwr,SusTurboPwr,MaxTurboCurr,SusTurboCurr,TurboRhf,TurboVx,TurboQpass,TurboIsim,TurboVloadCell1,TurboVloadCell2,TurboVloadCell3,TurboVloadCell4,TurboVloadStack,TurboVloadSystem,TurboReffCell1,TurboReffCell2,TurboReffCell3,TurboReffCell4,TurboReffStack,TurboReffSystem,TurboSPPCCell1,TurboSPPCCell2,TurboSPPCCell3,TurboSPPCCell4,TurboSPPCStack,TurboSPPCSystem,TurboRhfCell,SoH,OpStatA,OpStatB,TempRange,ChgStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,CellVolt1,CellVolt2,CellVolt3,CellVolt4,vBAT,vPACK,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellPower1,CellPower2,CellPower3,CellPower4,Power,AvgPow,IntTemp,TS1Temp,TS2Temp,TS3Temp,TS4Temp,CellTemp,FETTemp,GaugeTemp,GaugeTemp,TMP468IntTemp,TMP468Remote1Temp,TMP468Remote2Temp,TMP468Remote3Temp,TMP468Remote4Temp,TMP468Remote5Temp,TMP468Remote6Temp,TMP468Remote7Temp,TMP468Remote8Temp,UnCompCellVolt1,UnCompCellVolt2,UnCompCellVolt3,UnCompCellVolt4,FiltCellVolt1,FiltCellVolt2,FiltCellVolt3,FiltCellVolt4,FiltCellCurr1,FiltCellCurr2,FiltCellCurr3,FiltCellCurr4,FiltTemp,FltRemQ,FltRemE,FltFullChgQ,FltFullChgE,NoLoadRemCap,TrueRemQ,TrueRemE,InitialQ,InitialE,TrueFullChgQ,TrueFullChgE,T_sim,T_ambient,RaScale1,RaScale2,RaScale3,RaScale4,CompRes1,CompRes2,CompRes3,CompRes4,PackGrid,LStatus,CellGrid1,CellGrid2,CellGrid3,CellGrid4,StateTime,DOD0_1,DOD0_2,DOD0_3,DOD0_4,DOD0 Passed Q,DOD0 Passed E,DOD0 Time,DODEOC_1,DODEOC_2,DODEOC_3,DODEOC_4,QMax1,QMax2,QMax3,QMax4,QMaxDOD0_1,QMaxDOD0_2,QMaxDOD0_3,QMaxDOD0_4,QMaxPassedQ,QMaxTime,Tk,Ta,RawDOD_1,RawDOD_2,RawDOD_3,RawDOD_4,CBTime1,CBTime2,CBTime3,CBTime4,CBDOD_1,CBDOD_2,CBDOD_3,CBDOD_4,CBTotalDODChg,BalStat,SOH_FC_Q,SOH_FC_E,AccumT,AccumQ,LogRowTime(ms),LogStatus
    1,2025-04-25 20:15:34,4.008,0x0107,300,10,0x6000,0,65535,65535,1,25.3,16290,0,0,1,100,84,6676,6676,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4069,4084,4096,4076,16323,16323,3,3,3,3,12,12,-32767,-32767,-32767,-32767,-32767,-32767,11,93,0x0107,0x1000,0x08,0x0008,0x52,0x0011,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4069,4072,4084,4067,16280,16329,0,0,0,0,0,0,0,0,0,0,27.2,25.2,25.2,25.1,25.3,25.3,27.5,25.1,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,407.1,407.2,408.7,407.0,4069,4072,4083,4067,10,11,10,9,25.1,6676,10182,6676,10182,7172,6972,10663,-296,-481,6676,10182,25.3,25.1,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,29937,2015,1727,1503,1887,0,0,53,2464,2256,2096,1312,8178,8178,8178,8178,0,0,0,0,0,133,0.5,1051,2016,1728,1504,1888,0,59578,59578,26939,2016,1728,1504,1888,18432,0x0A,7459,11354,0,0,1654,SUCCESS
    registers_250425_after_GPCmaker.xls
    I've noted a few comments.
    is this what you wanted?
    CM
  • Hello Cedric,
    Thanks for the update. We won't close the thread and reviewing your question.
    Thank you,
    Alan
  • Hello
    I do not understand.
    Will you continue to help me find the problem or do nothing?
    CM
  • Hi Cedric,
    Sorry for the delay, and thanks for sharing that information. Regarding the resistance, it does seem like this was able to assist the initial calculation of the SOH_FCC, but since the resistance will be updated the next time there is a discharge, I believe it would be out of the picture to try and scale this further since it will just update. Another aspect we can look into is the SOH Load Rate, which in this case is set to 1.6A. Is this the typical current rate for this application at this time?
    Another option would be to use the host to scale this value to 100, but I believe we can keep looking into the settings to see if other factors can adjust this.
    Anthony
    1) Regarding the Ra optimization, indeed, multiplying the tests doesn't seem like the solution to me either, because the "offset" anomaly is upstream; the optimization only affects the factor.
    2) Regarding the Load Rate, this was one of the obscure points of the configuration, which isn't clearly explained in the documentation (just a short paragraph).
    There is a formula, of course, but the current to choose isn't explained.
    I don't know if I need an average current, a peak current, or an average maximum current.
    When you mention a load rate of 1.6A, I assume you mean the current resulting from 1.6A.
    I = DC/SOH load rate = 8000mAh / (50h * 0.1) = 1600mA
    So, you think that setting the current can have an effect on the initial SOH and not on the SOH that changes over time?
    Because in my case, the initial SOH was incorrect, I haven't yet been able to test the SOH aging, even though I thought this parameter concerned aging.
    For the typical current, it's difficult to choose because I don't know the criteria required by the FW.
    What should I use as a typical current?
    Since my operation is linked to motor control, my current varies depending on the mechanical torque, so I can have long discharges at 1A, like 5A, or 15A in short 10s increments.
    In the case of 1A or 15A:
    SOH load rate = DC / I = 8000mAh / (1000 * 0.1) = 80
    SOH load rate = DC / I = 8000mAh / (15000 * 0.1) = 5
    So for now, the default value of 50 hasn't bothered me. Should Imax or Iavg be preferred?
    3) Of course, if we can initially set SOH to 100%, I'm interested, but that's precisely what I've been trying to do all along, but I can't seem to find a way to configure it. I'd love to know how to set this value!
    CM
  • Hello Cedric,
    Thank you,
    Alan
  • Hi Cedric,
    Sorry for the delay, we typically recommend for the SOH Load rate to reflect the average current at this time. Since the model is a constant current load based on what is set in SOH Load rate, having it at the Imax would be aggressive and not reflect the true SOH.
    Would it be possible to try the SOH_LEARN_EN feature here? This can be enabled in the IT Gauging Ext register seen below. I believe this would need to be enabled and a quick cycle would need to be ran, then pull the .srec from it with the updated values. I would like to see if this learned value will allow us to reach an SOH of 100 upon programming here.
    Anthony
    As requested, attached are the SREC files, log, and parameters before and after modifying the "SOH_LEARN" bit.
    The pack was initially charged to 97% and was discharged at 15A (fast).
    Before:
    parameters_before.gg.csv
    Mon May 05 13:58:49 CEST 2025
    1,2025-05-05 13:58:53,4.005,0x0187,300,10,0x6000,0,65535,65535,1,26.0,16025,0,0,1,97,79,6291,6505,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4000,4010,4042,4012,16062,16062,4,4,3,4,15,15,-32767,-32767,-32767,-32767,-32767,-32767,14,92,0x0187,0x1000,0x08,0x0008,0x52,0x0011,0x01F8,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,3997,3999,4032,3999,16017,16066,0,0,0,0,0,0,0,0,0,0,28.2,25.9,25.8,25.7,25.9,25.9,28.1,25.7,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,399.5,400.2,403.2,399.9,3996,3998,4033,4000,11,11,10,9,25.7,6291,9571,6505,9918,6491,6291,9571,214,347,6505,9918,25.6,25.7,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,439286,3379,3168,2540,3125,0,0,28,2480,2272,2112,1328,8178,8178,8178,8178,0,0,0,0,-5169,2185,0.5,1051,3472,3200,2560,3200,0,62454,62454,62454,3472,3200,2560,3200,18448,0x04,7399,10968,0,0,1957,SUCCESS
    2,2025-05-05 13:58:57,8.012,0x0187,300,10,0x6000,0,65535,65535,1,25.9,16025,0,0,1,97,79,6291,6505,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4000,4010,4042,4012,16062,16062,4,4,3,4,15,15,-32767,-32767,-32767,-32767,-32767,-32767,14,92,0x0187,0x1000,0x08,0x0008,0x52,0x0011,0x01F8,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,3998,3998,4032,4000,16018,16066,0,0,0,0,0,0,0,0,0,0,28.3,25.8,25.8,25.7,25.9,25.9,28.3,25.6,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,399.8,399.8,403.2,400.0,3996,3998,4033,4000,11,11,9,9,25.7,6291,9571,6505,9918,6491,6291,9571,214,347,6505,9918,25.6,25.7,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,439290,3379,3168,2540,3125,0,0,28,2480,2272,2112,1328,8178,8178,8178,8178,0,0,0,0,-5169,2185,0.5,1051,3472,3200,2560,3200,0,62452,62452,62452,3472,3200,2560,3200,18448,0x04,7399,10968,0,0,1862,SUCCESS
    3,2025-05-05 13:59:02,12.490,0x0187,300,10,0x6000,0,65535,65535,1,25.9,16026,0,0,1,97,79,6291,6505,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4000,4010,4042,4012,16062,16062,4,4,3,4,15,15,-32767,-32767,-32767,-32767,-32767,-32767,14,92,0x0187,0x1000,0x08,0x0008,0x52,0x0011,0x01F8,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3998,4031,3999,16017,16065,0,0,0,0,0,0,0,0,0,0,28.3,25.8,25.8,25.6,25.9,25.9,28.3,25.6,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,399.6,399.8,403.2,399.9,3996,3998,4033,4000,11,11,10,9,25.7,6291,9571,6505,9918,6491,6291,9571,214,347,6505,9918,25.6,25.6,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,439294,3379,3168,2540,3125,0,0,28,2480,2272,2112,1328,8178,8178,8178,8178,0,0,0,0,-5169,2185,0.5,1051,3472,3200,2560,3200,0,62450,62450,62450,3472,3200,2560,3200,18448,0x04,7399,10968,0,0,1897,SUCCESS
    4,2025-05-05 13:59:05,16.042,0x0187,300,10,0x6000,0,65535,65535,1,25.9,16026,0,0,1,97,79,6291,6505,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4000,4010,4042,4012,16062,16062,4,4,3,4,15,15,-32767,-32767,-32767,-32767,-32767,-32767,14,92,0x0187,0x1000,0x08,0x0008,0x52,0x0011,0x01F8,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3999,4031,3999,16018,16068,0,0,0,0,0,0,0,0,0,0,28.2,25.8,25.8,25.6,25.9,25.9,28.2,25.7,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,399.8,399.8,403.2,399.9,3996,3998,4033,4000,11,10,10,9,25.7,6291,9571,6505,9918,6491,6291,9571,214,347,6505,9918,25.6,25.6,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,439298,3379,3168,2540,3125,0,0,28,2480,2272,2112,1328,8178,8178,8178,8178,0,0,0,0,-5169,2185,0.5,1051,3472,3200,2560,3200,0,62448,62448,62448,3472,3200,2560,3200,18448,0x04,7399,10968,0,0,1927,SUCCESS
    FW_before.zip
    Discharge log:
    Data Log
    TimeStamp,Cell 1 Voltage,Cell 2 Voltage,Cell 3 Voltage,Cell 4 Voltage,Cell 1 Current,Cell 2 Current,Cell 3 Current,Cell 4 Current,TS1 Temperature,TS2 Temperature,TS3 Temperature,TS4 Temperature,Relative State of Charge
    2025-05-05 14:11:59.500,3996,3998,4032,4001,0,0,0,0,25.3,25.4,25.4,25.4,96
    2025-05-05 14:12:04.505,3996,3998,4032,4001,0,0,0,0,25.3,25.4,25.4,25.4,96
    2025-05-05 14:12:09.590,3996,3998,4032,4001,0,0,0,0,25.3,25.4,25.4,25.4,96
    2025-05-05 14:12:14.525,3977,3977,4002,3968,-7110,-7459,-7459,-7459,25.3,25.4,25.4,25.4,96
    2025-05-05 14:12:19.526,3920,3929,3943,3911,-14606,-14602,-14602,-14608,25.3,25.4,25.4,25.4,95
    2025-05-05 14:12:24.535,3907,3916,3929,3897,-14628,-14617,-14617,-14622,25.3,25.5,25.4,25.4,95
    2025-05-05 14:12:29.623,3898,3906,3919,3888,-14630,-14628,-14627,-14636,25.7,25.4,25.4,25.5,95
    2025-05-05 14:12:34.550,3891,3899,3911,3878,-14639,-14637,-14636,-14640,29.9,27.0,27.4,29.3,95
    2025-05-05 14:12:39.559,3886,3893,3904,3875,-14644,-14645,-14641,-14649,29.6,27.4,27.6,28.8,94
    2025-05-05 14:12:44.573,3881,3888,3898,3868,-14643,-14651,-14649,-14656,27.7,26.6,26.8,27.6,94
    2025-05-05 14:12:49.655,3877,3884,3893,3865,-14656,-14660,-14657,-14659,26.7,26.2,26.3,26.8,94
    2025-05-05 14:12:54.597,3874,3880,3889,3861,-14659,-14656,-14660,-14665,26.3,26.0,25.9,26.5,93
    2025-05-05 14:12:59.604,3871,3876,3885,3858,-14665,-14661,-14666,-14666,26.0,25.8,25.9,26.2,93
    2025-05-05 14:13:04.617,3868,3874,3881,3855,-14670,-14664,-14672,-14670,25.9,25.8,25.8,26.0,93
    2025-05-05 14:13:09.721,3866,3872,3877,3853,-14676,-14672,-14679,-14679,25.9,25.8,25.8,25.9,92
    2025-05-05 14:13:14.632,3862,3868,3874,3850,-14678,-14678,-14679,-14681,25.9,25.8,25.8,26.0,92
    2025-05-05 14:13:19.639,3860,3865,3871,3847,-14684,-14682,-14684,-14684,25.8,25.8,25.8,25.9,92
    2025-05-05 14:13:24.651,3858,3863,3867,3845,-14690,-14685,-14689,-14689,25.8,25.7,25.8,25.9,91
    2025-05-05 14:13:29.748,3856,3861,3864,3844,-14694,-14691,-14686,-14690,25.9,25.8,25.8,25.9,91
    2025-05-05 14:13:34.671,3854,3859,3862,3841,-14694,-14698,-14694,-14701,25.9,25.8,25.8,25.9,91
    2025-05-05 14:13:39.682,3852,3856,3859,3840,-14697,-14699,-14695,-14699,25.9,25.8,25.9,25.9,91
    2025-05-05 14:13:44.691,3850,3854,3856,3838,-14700,-14701,-14698,-14707,25.9,25.8,25.9,25.9,90
    2025-05-05 14:13:49.779,3849,3853,3854,3836,-14704,-14705,-14701,-14707,25.9,25.8,25.9,25.9,90
    2025-05-05 14:13:54.709,3847,3851,3852,3834,-14708,-14707,-14714,-14711,25.9,25.8,25.9,25.9,90
    2025-05-05 14:13:59.715,3845,3849,3850,3832,-14709,-14711,-14711,-14711,26.0,25.8,25.9,25.9,89
    2025-05-05 14:14:04.727,3843,3847,3847,3831,-14714,-14712,-14713,-14713,26.0,25.8,25.9,26.0,89
    2025-05-05 14:14:09.825,3842,3845,3846,3829,-14718,-14715,-14718,-14711,25.9,25.8,25.9,26.0,89
    2025-05-05 14:14:14.751,3840,3843,3844,3828,-14723,-14718,-14719,-14721,25.9,25.8,26.0,26.0,88
    2025-05-05 14:14:19.763,3838,3841,3842,3826,-14715,-14724,-14719,-14723,26.0,25.8,26.0,26.0,88
    2025-05-05 14:14:24.772,3836,3839,3840,3824,-14716,-14724,-14725,-14725,26.0,25.8,25.9,25.9,88
    2025-05-05 14:14:29.827,3835,3838,3838,3823,-14726,-14728,-14727,-14726,26.0,25.8,25.9,25.9,87
    2025-05-05 14:14:34.787,3833,3836,3836,3821,-14729,-14728,-14727,-14727,26.0,25.8,25.9,26.0,87
    2025-05-05 14:14:39.796,3831,3834,3835,3819,-14733,-14729,-14731,-14728,26.0,25.9,25.9,26.0,87
    2025-05-05 14:14:44.808,3830,3832,3833,3818,-14733,-14729,-14733,-14730,26.0,25.9,25.9,26.0,87
    2025-05-05 14:14:49.889,3828,3831,3832,3816,-14735,-14730,-14736,-14738,26.0,25.9,25.9,26.0,86
    2025-05-05 14:14:54.829,3826,3828,3830,3815,-14738,-14733,-14737,-14735,26.1,25.9,26.0,26.0,86
    2025-05-05 14:14:59.841,3824,3827,3828,3813,-14735,-14736,-14743,-14738,26.2,25.9,26.0,26.1,86
    2025-05-05 14:15:04.854,3823,3825,3826,3813,-14738,-14742,-14740,-14738,26.2,25.9,26.0,26.1,85
    2025-05-05 14:15:09.902,3821,3823,3825,3811,-14741,-14745,-14741,-14747,26.2,26.0,26.0,26.2,85
    2025-05-05 14:15:14.876,3819,3821,3823,3809,-14743,-14746,-14739,-14742,26.2,25.9,26.0,26.2,85
    2025-05-05 14:15:19.885,3817,3819,3821,3808,-14745,-14746,-14744,-14747,26.3,26.0,26.0,26.2,84
    2025-05-05 14:15:24.897,3816,3817,3820,3806,-14746,-14750,-14738,-14749,26.4,26.0,26.0,26.3,84
    2025-05-05 14:15:29.948,3814,3815,3818,3804,-14749,-14751,-14746,-14750,26.4,26.0,26.0,26.3,84
    2025-05-05 14:15:34.919,3812,3813,3816,3803,-14751,-14754,-14747,-14752,26.4,26.0,26.0,26.4,83
    2025-05-05 14:15:39.930,3810,3812,3815,3801,-14750,-14749,-14746,-14754,26.4,26.1,26.0,26.4,83
    2025-05-05 14:15:44.931,3809,3810,3813,3799,-14750,-14751,-14750,-14758,26.5,26.1,26.0,26.5,83
    2025-05-05 14:15:49.997,3807,3808,3811,3798,-14749,-14752,-14757,-14751,26.5,26.2,26.1,26.5,82
    2025-05-05 14:15:54.948,3805,3806,3810,3796,-14757,-14752,-14758,-14759,26.6,26.2,26.1,26.5,82
    2025-05-05 14:15:59.961,3803,3804,3808,3792,-14757,-14754,-14758,-14761,26.6,26.3,26.2,26.5,82
    2025-05-05 14:16:04.971,3801,3802,3806,3791,-14753,-14757,-14760,-14757,26.6,26.3,26.2,26.6,82
    2025-05-05 14:16:10.036,3800,3801,3805,3789,-14756,-14760,-14760,-14759,26.7,26.3,26.3,26.7,81
    2025-05-05 14:16:14.991,3798,3799,3803,3787,-14759,-14758,-14758,-14762,26.7,26.4,26.3,26.7,81
    2025-05-05 14:16:20.002,3796,3797,3801,3786,-14758,-14758,-14757,-14764,26.8,26.4,26.3,26.8,81
    2025-05-05 14:16:25.015,3794,3795,3799,3784,-14756,-14759,-14759,-14768,26.8,26.4,26.3,26.8,80
    2025-05-05 14:16:30.066,3793,3794,3798,3782,-14761,-14759,-14764,-14769,26.9,26.5,26.4,26.9,80
    2025-05-05 14:16:35.032,3791,3792,3796,3780,-14765,-14762,-14759,-14764,26.9,26.5,26.4,26.9,80
    2025-05-05 14:16:40.042,3789,3790,3794,3779,-14763,-14765,-14762,-14764,27.0,26.6,26.5,26.9,79
    2025-05-05 14:16:45.054,3787,3788,3792,3777,-14765,-14765,-14769,-14763,27.0,26.6,26.5,27.0,79
    2025-05-05 14:16:50.093,3786,3786,3790,3775,-14769,-14765,-14764,-14763,27.1,26.7,26.5,27.0,79
    2025-05-05 14:16:55.068,3784,3785,3788,3774,-14774,-14767,-14768,-14765,27.1,26.7,26.6,27.1,78
    2025-05-05 14:17:00.075,3782,3783,3787,3772,-14761,-14769,-14767,-14768,27.2,26.7,26.6,27.1,78
    2025-05-05 14:17:05.085,3781,3781,3785,3770,-14763,-14769,-14768,-14767,27.2,26.8,26.6,27.1,78
    2025-05-05 14:17:10.139,3779,3780,3783,3769,-14766,-14770,-14771,-14772,27.2,26.8,26.7,27.2,77
    2025-05-05 14:17:15.098,3777,3778,3781,3767,-14766,-14769,-14770,-14773,27.3,26.8,26.7,27.2,77
    2025-05-05 14:17:20.111,3775,3776,3780,3765,-14769,-14767,-14770,-14770,27.4,26.9,26.8,27.3,77
    2025-05-05 14:17:25.126,3774,3775,3778,3764,-14772,-14765,-14772,-14772,27.4,26.9,26.8,27.4,77
    2025-05-05 14:17:30.174,3772,3773,3776,3762,-14772,-14770,-14772,-14773,27.4,26.9,26.8,27.4,76
    2025-05-05 14:17:35.140,3770,3771,3775,3761,-14773,-14771,-14772,-14772,27.5,27.0,26.9,27.4,76
    2025-05-05 14:17:40.150,3769,3770,3773,3759,-14773,-14770,-14775,-14777,27.5,27.0,26.9,27.5,76
    2025-05-05 14:17:45.160,3767,3768,3771,3758,-14777,-14775,-14774,-14777,27.6,27.0,27.0,27.5,75
    2025-05-05 14:17:50.167,3766,3767,3770,3756,-14772,-14776,-14774,-14778,27.5,27.1,27.0,27.6,75
    2025-05-05 14:17:55.167,3764,3765,3768,3754,-14773,-14777,-14776,-14775,27.5,27.1,27.1,27.6,75
    2025-05-05 14:18:00.181,3763,3763,3766,3753,-14775,-14777,-14779,-14780,27.6,27.1,27.1,27.6,74
    2025-05-05 14:18:05.189,3761,3762,3764,3751,-14777,-14782,-14785,-14782,27.7,27.2,27.1,27.6,74
    2025-05-05 14:18:10.202,3759,3761,3763,3750,-14776,-14778,-14782,-14778,27.7,27.2,27.2,27.7,74
    2025-05-05 14:18:15.209,3758,3759,3761,3748,-14780,-14776,-14783,-14778,27.7,27.2,27.2,27.6,73
    2025-05-05 14:18:20.223,3756,3757,3760,3746,-14781,-14776,-14780,-14782,27.8,27.3,27.2,27.7,73
    2025-05-05 14:18:25.232,3755,3756,3758,3745,-14782,-14778,-14778,-14784,27.8,27.4,27.3,27.8,73
    2025-05-05 14:18:30.243,3753,3754,3756,3745,-14785,-14781,-14785,-14785,27.8,27.4,27.3,27.8,73
    2025-05-05 14:18:35.257,3752,3753,3755,3744,-14786,-14779,-14786,-14786,27.9,27.4,27.4,27.8,72
    2025-05-05 14:18:40.265,3750,3751,3753,3742,-14784,-14783,-14786,-14791,27.9,27.5,27.4,27.9,72
    2025-05-05 14:18:45.278,3749,3750,3752,3740,-14784,-14786,-14784,-14789,27.9,27.5,27.5,27.9,72
    2025-05-05 14:18:50.287,3748,3749,3750,3739,-14782,-14777,-14786,-14789,28.0,27.5,27.5,27.9,71
    2025-05-05 14:18:55.294,3746,3747,3748,3737,-14784,-14779,-14780,-14784,28.0,27.6,27.6,27.9,71
    2025-05-05 14:19:00.302,3744,3746,3747,3736,-14785,-14777,-14784,-14785,28.0,27.6,27.6,28.0,71
    2025-05-05 14:19:05.316,3743,3744,3746,3735,-14782,-14783,-14784,-14786,28.1,27.6,27.6,28.0,70
    2025-05-05 14:19:10.328,3742,3743,3744,3734,-14782,-14787,-14787,-14790,28.1,27.7,27.7,28.0,70
    2025-05-05 14:19:15.329,3740,3741,3742,3732,-14788,-14792,-14786,-14792,28.1,27.6,27.7,28.1,70
    2025-05-05 14:19:20.342,3739,3740,3741,3730,-14787,-14787,-14786,-14789,28.2,27.7,27.6,28.1,69
    2025-05-05 14:19:25.350,3737,3739,3739,3728,-14788,-14788,-14783,-14791,28.2,27.8,27.7,28.2,69
    2025-05-05 14:19:30.357,3736,3737,3738,3727,-14790,-14787,-14783,-14794,28.3,27.8,27.8,28.2,69
    2025-05-05 14:19:35.366,3735,3736,3737,3725,-14792,-14790,-14788,-14794,28.3,27.8,27.8,28.2,68
    2025-05-05 14:19:40.369,3733,3735,3735,3724,-14787,-14790,-14791,-14792,28.3,27.9,27.9,28.2,68
    2025-05-05 14:19:45.379,3732,3734,3734,3722,-14789,-14789,-14793,-14792,28.4,27.9,27.9,28.3,68
    2025-05-05 14:19:50.386,3731,3732,3733,3721,-14790,-14793,-14790,-14790,28.4,27.9,27.9,28.3,68
    2025-05-05 14:19:55.398,3729,3731,3731,3720,-14790,-14794,-14792,-14788,28.4,27.9,27.9,28.4,67
    2025-05-05 14:20:00.408,3728,3729,3729,3718,-14792,-14796,-14790,-14791,28.4,28.0,28.0,28.4,67
    2025-05-05 14:20:05.419,3727,3728,3728,3717,-14793,-14794,-14791,-14792,28.5,28.0,28.0,28.4,67
    2025-05-05 14:20:10.430,3726,3727,3727,3716,-14795,-14794,-14793,-14796,28.5,28.0,28.1,28.4,66
    2025-05-05 14:20:15.440,3724,3726,3725,3714,-14793,-14795,-14793,-14798,28.5,28.1,28.1,28.5,66
    2025-05-05 14:20:20.450,3723,3725,3724,3713,-14797,-14797,-14795,-14797,28.5,28.1,28.1,28.6,66
    2025-05-05 14:20:25.464,3722,3723,3723,3712,-14793,-14795,-14798,-14797,28.6,28.1,28.1,28.5,65
    2025-05-05 14:20:30.468,3721,3722,3722,3711,-14792,-14795,-14795,-14793,28.6,28.2,28.2,28.6,65
    2025-05-05 14:20:35.476,3719,3721,3720,3710,-14796,-14796,-14797,-14796,28.6,28.2,28.2,28.6,65
    2025-05-05 14:20:40.485,3718,3720,3719,3708,-14795,-14796,-14797,-14799,28.6,28.2,28.3,28.6,64
    2025-05-05 14:20:45.498,3717,3718,3717,3707,-14800,-14798,-14796,-14795,28.6,28.3,28.3,28.6,64
    2025-05-05 14:20:50.510,3716,3717,3716,3706,-14796,-14794,-14793,-14795,28.7,28.3,28.3,28.7,64
    2025-05-05 14:20:55.521,3715,3716,3715,3705,-14798,-14795,-14796,-14795,28.7,28.4,28.4,28.7,63
    2025-05-05 14:21:00.533,3713,3715,3713,3703,-14795,-14794,-14795,-14800,28.7,28.4,28.4,28.7,63
    2025-05-05 14:21:05.536,3712,3714,3712,3702,-14800,-14797,-14796,-14797,28.7,28.5,28.5,28.7,63
    2025-05-05 14:21:10.550,3711,3713,3711,3701,-14804,-14798,-14795,-14792,28.8,28.5,28.6,28.7,63
    2025-05-05 14:21:15.564,3710,3712,3710,3700,-14802,-14798,-14794,-14792,28.9,28.6,28.6,28.7,62
    2025-05-05 14:21:20.575,3709,3710,3708,3699,-14801,-14797,-14794,-14792,28.9,28.5,28.5,28.8,62
    2025-05-05 14:21:25.579,3708,3709,3707,3698,-14799,-14801,-14798,-14798,29.0,28.6,28.6,28.8,62
    2025-05-05 14:21:30.593,3707,3708,3706,3697,-14795,-14799,-14797,-14798,29.0,28.6,28.6,28.9,61
    2025-05-05 14:21:35.608,3706,3707,3705,3696,-14794,-14795,-14794,-14796,29.1,28.6,28.6,29.0,61
    2025-05-05 14:21:40.608,3704,3706,3704,3694,-14797,-14798,-14798,-14799,29.1,28.7,28.7,29.0,61
    2025-05-05 14:21:45.616,3703,3705,3703,3693,-14796,-14795,-14798,-14801,29.2,28.7,28.7,29.1,60
    2025-05-05 14:21:50.618,3703,3704,3701,3692,-14798,-14798,-14801,-14799,29.2,28.7,28.7,29.1,60
    2025-05-05 14:21:55.623,3701,3703,3700,3691,-14799,-14797,-14803,-14804,29.2,28.8,28.8,29.1,60
    2025-05-05 14:22:00.634,3700,3702,3699,3690,-14804,-14798,-14800,-14804,29.2,28.8,28.8,29.1,59
    2025-05-05 14:22:05.637,3699,3701,3698,3689,-14804,-14800,-14801,-14804,29.3,28.8,28.8,29.0,59
    2025-05-05 14:22:10.643,3699,3700,3697,3689,-14806,-14800,-14801,-14800,29.3,28.9,28.9,29.1,59
    2025-05-05 14:22:15.651,3697,3699,3696,3688,-14800,-14800,-14798,-14799,29.3,29.0,29.0,29.1,58
    2025-05-05 14:22:20.666,3696,3698,3694,3687,-14804,-14799,-14795,-14802,29.3,29.0,29.0,29.2,58
    2025-05-05 14:22:25.676,3695,3697,3693,3686,-14804,-14799,-14795,-14803,29.3,29.0,29.0,29.3,58
    2025-05-05 14:22:30.691,3694,3696,3693,3685,-14807,-14802,-14804,-14804,29.4,29.1,29.0,29.3,58
    2025-05-05 14:22:35.697,3693,3695,3691,3684,-14807,-14801,-14807,-14806,29.4,29.1,29.1,29.3,57
    2025-05-05 14:22:40.698,3693,3694,3690,3683,-14806,-14801,-14809,-14811,29.4,29.1,29.2,29.3,57
    2025-05-05 14:22:45.713,3692,3693,3689,3682,-14807,-14803,-14805,-14812,29.4,29.1,29.2,29.3,57
    2025-05-05 14:22:50.717,3691,3692,3688,3681,-14801,-14808,-14800,-14799,29.5,29.2,29.2,29.3,56
    2025-05-05 14:22:55.721,3690,3691,3687,3680,-14801,-14809,-14802,-14809,29.5,29.2,29.3,29.3,56
    2025-05-05 14:23:00.726,3689,3690,3686,3679,-14805,-14808,-14802,-14808,29.5,29.3,29.3,29.3,56
    2025-05-05 14:23:05.736,3688,3689,3685,3678,-14807,-14810,-14803,-14804,29.6,29.3,29.3,29.4,55
    2025-05-05 14:23:10.740,3687,3688,3684,3677,-14810,-14811,-14806,-14806,29.6,29.4,29.3,29.4,55
    2025-05-05 14:23:15.744,3686,3687,3683,3676,-14805,-14806,-14811,-14807,29.6,29.4,29.4,29.5,55
    2025-05-05 14:23:20.745,3685,3686,3682,3675,-14808,-14804,-14808,-14810,29.7,29.4,29.4,29.5,54
    2025-05-05 14:23:25.754,3684,3685,3681,3674,-14808,-14807,-14808,-14807,29.7,29.4,29.4,29.6,54
    2025-05-05 14:23:30.769,3684,3684,3681,3674,-14808,-14804,-14812,-14808,29.7,29.5,29.5,29.6,54
    2025-05-05 14:23:35.776,3683,3684,3679,3672,-14808,-14805,-14812,-14808,29.7,29.5,29.5,29.6,53
    2025-05-05 14:23:40.777,3682,3683,3678,3672,-14808,-14809,-14808,-14810,29.8,29.6,29.6,29.7,53
    2025-05-05 14:23:45.788,3681,3682,3677,3671,-14807,-14810,-14808,-14810,29.8,29.6,29.6,29.7,53
    2025-05-05 14:23:50.790,3680,3681,3676,3670,-14804,-14809,-14809,-14810,29.9,29.7,29.6,29.7,53
    2025-05-05 14:23:55.796,3680,3680,3676,3669,-14808,-14811,-14807,-14812,29.9,29.7,29.6,29.7,52
    2025-05-05 14:24:00.811,3679,3679,3675,3668,-14808,-14811,-14809,-14810,30.0,29.7,29.7,29.8,52
    2025-05-05 14:24:05.813,3678,3679,3674,3667,-14809,-14806,-14806,-14811,30.0,29.7,29.7,29.8,52
    2025-05-05 14:24:10.826,3678,3678,3673,3667,-14810,-14807,-14809,-14811,30.1,29.8,29.7,29.8,51
    2025-05-05 14:24:15.830,3677,3677,3672,3666,-14811,-14811,-14810,-14810,30.1,29.8,29.8,29.9,51
    2025-05-05 14:24:20.837,3676,3676,3671,3665,-14811,-14811,-14809,-14809,30.1,29.9,29.8,29.9,51
    2025-05-05 14:24:25.853,3675,3676,3670,3664,-14812,-14811,-14809,-14805,30.1,29.9,29.9,29.9,50
    2025-05-05 14:24:30.857,3675,3675,3670,3664,-14811,-14812,-14815,-14816,30.1,29.9,29.9,30.0,50
    2025-05-05 14:24:35.860,3674,3674,3669,3663,-14812,-14811,-14811,-14814,30.1,30.0,29.9,30.0,50
    2025-05-05 14:24:40.862,3674,3674,3668,3662,-14812,-14812,-14813,-14814,30.2,30.1,30.0,30.0,49
    2025-05-05 14:24:45.867,3673,3673,3667,3662,-14808,-14813,-14812,-14814,30.2,30.1,30.1,30.1,49
    2025-05-05 14:24:50.919,3672,3672,3666,3661,-14813,-14814,-14815,-14812,30.2,30.2,30.1,30.0,49
    2025-05-05 14:24:55.883,3672,3672,3666,3661,-14813,-14815,-14817,-14817,30.2,30.2,30.1,30.1,49
    2025-05-05 14:25:00.887,3671,3671,3665,3660,-14815,-14812,-14812,-14813,30.3,30.2,30.2,30.1,48
    2025-05-05 14:25:05.891,3671,3670,3664,3660,-14811,-14815,-14815,-14816,30.3,30.2,30.2,30.2,48
    2025-05-05 14:25:10.983,3670,3670,3663,3659,-14814,-14815,-14813,-14818,30.3,30.3,30.2,30.2,48
    2025-05-05 14:25:15.906,3670,3669,3663,3659,-14814,-14813,-14814,-14818,30.4,30.3,30.2,30.3,47
    2025-05-05 14:25:20.916,3669,3669,3662,3658,-14816,-14815,-14815,-14814,30.5,30.4,30.2,30.2,47
    2025-05-05 14:25:25.930,3669,3668,3661,3658,-14817,-14817,-14816,-14810,30.5,30.4,30.3,30.3,47
    2025-05-05 14:25:30.997,3668,3668,3661,3657,-14819,-14816,-14818,-14815,30.5,30.5,30.3,30.3,46
    2025-05-05 14:25:35.958,3668,3667,3660,3657,-14820,-14816,-14814,-14812,30.6,30.5,30.4,30.3,46
    2025-05-05 14:25:40.967,3667,3667,3659,3657,-14822,-14815,-14815,-14816,30.6,30.6,30.5,30.3,46
    2025-05-05 14:25:45.973,3667,3666,3659,3656,-14816,-14819,-14816,-14816,30.6,30.7,30.5,30.4,45
    2025-05-05 14:25:51.073,3667,3665,3658,3655,-14818,-14822,-14816,-14818,30.7,30.7,30.6,30.5,45
    2025-05-05 14:25:55.981,3666,3665,3657,3656,-14816,-14822,-14814,-14817,30.8,30.7,30.6,30.5,45
    2025-05-05 14:26:00.989,3665,3664,3657,3655,-14817,-14813,-14818,-14819,30.8,30.8,30.6,30.6,44
    2025-05-05 14:26:06.003,3665,3664,3656,3655,-14819,-14818,-14818,-14816,30.8,30.8,30.7,30.7,44
    2025-05-05 14:26:11.126,3665,3663,3656,3654,-14819,-14826,-14818,-14817,30.8,30.9,30.7,30.6,44
    2025-05-05 14:26:16.020,3664,3662,3655,3654,-14821,-14818,-14817,-14821,31.0,30.9,30.7,30.6,43
    2025-05-05 14:26:21.022,3664,3662,3655,3654,-14821,-14817,-14815,-14821,30.9,31.0,30.8,30.7,43
    2025-05-05 14:26:26.035,3663,3661,3654,3653,-14821,-14819,-14814,-14821,31.0,31.0,30.8,30.7,43
    2025-05-05 14:26:31.139,3663,3661,3654,3653,-14821,-14820,-14822,-14820,30.9,31.1,30.9,30.7,42
    2025-05-05 14:26:36.053,3662,3660,3653,3652,-14821,-14825,-14818,-14821,31.0,31.1,30.9,30.6,42
    2025-05-05 14:26:41.064,3662,3659,3653,3651,-14821,-14825,-14820,-14819,31.0,31.2,31.0,30.7,42
    2025-05-05 14:26:46.076,3662,3659,3652,3651,-14819,-14827,-14821,-14819,31.1,31.2,31.0,30.7,42
    2025-05-05 14:26:51.201,3661,3658,3652,3652,-14817,-14824,-14820,-14815,31.1,31.3,31.1,30.8,41
    2025-05-05 14:26:56.086,3661,3658,3652,3650,-14824,-14820,-14822,-14815,31.2,31.3,31.1,30.8,41
    2025-05-05 14:27:01.097,3660,3657,3651,3650,-14824,-14823,-14825,-14821,31.2,31.4,31.2,30.8,41
    2025-05-05 14:27:06.098,3660,3656,3651,3649,-14823,-14823,-14822,-14821,31.3,31.4,31.2,30.9,40
    2025-05-05 14:27:11.209,3659,3656,3650,3649,-14828,-14823,-14827,-14824,31.3,31.5,31.3,30.9,40
    2025-05-05 14:27:16.104,3659,3655,3650,3649,-14824,-14823,-14826,-14828,31.4,31.5,31.3,30.9,40
    2025-05-05 14:27:21.112,3659,3654,3650,3648,-14827,-14824,-14824,-14828,31.4,31.6,31.3,30.9,39
    2025-05-05 14:27:26.116,3658,3654,3649,3648,-14826,-14825,-14825,-14826,31.5,31.7,31.4,30.9,39
    2025-05-05 14:27:31.244,3657,3654,3649,3648,-14827,-14825,-14827,-14828,31.5,31.8,31.4,31.0,39
    2025-05-05 14:27:36.120,3657,3652,3648,3647,-14825,-14831,-14825,-14827,31.5,31.8,31.5,31.1,38
    2025-05-05 14:27:41.126,3656,3652,3647,3647,-14825,-14824,-14828,-14827,31.7,31.9,31.5,31.1,38
    2025-05-05 14:27:46.130,3656,3651,3647,3646,-14828,-14822,-14827,-14829,31.7,31.9,31.6,31.1,38
    2025-05-05 14:27:51.291,3655,3650,3647,3646,-14830,-14829,-14826,-14829,31.8,31.9,31.7,31.2,37
    2025-05-05 14:27:56.146,3655,3650,3646,3646,-14827,-14826,-14830,-14827,31.8,32.0,31.8,31.1,37
    2025-05-05 14:28:01.150,3654,3649,3646,3645,-14827,-14828,-14828,-14828,31.8,32.1,31.8,31.1,37
    2025-05-05 14:28:06.161,3654,3648,3645,3645,-14826,-14833,-14828,-14831,31.9,32.2,31.8,31.2,36
    2025-05-05 14:28:11.304,3654,3647,3645,3644,-14827,-14831,-14834,-14826,31.9,32.2,31.9,31.2,36
    2025-05-05 14:28:16.189,3653,3646,3644,3644,-14829,-14828,-14828,-14828,31.9,32.3,31.9,31.2,36
    2025-05-05 14:28:21.190,3652,3645,3644,3643,-14828,-14831,-14827,-14830,32.1,32.3,31.9,31.2,36
    2025-05-05 14:28:26.196,3652,3645,3643,3643,-14829,-14831,-14830,-14830,32.2,32.4,32.0,31.3,35
    2025-05-05 14:28:31.374,3651,3644,3643,3643,-14828,-14829,-14828,-14831,32.2,32.5,32.1,31.4,35
    2025-05-05 14:28:36.218,3650,3643,3642,3642,-14830,-14830,-14833,-14829,32.2,32.5,32.1,31.4,35
    2025-05-05 14:28:41.222,3650,3642,3642,3642,-14833,-14828,-14831,-14830,32.3,32.6,32.2,31.6,34
    2025-05-05 14:28:46.223,3649,3641,3641,3641,-14833,-14833,-14831,-14830,32.3,32.6,32.2,31.6,34
    2025-05-05 14:28:51.408,3649,3640,3640,3641,-14829,-14834,-14831,-14830,32.3,32.8,32.3,31.6,34
    2025-05-05 14:28:56.242,3648,3640,3640,3640,-14834,-14832,-14833,-14836,32.4,32.8,32.3,31.6,33
    2025-05-05 14:29:01.251,3647,3638,3639,3640,-14834,-14832,-14835,-14834,32.4,32.8,32.4,31.7,33
    2025-05-05 14:29:06.255,3647,3638,3639,3639,-14834,-14834,-14838,-14835,32.5,32.9,32.4,31.8,33
    2025-05-05 14:29:11.457,3646,3636,3638,3638,-14833,-14832,-14830,-14834,32.6,33.0,32.5,31.9,32
    2025-05-05 14:29:16.273,3645,3636,3638,3638,-14833,-14836,-14834,-14834,32.6,33.0,32.6,31.8,32
    2025-05-05 14:29:21.284,3644,3634,3637,3638,-14837,-14836,-14837,-14832,32.7,33.0,32.6,31.9,32
    2025-05-05 14:29:26.286,3644,3633,3636,3637,-14839,-14834,-14836,-14836,32.8,33.2,32.8,31.9,31
    2025-05-05 14:29:31.479,3643,3633,3636,3636,-14834,-14839,-14835,-14834,32.8,33.2,32.8,31.9,31
    2025-05-05 14:29:36.294,3642,3631,3635,3636,-14840,-14837,-14839,-14838,32.8,33.3,32.8,31.9,31
    2025-05-05 14:29:41.303,3641,3630,3635,3636,-14843,-14835,-14836,-14841,32.8,33.3,32.8,31.9,30
    2025-05-05 14:29:46.316,3641,3629,3634,3635,-14841,-14835,-14839,-14839,32.8,33.4,32.9,32.0,30
    2025-05-05 14:29:51.513,3640,3628,3633,3634,-14833,-14840,-14840,-14839,32.8,33.5,33.0,32.1,30
    2025-05-05 14:29:56.320,3639,3626,3632,3634,-14838,-14840,-14838,-14840,32.9,33.5,33.0,32.1,29
    2025-05-05 14:30:01.329,3638,3625,3632,3633,-14843,-14844,-14842,-14838,33.0,33.6,33.1,32.2,29
    2025-05-05 14:30:06.337,3637,3624,3631,3633,-14842,-14846,-14842,-14835,33.0,33.7,33.2,32.3,29
    2025-05-05 14:30:11.569,3636,3623,3630,3632,-14841,-14836,-14842,-14840,33.1,33.7,33.2,32.4,28
    2025-05-05 14:30:16.352,3636,3621,3630,3631,-14840,-14849,-14841,-14840,33.2,33.8,33.3,32.4,28
    2025-05-05 14:30:21.363,3635,3620,3629,3630,-14837,-14841,-14842,-14841,33.2,33.8,33.3,32.4,28
    2025-05-05 14:30:26.371,3634,3619,3628,3629,-14838,-14839,-14842,-14841,33.3,33.9,33.4,32.3,27
    2025-05-05 14:30:31.567,3633,3618,3627,3629,-14838,-14844,-14845,-14843,33.3,33.9,33.5,32.3,27
    2025-05-05 14:30:36.391,3631,3616,3627,3628,-14842,-14842,-14847,-14843,33.4,34.0,33.5,32.4,27
    2025-05-05 14:30:41.406,3630,3615,3626,3627,-14844,-14841,-14844,-14843,33.4,34.1,33.5,32.4,27
    2025-05-05 14:30:46.420,3630,3613,3625,3626,-14844,-14841,-14840,-14843,33.4,34.1,33.6,32.4,26
    2025-05-05 14:30:51.614,3628,3612,3624,3626,-14841,-14844,-14844,-14846,33.5,34.2,33.7,32.6,26
    2025-05-05 14:30:56.435,3627,3611,3623,3624,-14845,-14841,-14840,-14846,33.5,34.3,33.7,32.5,26
    2025-05-05 14:31:01.435,3626,3609,3622,3624,-14844,-14842,-14842,-14846,33.6,34.4,33.8,32.5,25
    2025-05-05 14:31:06.447,3625,3608,3621,3623,-14847,-14846,-14842,-14845,33.6,34.4,33.9,32.5,25
    2025-05-05 14:31:11.646,3624,3607,3620,3622,-14847,-14846,-14848,-14854,33.7,34.5,33.9,32.5,25
    2025-05-05 14:31:16.460,3623,3605,3619,3621,-14844,-14848,-14846,-14844,33.8,34.5,34.0,32.6,24
    2025-05-05 14:31:21.466,3621,3604,3618,3620,-14843,-14846,-14847,-14843,33.8,34.5,34.0,32.7,24
    2025-05-05 14:31:26.466,3620,3603,3617,3619,-14850,-14848,-14847,-14843,33.9,34.6,34.1,32.7,24
    2025-05-05 14:31:31.678,3619,3601,3616,3618,-14848,-14849,-14847,-14850,33.9,34.7,34.1,32.8,23
    2025-05-05 14:31:36.490,3617,3600,3615,3617,-14852,-14850,-14851,-14852,33.9,34.7,34.2,32.8,23
    2025-05-05 14:31:41.497,3616,3599,3614,3616,-14850,-14849,-14851,-14850,34.0,34.8,34.3,32.8,23
    2025-05-05 14:31:46.504,3615,3597,3613,3615,-14850,-14847,-14849,-14847,34.0,34.8,34.4,32.8,22
    2025-05-05 14:31:51.747,3613,3596,3612,3614,-14850,-14847,-14853,-14847,34.1,34.9,34.4,32.8,22
    2025-05-05 14:31:56.530,3612,3595,3611,3612,-14849,-14855,-14847,-14852,34.2,34.9,34.4,32.8,22
    2025-05-05 14:32:01.534,3610,3593,3610,3611,-14852,-14854,-14850,-14851,34.2,35.0,34.5,32.9,21
    2025-05-05 14:32:06.545,3609,3592,3608,3610,-14852,-14853,-14853,-14853,34.3,35.1,34.5,32.8,21
    2025-05-05 14:32:11.771,3607,3590,3607,3609,-14854,-14852,-14852,-14855,34.3,35.1,34.6,32.9,21
    2025-05-05 14:32:16.553,3606,3589,3606,3608,-14855,-14854,-14854,-14850,34.3,35.2,34.7,33.0,21
    2025-05-05 14:32:21.560,3604,3587,3605,3606,-14848,-14854,-14855,-14853,34.3,35.2,34.7,33.2,20
    2025-05-05 14:32:26.572,3603,3585,3604,3605,-14850,-14853,-14858,-14851,34.4,35.2,34.8,33.1,20
    2025-05-05 14:32:31.824,3601,3583,3602,3604,-14854,-14853,-14851,-14855,34.4,35.4,34.9,33.1,19
    2025-05-05 14:32:36.586,3600,3581,3601,3602,-14855,-14856,-14855,-14856,34.5,35.4,34.9,33.2,19
    2025-05-05 14:32:41.602,3598,3579,3600,3601,-14855,-14853,-14850,-14855,34.5,35.4,35.0,33.3,19
    2025-05-05 14:32:46.616,3596,3577,3599,3599,-14855,-14857,-14852,-14852,34.7,35.5,35.0,33.3,19
    2025-05-05 14:32:51.873,3595,3574,3597,3598,-14857,-14858,-14857,-14857,34.7,35.5,35.1,33.3,18
    2025-05-05 14:32:56.623,3593,3572,3596,3596,-14855,-14853,-14856,-14860,34.7,35.5,35.2,33.4,18
    2025-05-05 14:33:01.637,3591,3569,3595,3594,-14857,-14855,-14857,-14858,34.7,35.6,35.2,33.5,18
    2025-05-05 14:33:06.651,3589,3566,3593,3593,-14857,-14855,-14856,-14855,34.7,35.7,35.3,33.6,17
    2025-05-05 14:33:11.925,3587,3563,3592,3591,-14857,-14856,-14860,-14858,34.7,35.7,35.4,33.6,17
    2025-05-05 14:33:16.668,3586,3559,3590,3589,-14858,-14855,-14859,-14858,34.7,35.8,35.4,33.6,17
    2025-05-05 14:33:21.672,3584,3556,3589,3587,-14860,-14857,-14856,-14855,34.9,35.9,35.4,33.6,16
    2025-05-05 14:33:26.677,3581,3551,3587,3585,-14857,-14860,-14856,-14859,34.9,35.9,35.5,33.7,16
    2025-05-05 14:33:31.968,3579,3547,3586,3583,-14857,-14860,-14861,-14856,35.0,35.9,35.6,33.8,16
    2025-05-05 14:33:36.702,3577,3542,3584,3582,-14855,-14860,-14860,-14860,35.0,36.0,35.6,33.9,15
    2025-05-05 14:33:41.713,3575,3537,3583,3580,-14857,-14862,-14861,-14859,35.0,36.1,35.6,33.9,15
    2025-05-05 14:33:46.720,3572,3531,3580,3577,-14855,-14860,-14865,-14861,35.2,36.1,35.7,33.8,15
    2025-05-05 14:33:52.011,3569,3524,3578,3574,-14861,-14863,-14862,-14860,35.2,36.2,35.8,33.7,14
    2025-05-05 14:33:56.739,3566,3517,3576,3572,-14857,-14862,-14861,-14857,35.2,36.2,35.9,33.8,14
    2025-05-05 14:34:01.740,3563,3509,3574,3570,-14859,-14860,-14863,-14861,35.1,36.2,35.9,33.8,14
    2025-05-05 14:34:06.745,3559,3501,3572,3566,-14862,-14860,-14865,-14862,35.1,36.3,36.0,33.9,13
    2025-05-05 14:34:12.046,3556,3491,3570,3563,-14868,-14859,-14862,-14865,35.2,36.4,36.0,33.8,13
    2025-05-05 14:34:16.770,3552,3482,3567,3560,-14866,-14859,-14863,-14863,35.2,36.4,36.1,33.8,13
    2025-05-05 14:34:21.776,3547,3471,3565,3557,-14859,-14855,-14860,-14860,35.2,36.5,36.1,33.9,12
    2025-05-05 14:34:26.782,3543,3460,3562,3554,-14861,-14860,-14863,-14868,35.2,36.6,36.2,33.9,12
    2025-05-05 14:34:32.108,3538,3448,3559,3549,-14865,-14869,-14864,-14866,35.4,36.6,36.2,34.0,12
    2025-05-05 14:34:36.797,3533,3435,3555,3546,-14871,-14862,-14864,-14863,35.4,36.7,36.3,34.1,12
    2025-05-05 14:34:41.799,3528,3422,3552,3542,-14868,-14871,-14864,-14868,35.4,36.7,36.4,34.2,11
    2025-05-05 14:34:46.812,3523,3407,3548,3537,-14866,-14865,-14864,-14868,35.5,36.8,36.4,34.2,11
    2025-05-05 14:34:52.172,3517,3392,3544,3533,-14869,-14871,-14868,-14867,35.6,36.8,36.5,34.2,11
    2025-05-05 14:34:56.822,3511,3377,3540,3528,-14867,-14871,-14869,-14869,35.6,36.9,36.5,34.4,10
    2025-05-05 14:35:01.829,3505,3361,3535,3523,-14867,-14869,-14870,-14868,35.4,37.0,36.5,34.5,10
    2025-05-05 14:35:06.838,3498,3344,3530,3518,-14867,-14869,-14873,-14869,35.4,37.0,36.6,34.5,10
    2025-05-05 14:35:12.188,3491,3325,3526,3513,-14869,-14870,-14875,-14868,35.4,37.1,36.6,34.4,9
    2025-05-05 14:35:16.863,3484,3307,3520,3507,-14871,-14873,-14877,-14867,35.4,37.1,36.7,34.4,9
    2025-05-05 14:35:21.875,3476,3287,3514,3502,-14869,-14874,-14875,-14870,35.5,37.2,36.7,34.4,9
    2025-05-05 14:35:26.881,3468,3265,3509,3496,-14872,-14872,-14873,-14871,35.6,37.3,36.8,34.4,8
    2025-05-05 14:35:32.214,3460,3241,3502,3491,-14868,-14874,-14870,-14873,35.6,37.3,36.8,34.5,8
    2025-05-05 14:35:36.903,3451,3218,3496,3485,-14873,-14872,-14874,-14873,35.7,37.4,36.9,34.5,8
    2025-05-05 14:35:41.909,3442,3191,3490,3479,-14869,-14874,-14873,-14879,35.8,37.5,37.0,34.6,8
    2025-05-05 14:35:46.918,3433,3162,3483,3473,-14869,-14873,-14874,-14878,35.8,37.5,37.0,34.5,7
    2025-05-05 14:35:52.230,3423,3128,3475,3466,-14874,-14873,-14872,-14875,35.9,37.5,37.0,34.5,7
    2025-05-05 14:35:56.941,3413,3094,3468,3460,-14873,-14872,-14872,-14876,35.9,37.6,37.1,34.4,7
    2025-05-05 14:36:01.948,3403,3052,3460,3454,-14874,-14875,-14872,-14874,35.9,37.6,37.1,34.4,6
    2025-05-05 14:36:06.953,3392,3004,3452,3447,-14875,-14873,-14871,-14877,36.0,37.7,37.1,34.4,6
    2025-05-05 14:36:12.281,3379,2941,3443,3440,-14873,-14876,-14872,-14875,36.1,37.7,37.1,34.5,6
    2025-05-05 14:36:16.961,3368,2867,3435,3434,-14875,-14872,-14879,-14877,36.0,37.8,37.2,34.5,6
    2025-05-05 14:36:21.964,3355,2746,3426,3426,-14875,-14870,-14877,-14874,36.0,37.8,37.2,34.5,5
    2025-05-05 14:36:26.976,3372,2701,3437,3436,-13928,-13923,-13922,-14612,36.0,37.8,37.3,34.6,0
    2025-05-05 14:36:32.347,3394,2614,3475,3479,-249,-227,-44,-50,36.0,37.9,37.3,34.7,0
    2025-05-05 14:36:36.990,,,,,,,,,,,,,
    2025-05-05 14:36:41.996,3397,2572,3484,3489,0,0,0,0,35.9,37.9,37.3,34.6,0
    2025-05-05 14:36:47.001,3408,2653,3494,3500,0,0,0,0,36.0,37.9,37.3,34.5,0
    2025-05-05 14:36:52.388,3381,2421,3468,3474,-3715,-3707,-930,-935,36.1,37.9,37.3,34.5,0
    2025-05-05 14:36:57.017,3404,2598,3493,3499,0,0,0,0,36.0,37.9,37.3,34.5,0
    2025-05-05 14:37:02.030,3352,2379,3440,3444,-14643,-14641,-14643,-14639,36.0,38.0,37.3,34.7,0
    2025-05-05 14:37:07.038,3397,2537,3490,3496,0,0,0,0,36.0,38.0,37.2,34.5,0
    2025-05-05 14:37:12.404,3403,2583,3497,3502,-18,-1,7,9,36.0,38.0,37.2,34.5,0
    2025-05-05 14:37:17.052,3405,2612,3499,3506,0,0,0,0,35.9,38.0,37.1,34.4,0
    After:
    parameters_after.gg.csv
    Mon May 05 14:38:25 CEST 2025
    1,2025-05-05 14:38:30,4.011,0x050B,300,10,0x6000,0,0,0,0,37.7,13216,0,0,100,0,0,0,8000,0,0,0,0,16000,0x0040,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0x058B,0x0000,0x10,0x0201,0x55,0x0014,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3425,2751,3522,3528,13241,12782,-20,-15,-3,-10,-7,-4,-1,-4,-9,0,40.2,35.0,37.5,36.6,33.8,37.5,40.2,33.8,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,342.5,275.1,352.2,352.8,3424,2749,3520,3527,-15,-15,-6,14,33.8,-200,-296,6577,10079,0,-200,-296,6777,10375,6577,10079,33.8,33.8,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,1,16026,16384,15932,15911,0,0,0,2448,2240,2080,1296,8178,8178,8178,8178,0,0,0,0,0,0,0.5,1051,16026,16384,15932,15911,0,0,0,0,0,0,0,0,0,0x00,7399,10968,0,0,2136,SUCCESS
    2,2025-05-05 14:38:34,8.026,0x058B,300,10,0x6000,0,65535,65535,0,37.5,13226,-14,-1,1,0,0,0,6577,0,0,65535,80,16600,0x03D0,1,0,0,0,0,0,0,0,-99,3422,2920,3519,3525,13385,13385,7,13,6,5,31,31,-32767,-9330,-32767,-32767,-32767,-32767,28,92,0x058B,0x0000,0x10,0x0001,0x55,0x0014,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3424,2755,3521,3527,13243,12767,-32,-2,6,-3,-11,-1,2,-1,-20,-3,40.2,35.0,37.5,36.6,33.8,37.5,40.2,33.8,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,342.4,275.4,352.1,352.8,3424,2749,3520,3527,-16,-14,-5,13,33.8,-200,-296,6577,10079,0,-200,-296,6777,10375,6577,10079,33.8,33.8,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,5,16026,16384,15932,15911,0,0,0,2448,2240,2080,1296,8178,8178,8178,8178,0,0,0,0,0,0,0.5,1051,16026,16384,15932,15911,0,0,0,0,0,0,0,0,0,0x00,7399,10968,0,0,2129,SUCCESS
    3,2025-05-05 14:38:38,12.030,0x058B,300,10,0x6000,0,65535,65535,0,37.4,13231,-15,-5,1,0,0,0,6577,0,0,65535,80,16600,0x03D0,1,0,0,0,0,0,0,0,-99,3422,2920,3519,3525,13385,13385,7,13,6,5,31,31,-32767,-9330,-32767,-32767,-32767,-32767,28,92,0x2589,0x0000,0x10,0x0001,0x55,0x0014,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3425,2758,3522,3528,13249,2792,-13,5,5,9,-4,1,2,3,-8,-7,40.0,34.9,37.4,36.5,33.7,37.4,40.0,33.7,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,342.5,275.8,352.2,352.8,3424,2750,3520,3527,-17,-14,-5,12,33.8,-200,-296,6577,10079,0,-200,-296,6777,10375,6577,10079,33.8,33.7,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,8,16026,16384,15932,15911,0,0,0,2448,2240,2080,1296,8178,8178,8178,8178,0,0,0,0,0,0,0.5,1051,16026,16384,15932,15911,
    FW_after.zip
    And after charging and reset (I do reset to see if there is an update of SoH. SoH is 92%, no change.
    (SoC will pass 96% to 100% after reset)
    0827.charging.log
    after_charging.gg.csv
    Mon May 05 19:12:12 CEST 2025
    1,2025-05-05 19:12:17,4.007,0x0107,300,10,0x6000,0,65535,65535,1,26.1,16336,0,0,1,100,85,6741,6741,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4078,4079,4098,4080,16333,16333,3,3,3,3,12,12,-32767,-32767,-32767,-32767,-32767,-32767,11,92,0x0107,0x0000,0x08,0x0008,0x52,0x0014,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4078,4080,4099,4081,16324,16374,0,0,0,0,0,0,0,0,0,0,27.0,25.5,26.0,26.1,25.4,26.1,27.0,25.4,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,407.8,408.0,409.9,408.0,4078,4079,4098,4080,-14,-2,7,10,25.4,7060,10787,6741,10269,7260,7060,10787,-319,-518,6741,10269,25.4,25.4,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,61,1840,1824,1456,1792,0,0,0,2480,2256,2096,1328,8178,8178,8178,8178,0,0,0,0,0,0,0.5,1051,1840,1824,1456,1792,0,0,0,0,0,0,0,0,0,0x00,7399,10968,0,0,2113,SUCCESS
    2,2025-05-05 19:12:21,8.009,0x0107,300,10,0x6000,0,65535,65535,1,26.0,16336,0,0,1,100,85,6741,6741,65535,65535,65535,4000,16400,0x00E0,1,0,0,0,0,0,0,0,-99,4078,4079,4098,4080,16333,16333,3,3,3,3,12,12,-32767,-32767,-32767,-32767,-32767,-32767,11,92,0x0107,0x0000,0x08,0x0008,0x52,0x0014,0x01F8,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4078,4079,4099,4082,16324,16375,0,0,0,0,0,0,0,0,0,0,26.8,25.5,26.0,26.0,25.4,26.0,26.8,25.4,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,-273.2,407.8,407.9,410.0,408.1,4078,4079,4098,4080,-14,-2,7,10,25.4,7060,10787,6741,10269,7260,7060,10787,-319,-518,6741,10269,25.4,25.4,1000,1000,1000,1000,0,0,0,0,0,0x06,0,0,0,0,65,1840,1824,1456,1792,0,0,0,2480,2256,2096,1328,8178,8178,8178,8178,0,0,0,0,0,0,0.5,1051,1840,1824,1456,1792,0,0,0,0,0,0,0,0,0,0x00,7399,10968,0,0,2019,SUCCESS
    FW_after_charging.zip
    What should I do next?
    Regarding the average current parameter for the SOH rate, given that the BMU is mainly in standby mode with occasional wake-ups to control a motor, how should this average current be defined:
    - over the entire standby + activity period, but it will then be close to 0
    - over a functional cycle only, so a few amps but over a few seconds
    - or something in between?
    CM
  • Hi Cedric,
    Thanks for sending these files, it seems like there was no change to the SOH FCC Max parameters in this case. Regarding the charge, was this able to reach Valid Charge Termination? This is how the device classifies the OCV measurement taken prior to the charge is at the end of charge, which would also ensure the maximum amount of passed charge is being seen.
    Regarding the SOH Load Rate, this should be the average of the discharge in the functional cycle. The standby period should not be added.
    Anthony
    From what I understand, the expected result with SOH_LEARN didn't have the desired effect. So, what should I do?
    In the previous message, you seemed to suggest directly setting the initial SoH with the HOST. Can you clarify?
    Regarding the charge, here's the log. At the end, the current was almost zero; we can consider the charge complete.
    charging_log.xlsx
    OCV (Open Circuit Voltage), or the idle voltage, isn't quite at its maximum (20mV remains on the weakest cell), but in this case, after the reset, this voltage is unchanged, and the SoC is miscalculated.
    This SoC variability is apparently independent of the SoH.
    Okay for the SoH load rate, but this only applies to the future "life" of the SoH degradation, apparently independent of the initial state, which is currently the problem to be resolved.
    So, what next?
    CM
  • Hi Cedric,
    My apologies, the SOH FCC Max should only update to a different value if the SOH FCC calculated is greater than the value in that register at this time, which in this case is the design capacity. Maybe we could try setting this to a lower value (around where the FCC value is at this time) to see if this can report SOH initially?
    My concern with the charge is that VCT is not being hit, meaning the gauge is not observing the full capacity of the cell, which can have an effect on the FCC calculation. If 100% is not being hit, the gauge might be overestimating the capacity at this time. The conditions for VCT can be found below, where we can look into the sent charge file:
    Anthony
    The fact that a charge occasionally doesn't immediately achieve 100% SoC isn't a cause of SoH loss because the SoH has been abnormal from the start.
    Here, I had 97% SoC because there was a small imbalance in one cell, and it was certainly necessary to wait for balancing, which can last several days and cycles.
    The maximum SoH FCC is an initial problem. At worst, with a degraded SoC, the SoH could also degrade; this was the main reason why this observation should be analyzed.
    So, to return to the initial problem, it's a matter of setting the initial SoH to 100% and therefore understanding the FCC problem.
    In a previous message, you seemed to suggest directly setting the initial SoH with the HOST. Can you clarify?
    ------------------update-------
    Today, I assembled a new board with a blank chip, a new prototype with hardware improvements.
    I created a "golden" file with 1189 chemistry and generated an SREC.
    I do "clean" of parameters file before doing golden file
    I didn't use any cells, just a lab power supply to simulate the cells.
    With 4V per cell, this gives a 78% SoC (consistent), but despite my FCC setting, I still have an initial SoH of 90%.
    Here are the registers live and those I identified as suspect, so we need to analyze them.
    I really don't know what to do or where to look anymore... What do you think? (I added the SREC file)
    r5_250508.zip
    CM
  • Hi Cedric,
    Regarding this, this solution would not be to directly change the SOH within the gauge by the host, but to have the host accommodate as in seeing the 93% as 100%, then incrementing down with the read.
    I understand that a lab power supply is being used here, however I think we need to have the gauge observe at least 8000mAh of passed charge during charge or discharge for it to create the correct FCC.
    Based on the previously sent 0827.charging.log file, from 0% to 97%, the gauge is only seeing ~6500mAh of passed charge, which could be affecting the measurement. When actual cells are used, is there any difference in this or has the lab power supply only been used here?
    Anthony
    1) How do you want to make chip believe that a 100% SoH is achieved from 93%? I don't understand how you're trying to do this.
    2) My last test with the lab power supply consisted of powering up a new board (simply) with a new firmware/settings.
    This is to verify that the initial state starts at 100% SoH, but I only got 90%, which shows that there's something inconsistent somewhere. In any case, when assembling a pack, the (new) cells are never charged to 100% (SoC), so this textbook case is completely normal.
    Having already built BMUs with this chip in other battery formats and chemistries, the SoH always starts at 100% (which seems logical), even with initially partially charged or unbalanced cells. The initial state of the SoC is independent of the SoH. The "life" (evolution) of the SoC can eventually impact the SoH (which degrades it), but here the goal is to resolve the initial SoH. In other words, the BMU cannot "anticipate" an SoH <100% when it is first programmed, otherwise it would be magic!
    There is likely a problem defining the initial conditions.
    I suspect that with the chemistry used and the mAh values ​​higher than the "usual" settings, the FW has a bug. With the source code at your disposal, can you trace the initial SoH calculation to determine what leads to not obtaining 100% SoH?
    CM
  • Hello Cedric,
    We have received your update and are working on the trend.
    Thank you,
    Alan
  • Hi Cedric,
    I was able to discuss this with our team, where they defined the FCC_SOH as a " a function of charge termination, Terminate Voltage, SOH load current and SOH thermal model. This can be less than Design Capacity, even for a brand new cell, for example, if the charger is configured to not charge to DOD ​< 10% or if discharge terminates for DOD < 90%."
    I agree with your statement that there is something off going on at the initialization. We can look into the code, however were there any changes to any of the charging parameters when compared to the learning cycle used to create the golden learning?
    Would it be possible to share the learning cycle log and .gg if you have them available?
    Anthony
    Thank you for these clarifications.
    I just ran a thorough parameter check again to see if there were any inconsistencies. I didn't see anything unusual.
    I reread the SLUA848 document to check the Term taper, DSG/CHG threshold, quit current, term, and also the charger control levels (according to the stages).
    For all the tests done so far, I hadn't changed the charging parameters.
    For this test, I made a few adjustments, which I consider minor. These are adjustments to the voltage thresholds at the limits, during charging or discharging.
    However, it's important to differentiate between:
    - RSOC
    - ASOC
    - SOH
    Here, my RSOC is lower than ASOC; I'm keeping some margin at the limits to improve cell lifespan. I assume the SoH takes this into account. The SoH shouldn't be dependent on the RSOC. As its name suggests, SOH provides the health status, not the capacity status. The capacity is intentionally reduced, and this shouldn't have an impact on health.
    For example, a "new" cell operating at 80% capacity should still have an initial health status of 100% even if it isn't fully discharged.
    However, I just ran a complete discharge/charge cycle from 100%, after correcting some settings.
    I topped up the battery initially to start at 100% RSOC. I waited 2 hours before starting a full discharge.
    I have to restart the logs because BqStudio crashed and I couldn't save. The software is quite unstable; at the slightest communication problem with the card, it crashes; it's very annoying. For now, I can only provide you with the settings file.
    r5_250513.gg.csv
    A quick, cross-cutting, and unrelated question:
    In BqStudio, how do I save a watch window? Every time I want to log, I have to redo the entire list of variables. I can't find any buttons or menus, but maybe there's a hidden way with a file conveniently located in the executable directory?
    CM
    Here are the discharge and charge logs.
    What were you waiting for?
    BMU3_discharge_5A.log
    discharging_log.xlsx
    3782.charge.log
    7506.charging_log.xlsx
    After running the cycles, I didn't immediately see the SoH change. It was only after performing a reset that I noticed it had gone from 90% to 97%, so changing the charge and discharge thresholds (for the exploited depth of use) did have an impact.
    Since a voluntary reset was required, the calculation seems to be done at initialization.
    This is already better, but to return to my point in the previous post, the initial SoH shouldn't be dependent on the RSOC.
    CM
  • Hello Cedric,
    Anthony is currently out of the office and we ask to give time till late next week for a response. Sorry for any inconvenience this may cause.
    Thank you,
    Alan
  • Hi Cedric,
    Sorry for the delay, regarding the statement below, the SOH and SOC calculations are independent of each other, running different simulations to create the SOH_FCC and normal FCC values for their calculations. The normal FCC simulation is dictated by the IT Algorithm, while the SOH_FCC is a simulation based on a constant current load set by SOH Load Rate at 25degC.
    Looking into the code for the calculation and simulation, it seems heavily dependent on the DOD at EOC value, which is the DOD calculation done based on the OCV measurement taken once the gauge hits Valid Charge Termination.
    The code also confirms that this will be re-simulated upon initialization, and when Qmax and Ra table updates occur. Since this is being done at initialization (and if the gauge has just been programmed) I believe the DOD at EOC it is using is from the learning cycle. Is it possible to confirm that VCT was correctly met during the learning cycle?
    Anthony
    Regarding FCC, regardless of the method, I don't see any configuration issues.
    I've already accumulated a lot of practical tests and configuration changes, so I'm going around in circles because if there were something obvious, we would have already seen it.
    Having already performed complete charge and discharge cycles, learning cycles, and total reprogramming several times, the DoD and VCT indicators have already matched.
    With all the data I've sent you, you can't identify the key parameters that allow for proper initialization?
    Without knowing what to do, it's way too complicated. There seems to be no documentation on this subject, and we could spend weeks on it...it's gone on too long.
    Can you clearly tell me the parameters directly related to SoH initialization?
    There must be documentation with calculation notes describing the FCC and SOH algorithms.
    Thank you.
    CM
  • Hello Cedric,
    We will continue to work on your question, today is a national holiday, Memorial Day.
    Thank you,
    Alan
    While waiting for your response, I've been trying to go through all the procedures one by one over the last few days to see if I've missed anything.
    I used several platforms:
    - a new pack on a new board
    - reset existing packs (flash srec, no lifetime)
    Then, I redid (according to the VOK, REST, QMAX, FC, FD bits, the 5-hour wait times...):
    - charge/discharge cycle
    - learning cycle
    - parameter recording, adjust some parameters to try...
    - logs
    Nothing has changed, the SoH remains desperately at 97% at best.
    The only thing I haven't been able to do is the Ra table optimization with GPC Maker.
    Not knowing if it was related, I wanted to try it. I systematically get a report error where it seems the flags are not the expected ones (0xFFFF or 0xFF55), but I don't know why. I've repeated the tests several times. The operation of these flags is not specified (notably the GPC guide sluubc9). Do they have to be written beforehand at 0xFFFF or is it the result of an internal and automatic operation, therefore dependent on other conditions?
    CM
  • Hi Cedric,
    I apologize for the delay, regarding these topics:
    - learning cycle
    - logs
    Do you have any log files from the learning cycle completed above? I would like to look into the total amount of capacity that the gauge is learning during this process.
    These flags are used in the resistance update, where their definition can be found below. What value are these attempting to be changed to, and is this being done before or after the learning cycle? My thought is that since the gauge has maybe not updated these values yet, it does not want the flags changed.
    Anthony
    1) logs
    I've made logs for GPC Maker, I don't know if it contains the information you want. What data do you want in the log (to redo it)?
    TimeStamp,Cell1Voltage,Cell2Voltage,Cell3Voltage,Cell4Voltage,Cell1Current,Cell2Current,Cell3Current,Cell4Current,TS1Temperature,TS2Temperature,TS3Temperature,TS4Temperature,RelativeStateofCharge
    2025-05-27 14:32:45.003,4145,4142,4147,4143,0,0,0,0,26.2,26.0,26.2,26.0,96
    2025-05-27 14:32:50.138,4145,4142,4148,4143,0,0,0,0,26.2,26.0,26.2,26.0,96
    2025-05-27 14:32:55.026,4097,4099,4092,4090,-10542,-10537,-10541,-10537,26.2,26.0,26.2,26.0,96
    2025-05-27 14:33:00.039,4086,4088,4082,4080,-10548,-10548,-10551,-10544,26.2,26.0,26.2,26.0,96
    2025-05-27 14:33:05.048,4080,4082,4075,4073,-10554,-10553,-10559,-10553,26.2,26.0,26.2,26.0,96
    2025-05-27 14:33:10.216,4076,4078,4071,4069,-10558,-10557,-10557,-10560,26.3,26.0,26.2,26.1,96
    2025-05-27 14:33:15.069,4072,4074,4067,4065,-10561,-10563,-10563,-10561,26.3,26.0,26.2,26.1,96
    2025-05-27 14:33:20.074,4069,4071,4064,4064,-10566,-10569,-10564,-10563,26.3,26.0,26.2,26.1,95
    2025-05-27 14:33:25.088,4067,4069,4062,4062,-10569,-10569,-10564,-10566,26.3,26.0,26.2,26.2,95
    2025-05-27 14:33:30.279,4065,4067,4059,4058,-10573,-10568,-10569,-10566,26.4,26.1,26.2,26.2,95
    2025-05-27 14:33:35.103,4062,4064,4057,4057,-10573,-10572,-10572,-10575,26.3,26.1,26.3,26.2,95
    2025-05-27 14:33:40.112,4060,4062,4055,4055,-10577,-10574,-10572,-10578,26.4,26.1,26.3,26.2,95
    2025-05-27 14:33:45.121,4058,4060,4053,4053,-10578,-10580,-10578,-10581,26.4,26.1,26.3,26.3,94
    2025-05-27 14:33:50.313,4057,4058,4051,4049,-10577,-10579,-10577,-10575,26.5,26.2,26.3,26.3,94
    2025-05-27 14:33:55.132,4054,4056,4049,4049,-10579,-10581,-10584,-10579,26.5,26.2,26.3,26.3,94
    2025-05-27 14:34:00.140,4052,4054,4047,4047,-10580,-10581,-10587,-10580,26.6,26.2,26.4,26.4,94
    2025-05-27 14:34:05.149,4050,4052,4045,4045,-10584,-10587,-10584,-10585,26.6,26.2,26.4,26.4,94
    2025-05-27 14:34:10.346,4048,4051,4044,4042,-10586,-10589,-10582,-10585,26.6,26.2,26.4,26.4,93
    2025-05-27 14:34:15.158,4046,4048,4041,4041,-10594,-10589,-10585,-10587,26.7,26.3,26.4,26.5,93
    2025-05-27 14:34:20.166,4044,4046,4040,4039,-10593,-10583,-10587,-10589,26.6,26.3,26.5,26.5,93
    2025-05-27 14:34:25.172,4043,4044,4038,4037,-10595,-10588,-10589,-10593,26.7,26.3,26.5,26.5,93
    2025-05-27 14:34:30.407,4041,4043,4036,4035,-10585,-10593,-10590,-10590,26.7,26.3,26.5,26.6,93
    2025-05-27 14:34:35.189,4039,4041,4034,4034,-10592,-10591,-10595,-10594,26.8,26.3,26.5,26.6,92
    2025-05-27 14:34:40.194,4037,4039,4032,4032,-10592,-10595,-10591,-10593,26.8,26.4,26.5,26.7,92
    2025-05-27 14:34:45.203,4035,4037,4030,4030,-10590,-10593,-10595,-10593,26.9,26.4,26.6,26.7,92
    2025-05-27 14:34:50.453,4033,4036,4028,4027,-10591,-10595,-10592,-10596,26.9,26.4,26.6,26.7,92
    2025-05-27 14:34:55.215,4032,4033,4026,4026,-10596,-10600,-10592,-10596,26.9,26.4,26.6,26.8,92
    2025-05-27 14:35:00.216,4030,4032,4025,4025,-10593,-10600,-10594,-10593,26.9,26.5,26.7,26.8,91
    2025-05-27 14:35:05.229,4028,4030,4023,4023,-10594,-10598,-10596,-10596,27.0,26.5,26.7,26.8,91
    2025-05-27 14:35:10.513,4027,4028,4021,4020,-10588,-10587,-10593,-10597,27.0,26.5,26.7,26.9,91
    2025-05-27 14:35:15.248,4025,4026,4019,4021,-10591,-10593,-10600,-10603,27.1,26.4,26.7,26.9,91
    2025-05-27 14:35:20.260,4023,4025,4018,4018,-10592,-10596,-10599,-10599,27.1,26.5,26.7,27.0,91
    2025-05-27 14:35:25.269,4021,4023,4016,4016,-10597,-10599,-10591,-10600,27.1,26.6,26.8,27.0,90
    2025-05-27 14:35:30.578,4020,4022,4014,4013,-10601,-10597,-10599,-10600,27.2,26.6,26.8,27.0,90
    2025-05-27 14:35:35.283,4018,4020,4012,4013,-10597,-10599,-10600,-10598,27.2,26.6,26.8,27.1,90
    2025-05-27 14:35:40.291,4017,4019,4011,4011,-10600,-10598,-10599,-10595,27.3,26.6,26.8,27.1,90
    2025-05-27 14:35:45.295,4015,4017,4009,4010,-10600,-10594,-10596,-10601,27.4,26.7,26.8,27.1,90
    2025-05-27 14:35:50.640,4014,4016,4008,4007,-10600,-10596,-10606,-10600,27.4,26.7,26.9,27.2,89
    2025-05-27 14:35:55.311,4013,4015,4006,4008,-10602,-10598,-10601,-10604,27.4,26.7,26.9,27.2,89
    2025-05-27 14:36:00.316,4011,4014,4005,4006,-10607,-10598,-10603,-10606,27.5,26.8,26.9,27.2,89
    2025-05-27 14:36:05.325,4010,4012,4004,4005,-10605,-10603,-10605,-10596,27.5,26.8,27.0,27.3,89
    2025-05-27 14:36:10.706,4009,4011,4003,4003,-10599,-10602,-10605,-10608,27.6,26.8,27.0,27.4,89
    2025-05-27 14:36:15.338,4008,4010,4001,4002,-10602,-10603,-10600,-10606,27.6,26.8,27.0,27.4,89
    2025-05-27 14:36:20.347,4007,4009,4000,4002,-10602,-10607,-10598,-10613,27.5,26.8,27.0,27.4,88
    2025-05-27 14:36:25.358,4005,4008,3999,4000,-10604,-10606,-10603,-10604,27.7,26.8,27.1,27.5,88
    2025-05-27 14:36:30.705,4004,4006,3998,3998,-10606,-10605,-10603,-10609,27.6,26.9,27.1,27.5,88
    2025-05-27 14:36:35.379,4003,4005,3997,3999,-10610,-10612,-10604,-10617,27.7,26.8,27.0,27.6,88
    2025-05-27 14:36:40.388,4002,4004,3995,3996,-10608,-10610,-10606,-10604,27.8,26.9,27.2,27.6,88
    2025-05-27 14:36:45.397,4000,4002,3994,3995,-10608,-10607,-10609,-10608,27.8,27.0,27.1,27.7,87
    2025-05-27 14:36:50.779,4000,4002,3993,3993,-10613,-10612,-10612,-10613,27.8,26.9,27.2,27.7,87
    2025-05-27 14:36:55.409,3997,3999,3991,3992,-10609,-10610,-10607,-10606,27.9,27.0,27.3,27.8,87
    2025-05-27 14:37:00.419,3996,3997,3990,3990,-10610,-10608,-10614,-10606,28.0,27.1,27.4,27.8,87
    2025-05-27 14:37:05.426,3994,3995,3988,3988,-10610,-10611,-10614,-10604,28.0,27.1,27.4,27.9,87
    2025-05-27 14:37:10.432,3992,3993,3987,3987,-10610,-10606,-10618,-10613,28.0,27.0,27.4,27.9,86
    2025-05-27 14:37:15.441,3990,3991,3985,3984,-10611,-10610,-10612,-10609,28.1,27.1,27.4,27.9,86
    2025-05-27 14:37:20.449,3988,3988,3983,3981,-10607,-10613,-10610,-10609,28.1,27.2,27.5,28.0,86
    2025-05-27 14:37:25.461,3986,3986,3981,3979,-10612,-10614,-10610,-10612,28.2,27.2,27.5,28.0,86
    2025-05-27 14:37:30.465,3983,3983,3979,3976,-10617,-10615,-10615,-10621,28.1,27.1,27.5,28.1,86
    2025-05-27 14:37:35.478,3981,3981,3977,3974,-10621,-10616,-10616,-10620,28.2,27.1,27.5,28.1,85
    2025-05-27 14:37:40.487,3978,3978,3974,3971,-10621,-10613,-10619,-10623,28.2,27.2,27.5,28.1,85
    2025-05-27 14:37:45.493,3976,3975,3972,3969,-10610,-10609,-10613,-10615,28.3,27.4,27.7,28.1,85
    2025-05-27 14:37:50.499,3973,3972,3969,3967,-10612,-10609,-10615,-10613,28.3,27.4,27.6,28.2,85
    2025-05-27 14:37:55.511,3970,3969,3966,3963,-10621,-10616,-10617,-10621,28.3,27.2,27.6,28.2,85
    2025-05-27 14:38:00.522,3967,3967,3964,3960,-10609,-10615,-10617,-10607,28.4,27.4,27.8,28.2,84
    2025-05-27 14:38:05.528,3965,3964,3961,3957,-10612,-10617,-10617,-10621,28.3,27.3,27.8,28.2,84
    2025-05-27 14:38:10.537,3962,3961,3958,3955,-10615,-10616,-10614,-10617,28.5,27.4,27.8,28.3,84
    2025-05-27 14:38:15.545,3959,3958,3955,3952,-10613,-10615,-10612,-10615,28.5,27.5,27.8,28.3,84
    2025-05-27 14:38:20.554,3956,3956,3952,3949,-10615,-10617,-10615,-10615,28.5,27.5,27.8,28.3,84
    2025-05-27 14:38:25.554,3954,3953,3950,3946,-10612,-10621,-10625,-10630,28.4,27.4,27.8,28.3,83
    2025-05-27 14:38:30.563,3951,3951,3947,3944,-10615,-10619,-10615,-10619,28.5,27.5,27.9,28.3,83
    2025-05-27 14:38:35.572,3948,3948,3944,3941,-10615,-10613,-10617,-10628,28.4,27.4,27.8,28.3,83
    2025-05-27 14:38:40.583,3946,3946,3942,3939,-10616,-10620,-10617,-10615,28.5,27.5,27.9,28.3,83
    2025-05-27 14:38:45.588,3943,3944,3939,3937,-10618,-10616,-10620,-10621,28.5,27.5,27.9,28.3,83
    2025-05-27 14:38:50.597,3941,3941,3936,3934,-10621,-10615,-10618,-10617,28.5,27.5,27.8,28.3,82
    2025-05-27 14:38:55.604,3939,3939,3934,3932,-10622,-10615,-10622,-10629,28.4,27.5,27.8,28.3,82
    2025-05-27 14:39:00.613,3936,3937,3932,3930,-10624,-10618,-10622,-10627,28.5,27.4,27.9,28.3,82
    2025-05-27 14:39:05.621,3934,3935,3929,3927,-10623,-10616,-10620,-10629,28.5,27.5,27.9,28.3,82
    2025-05-27 14:39:10.630,3932,3933,3927,3925,-10620,-10620,-10618,-10621,28.5,27.6,27.9,28.3,82
    2025-05-27 14:39:15.637,3930,3931,3925,3923,-10618,-10620,-10624,-10631,28.5,27.5,27.9,28.3,81
    2025-05-27 14:39:20.649,3928,3928,3923,3921,-10620,-10623,-10615,-10620,28.6,27.6,27.9,28.3,81
    2025-05-27 14:39:25.659,3926,3926,3921,3919,-10623,-10623,-10618,-10628,28.5,27.4,27.9,28.4,81
    2025-05-27 14:39:30.664,3924,3925,3918,3917,-10618,-10621,-10621,-10629,28.5,27.5,27.9,28.3,81
    2025-05-27 14:39:35.669,3922,3923,3916,3916,-10620,-10622,-10619,-10633,28.4,27.5,27.9,28.3,81
    2025-05-27 14:39:40.679,3920,3921,3915,3914,-10619,-10624,-10614,-10615,28.5,27.6,27.9,28.3,81
    2025-05-27 14:39:45.684,3919,3920,3913,3912,-10617,-10621,-10615,-10617,28.5,27.6,28.0,28.3,80
    2025-05-27 14:39:50.692,3917,3918,3911,3910,-10616,-10620,-10623,-10630,28.4,27.5,27.9,28.3,80
    2025-05-27 14:39:55.697,3915,3916,3909,3909,-10619,-10617,-10617,-10632,28.5,27.5,27.9,28.2,80
    2025-05-27 14:40:00.698,3914,3915,3907,3907,-10618,-10623,-10622,-10626,28.4,27.5,27.9,28.3,80
    2025-05-27 14:40:05.708,3912,3913,3905,3906,-10621,-10620,-10624,-10628,28.4,27.5,27.9,28.3,80
    2025-05-27 14:40:10.720,3910,3912,3904,3904,-10616,-10621,-10625,-10614,28.6,27.6,28.0,28.3,79
    2025-05-27 14:40:15.722,3909,3910,3902,3902,-10623,-10619,-10623,-10628,28.4,27.5,27.9,28.3,79
    2025-05-27 14:40:20.728,3908,3909,3901,3901,-10620,-10619,-10620,-10622,28.4,27.5,27.9,28.3,79
    2025-05-27 14:40:25.736,3906,3908,3899,3900,-10620,-10618,-10623,-10624,28.6,27.6,27.9,28.3,79
    2025-05-27 14:40:30.738,3905,3906,3898,3898,-10623,-10619,-10622,-10617,28.5,27.6,27.9,28.3,79
    2025-05-27 14:40:35.742,3903,3905,3897,3897,-10622,-10621,-10620,-10633,28.4,27.5,28.0,28.3,78
    2025-05-27 14:40:40.747,3902,3904,3895,3895,-10623,-10619,-10621,-10626,28.4,27.5,27.9,28.3,78
    2025-05-27 14:40:45.758,3901,3903,3894,3895,-10621,-10616,-10618,-10625,28.4,27.4,27.8,28.3,78
    2025-05-27 14:40:50.768,3900,3901,3893,3893,-10619,-10620,-10619,-10633,28.4,27.5,27.9,28.3,78
    2025-05-27 14:40:55.773,3898,3900,3891,3892,-10617,-10619,-10620,-10623,28.5,27.6,27.9,28.2,78
    2025-05-27 14:41:00.782,3897,3899,3890,3891,-10623,-10622,-10619,-10633,28.3,27.5,27.9,28.2,77
    2025-05-27 14:41:05.790,3896,3898,3889,3890,-10626,-10625,-10621,-10622,28.3,27.5,27.8,28.2,77
    2025-05-27 14:41:10.796,3895,3897,3888,3888,-10620,-10622,-10623,-10633,28.3,27.5,27.9,28.2,77
    2025-05-27 14:41:15.808,3894,3896,3887,3887,-10625,-10620,-10619,-10621,28.3,27.4,27.9,28.2,77
    2025-05-27 14:41:20.822,3893,3894,3885,3886,-10622,-10621,-10620,-10637,28.3,27.4,27.8,28.1,77
    2025-05-27 14:41:25.831,3891,3893,3884,3885,-10624,-10617,-10621,-10619,28.3,27.5,27.8,28.1,76
    2025-05-27 14:41:30.836,3890,3892,3883,3884,-10623,-10616,-10620,-10617,28.3,27.4,27.8,28.1,76
    2025-05-27 14:41:35.840,3889,3891,3882,3883,-10620,-10623,-10622,-10634,28.2,27.5,27.9,28.1,76
    2025-05-27 14:41:40.848,3888,3890,3881,3882,-10621,-10623,-10623,-10621,28.3,27.4,27.8,28.1,76
    2025-05-27 14:41:45.854,3887,3888,3880,3880,-10623,-10623,-10623,-10630,28.3,27.4,27.8,28.1,76
    2025-05-27 14:41:50.869,3886,3887,3878,3880,-10624,-10623,-10623,-10619,28.2,27.4,27.8,28.1,75
    2025-05-27 14:41:55.873,3885,3886,3877,3878,-10623,-10622,-10621,-10632,28.2,27.4,27.8,28.0,75
    2025-05-27 14:42:00.881,3883,3885,3876,3877,-10623,-10625,-10620,-10623,28.2,27.4,27.8,28.1,75
    2025-05-27 14:42:05.890,3882,3884,3875,3876,-10625,-10621,-10621,-10635,28.2,27.4,27.7,28.1,75
    2025-05-27 14:42:10.895,3881,3882,3874,3875,-10622,-10621,-10624,-10622,28.2,27.4,27.8,28.1,75
    2025-05-27 14:42:15.899,3880,3881,3872,3873,-10625,-10622,-10621,-10624,28.2,27.4,27.7,28.1,74
    2025-05-27 14:42:20.910,3879,3880,3871,3872,-10625,-10620,-10622,-10620,28.2,27.4,27.8,28.1,74
    2025-05-27 14:42:25.915,3877,3879,3870,3871,-10622,-10617,-10622,-10621,28.2,27.4,27.7,28.1,74
    2025-05-27 14:42:30.926,3876,3877,3869,3870,-10619,-10623,-10622,-10618,28.3,27.6,27.7,28.2,74
    2025-05-27 14:42:35.938,3875,3876,3867,3868,-10623,-10622,-10622,-10617,28.2,27.4,27.7,28.1,74
    2025-05-27 14:42:40.945,3874,3875,3866,3867,-10621,-10620,-10620,-10615,28.2,27.5,27.7,28.2,73
    2025-05-27 14:42:45.946,3872,3874,3865,3866,-10626,-10622,-10617,-10622,28.2,27.5,27.7,28.1,73
    2025-05-27 14:42:50.952,3871,3872,3864,3865,-10618,-10620,-10618,-10620,28.3,27.6,27.8,28.2,73
    2025-05-27 14:42:55.960,3870,3871,3862,3863,-10622,-10623,-10619,-10623,28.2,27.5,27.8,28.2,73
    2025-05-27 14:43:00.967,3868,3870,3861,3862,-10619,-10621,-10620,-10622,28.3,27.6,27.8,28.2,73
    2025-05-27 14:43:05.975,3867,3868,3860,3861,-10613,-10621,-10620,-10622,28.3,27.5,27.8,28.1,73
    2025-05-27 14:43:10.988,3866,3867,3859,3859,-10615,-10619,-10623,-10622,28.4,27.5,27.8,28.2,72
    2025-05-27 14:43:15.994,3864,3866,3859,3858,-10615,-10620,-10624,-10622,28.3,27.5,27.8,28.2,72
    2025-05-27 14:43:20.997,3863,3864,3856,3857,-10622,-10623,-10620,-10621,28.3,27.5,27.9,28.2,72
    2025-05-27 14:43:26.003,3862,3863,3855,3856,-10621,-10625,-10623,-10620,28.4,27.5,27.8,28.3,72
    2025-05-27 14:43:31.008,3860,3862,3854,3854,-10622,-10619,-10623,-10621,28.3,27.6,27.8,28.2,72
    2025-05-27 14:43:36.014,3859,3861,3854,3853,-10621,-10622,-10626,-10623,28.4,27.6,27.8,28.3,71
    2025-05-27 14:43:41.023,3858,3859,3851,3852,-10619,-10620,-10626,-10620,28.4,27.6,27.9,28.2,71
    2025-05-27 14:43:46.033,3857,3857,3849,3850,-10620,-10618,-10621,-10621,28.5,27.6,27.8,28.3,71
    2025-05-27 14:43:51.043,3855,3857,3848,3849,-10623,-10619,-10625,-10621,28.6,27.6,27.9,28.3,71
    2025-05-27 14:43:56.051,3854,3855,3847,3848,-10623,-10618,-10619,-10620,28.6,27.7,27.9,28.4,71
    2025-05-27 14:44:01.054,3853,3854,3846,3846,-10625,-10619,-10619,-10624,28.6,27.7,28.0,28.4,70
    2025-05-27 14:44:06.066,3851,3852,3844,3845,-10623,-10619,-10622,-10621,28.5,27.7,28.0,28.4,70
    2025-05-27 14:44:11.080,3850,3851,3843,3844,-10625,-10621,-10617,-10621,28.5,27.7,27.9,28.4,70
    2025-05-27 14:44:16.092,3849,3850,3842,3843,-10627,-10617,-10620,-10626,28.5,27.6,27.9,28.5,70
    2025-05-27 14:44:21.101,3847,3848,3840,3841,-10625,-10616,-10620,-10624,28.5,27.7,28.0,28.5,70
    2025-05-27 14:44:26.109,3846,3847,3839,3840,-10623,-10618,-10622,-10626,28.5,27.7,27.9,28.5,69
    2025-05-27 14:44:31.113,3845,3846,3837,3839,-10619,-10623,-10624,-10624,28.5,27.6,28.0,28.5,69
    2025-05-27 14:44:36.128,3844,3846,3838,3838,-10622,-10624,-10620,-10623,28.6,27.6,28.0,28.5,69
    2025-05-27 14:44:41.136,3842,3843,3835,3836,-10619,-10625,-10623,-10622,28.7,27.7,28.1,28.5,69
    2025-05-27 14:44:46.148,3841,3842,3834,3835,-10620,-10625,-10620,-10620,28.6,27.7,28.1,28.5,69
    2025-05-27 14:44:51.161,3839,3841,3832,3833,-10620,-10623,-10622,-10621,28.6,27.7,28.1,28.6,68
    2025-05-27 14:44:56.173,3839,3841,3832,3832,-10626,-10624,-10624,-10621,28.6,27.8,28.1,28.5,68
    2025-05-27 14:45:01.178,3837,3838,3830,3831,-10623,-10623,-10626,-10618,28.7,27.8,28.1,28.5,68
    2025-05-27 14:45:06.185,3836,3837,3829,3830,-10628,-10622,-10626,-10622,28.7,27.8,28.2,28.6,68
    2025-05-27 14:45:11.189,3834,3836,3827,3829,-10622,-10623,-10623,-10622,28.7,27.8,28.2,28.6,68
    2025-05-27 14:45:16.199,3833,3835,3827,3827,-10625,-10623,-10626,-10623,28.7,27.8,28.2,28.6,67
    2025-05-27 14:45:21.207,3832,3833,3825,3826,-10619,-10627,-10624,-10623,28.7,27.8,28.2,28.6,67
    2025-05-27 14:45:26.207,3831,3832,3823,3825,-10622,-10627,-10628,-10626,28.7,27.8,28.2,28.6,67
    2025-05-27 14:45:31.219,3829,3831,3822,3823,-10628,-10622,-10623,-10626,28.8,27.8,28.2,28.6,67
    2025-05-27 14:45:36.229,3828,3830,3822,3823,-10627,-10627,-10622,-10623,28.8,27.9,28.2,28.6,67
    2025-05-27 14:45:41.233,3827,3828,3820,3821,-10627,-10627,-10622,-10626,28.8,27.8,28.2,28.7,66
    2025-05-27 14:45:46.241,3826,3827,3818,3820,-10623,-10625,-10626,-10626,28.8,27.9,28.3,28.6,66
    2025-05-27 14:45:51.248,3824,3826,3817,3819,-10623,-10624,-10623,-10627,28.8,27.9,28.3,28.6,66
    2025-05-27 14:45:56.263,3823,3826,3817,3818,-10624,-10628,-10624,-10624,28.9,27.9,28.3,28.7,66
    2025-05-27 14:46:01.272,3822,3823,3815,3816,-10624,-10629,-10620,-10624,28.9,27.9,28.3,28.7,66
    2025-05-27 14:46:06.281,3821,3822,3814,3815,-10626,-10623,-10624,-10624,28.9,27.9,28.3,28.7,65
    2025-05-27 14:46:11.292,3820,3821,3812,3814,-10624,-10622,-10626,-10620,28.9,27.9,28.3,28.7,65
    2025-05-27 14:46:16.294,3819,3820,3812,3813,-10628,-10627,-10631,-10625,29.0,28.0,28.3,28.7,65
    2025-05-27 14:46:21.301,3817,3818,3810,3811,-10626,-10620,-10625,-10622,29.1,28.1,28.4,28.7,65
    2025-05-27 14:46:26.316,3816,3817,3809,3810,-10626,-10629,-10629,-10621,29.0,28.0,28.4,28.7,65
    2025-05-27 14:46:31.326,3815,3816,3808,3809,-10628,-10624,-10627,-10622,29.1,28.1,28.4,28.8,64
    2025-05-27 14:46:36.335,3815,3816,3807,3808,-10626,-10629,-10629,-10622,29.0,28.0,28.4,28.8,64
    2025-05-27 14:46:41.348,3813,3814,3805,3807,-10626,-10631,-10627,-10622,29.1,28.0,28.4,28.8,64
    2025-05-27 14:46:46.353,3812,3813,3804,3806,-10622,-10628,-10625,-10626,29.2,28.1,28.4,29.0,64
    2025-05-27 14:46:51.362,3810,3812,3803,3805,-10623,-10627,-10627,-10624,29.1,28.0,28.5,29.0,64
    2025-05-27 14:46:56.371,3811,3811,3802,3804,-10625,-10631,-10625,-10626,29.1,28.0,28.5,29.0,64
    2025-05-27 14:47:01.369,3808,3809,3801,3802,-10624,-10627,-10629,-10626,29.1,28.1,28.5,29.0,63
    2025-05-27 14:47:06.377,3807,3808,3799,3801,-10623,-10626,-10626,-10628,29.2,28.1,28.5,28.8,63
    2025-05-27 14:47:11.385,3806,3807,3798,3800,-10622,-10624,-10629,-10624,29.1,28.1,28.6,28.9,63
    2025-05-27 14:47:16.425,3806,3807,3798,3799,-10625,-10627,-10625,-10622,29.1,28.1,28.5,29.0,63
    2025-05-27 14:47:21.401,3803,3805,3796,3798,-10618,-10622,-10624,-10623,29.1,28.1,28.5,29.0,63
    2025-05-27 14:47:26.409,3802,3804,3795,3797,-10619,-10627,-10624,-10627,29.3,28.2,28.5,29.0,62
    2025-05-27 14:47:31.416,3801,3803,3794,3795,-10621,-10626,-10625,-10629,29.2,28.1,28.5,29.0,62
    2025-05-27 14:47:36.487,3801,3802,3793,3794,-10626,-10633,-10627,-10629,29.1,28.2,28.6,29.1,62
    2025-05-27 14:47:41.434,3799,3800,3792,3793,-10623,-10621,-10624,-10627,29.2,28.2,28.6,29.0,62
    2025-05-27 14:47:46.443,3798,3799,3790,3792,-10624,-10623,-10630,-10631,29.2,28.2,28.6,29.1,62
    2025-05-27 14:47:51.450,3797,3799,3789,3791,-10625,-10620,-10627,-10629,29.3,28.3,28.6,29.1,61
    2025-05-27 14:47:56.559,3797,3798,3788,3790,-10626,-10637,-10629,-10628,29.2,28.2,28.6,29.1,61
    2025-05-27 14:48:01.466,3795,3796,3787,3789,-10623,-10620,-10629,-10629,29.2,28.2,28.6,29.1,61
    2025-05-27 14:48:06.476,3794,3795,3786,3788,-10628,-10621,-10627,-10627,29.3,28.2,28.6,29.1,61
    2025-05-27 14:48:11.486,3793,3794,3785,3787,-10627,-10624,-10624,-10627,29.3,28.2,28.6,29.2,61
    2025-05-27 14:48:16.595,3793,3793,3784,3786,-10629,-10634,-10633,-10623,29.3,28.3,28.7,29.2,60
    2025-05-27 14:48:21.504,3791,3792,3783,3785,-10626,-10625,-10623,-10628,29.3,28.3,28.7,29.1,60
    2025-05-27 14:48:26.511,3790,3791,3782,3784,-10627,-10627,-10621,-10629,29.3,28.3,28.7,29.1,60
    2025-05-27 14:48:31.516,3789,3790,3781,3783,-10626,-10626,-10622,-10628,29.3,28.4,28.7,29.2,60
    2025-05-27 14:48:36.642,3788,3789,3780,3782,-10631,-10628,-10635,-10631,29.3,28.3,28.7,29.2,60
    2025-05-27 14:48:41.535,3786,3788,3779,3781,-10628,-10625,-10622,-10628,29.4,28.3,28.7,29.3,59
    2025-05-27 14:48:46.545,3785,3787,3778,3780,-10626,-10629,-10626,-10628,29.5,28.3,28.7,29.2,59
    2025-05-27 14:48:51.555,3784,3786,3777,3779,-10627,-10629,-10627,-10628,29.5,28.4,28.7,29.2,59
    2025-05-27 14:48:56.686,3784,3785,3776,3778,-10626,-10625,-10624,-10633,29.5,28.5,28.8,29.3,59
    2025-05-27 14:49:01.579,3782,3784,3775,3777,-10623,-10626,-10625,-10622,29.5,28.3,28.8,29.2,59
    2025-05-27 14:49:06.590,3781,3783,3774,3776,-10624,-10626,-10623,-10634,29.4,28.4,28.8,29.2,58
    2025-05-27 14:49:11.602,3780,3782,3772,3775,-10625,-10626,-10625,-10620,29.5,28.4,28.8,29.2,58
    2025-05-27 14:49:16.752,3780,3781,3771,3774,-10627,-10633,-10632,-10633,29.4,28.4,28.8,29.3,58
    2025-05-27 14:49:21.616,3778,3780,3770,3773,-10629,-10628,-10627,-10628,29.4,28.4,28.8,29.3,58
    2025-05-27 14:49:26.620,3777,3779,3770,3772,-10631,-10627,-10629,-10627,29.6,28.4,28.8,29.3,58
    2025-05-27 14:49:31.634,3776,3778,3768,3771,-10627,-10622,-10631,-10625,29.6,28.5,28.8,29.3,57
    2025-05-27 14:49:36.783,3777,3777,3768,3770,-10625,-10633,-10628,-10635,29.5,28.5,28.9,29.4,57
    2025-05-27 14:49:41.654,3775,3776,3767,3769,-10629,-10626,-10627,-10629,29.5,28.5,28.9,29.3,57
    2025-05-27 14:49:46.663,3773,3775,3766,3768,-10627,-10625,-10630,-10625,29.6,28.5,28.9,29.4,57
    2025-05-27 14:49:51.669,3772,3774,3765,3767,-10623,-10630,-10625,-10630,29.6,28.5,28.9,29.3,57
    2025-05-27 14:49:56.847,3772,3773,3764,3766,-10635,-10630,-10631,-10630,29.5,28.5,28.9,29.4,56
    2025-05-27 14:50:01.688,3770,3772,3763,3765,-10623,-10624,-10626,-10628,29.7,28.6,29.0,29.4,56
    2025-05-27 14:50:06.693,3770,3771,3762,3764,-10631,-10631,-10625,-10626,29.7,28.6,29.0,29.4,56
    2025-05-27 14:50:11.703,3769,3770,3761,3763,-10629,-10624,-10626,-10630,29.7,28.5,29.0,29.4,56
    2025-05-27 14:50:16.924,3768,3770,3760,3762,-10629,-10631,-10634,-10625,29.6,28.5,28.9,29.4,56
    2025-05-27 14:50:21.721,3767,3768,3759,3761,-10631,-10629,-10628,-10630,29.7,28.6,29.0,29.5,56
    2025-05-27 14:50:26.730,3766,3767,3758,3760,-10625,-10625,-10628,-10628,29.7,28.6,29.1,29.5,55
    2025-05-27 14:50:31.737,3765,3767,3757,3759,-10628,-10628,-10627,-10627,29.7,28.6,29.1,29.5,55
    2025-05-27 14:50:36.955,3764,3766,3756,3759,-10634,-10629,-10628,-10630,29.6,28.6,29.0,29.5,55
    2025-05-27 14:50:41.753,3763,3765,3755,3758,-10628,-10631,-10629,-10624,29.8,28.7,29.1,29.4,55
    2025-05-27 14:50:46.764,3762,3764,3754,3757,-10630,-10628,-10629,-10621,29.8,28.7,29.1,29.6,55
    2025-05-27 14:50:51.775,3762,3763,3753,3756,-10628,-10627,-10625,-10627,29.8,28.7,29.1,29.5,54
    2025-05-27 14:50:57.002,3761,3762,3752,3755,-10632,-10632,-10634,-10627,29.7,28.6,29.1,29.6,54
    2025-05-27 14:51:01.797,3760,3761,3751,3754,-10629,-10630,-10623,-10629,29.8,28.7,29.1,29.6,54
    2025-05-27 14:51:06.809,3759,3760,3750,3753,-10627,-10627,-10626,-10627,29.9,28.7,29.2,29.6,54
    2025-05-27 14:51:11.821,3758,3759,3749,3752,-10630,-10629,-10628,-10630,29.9,28.7,29.2,29.6,54
    2025-05-27 14:51:17.064,3757,3759,3749,3752,-10633,-10631,-10627,-10631,29.8,28.7,29.1,29.6,53
    2025-05-27 14:51:21.837,3756,3758,3748,3751,-10637,-10633,-10629,-10631,29.9,28.7,29.2,29.6,53
    2025-05-27 14:51:26.844,3755,3757,3747,3750,-10632,-10632,-10625,-10623,29.9,28.8,29.2,29.7,53
    2025-05-27 14:51:31.853,3754,3756,3746,3749,-10636,-10631,-10628,-10625,29.9,28.7,29.2,29.7,53
    2025-05-27 14:51:37.125,3754,3755,3745,3748,-10624,-10628,-10630,-10633,29.8,28.7,29.2,29.7,53
    2025-05-27 14:51:41.869,3753,3754,3744,3747,-10635,-10629,-10630,-10627,29.9,28.8,29.2,29.6,52
    2025-05-27 14:51:46.878,3752,3754,3744,3748,-10634,-10630,-10625,-10626,29.9,28.8,29.3,29.7,52
    2025-05-27 14:51:51.886,3751,3753,3743,3747,-10635,-10630,-10625,-10628,29.9,28.8,29.3,29.7,52
    2025-05-27 14:51:57.172,3750,3752,3742,3745,-10630,-10630,-10630,-10628,29.9,28.8,29.2,29.8,52
    2025-05-27 14:52:01.903,3749,3752,3741,3745,-10634,-10634,-10626,-10630,30.0,28.9,29.3,29.7,52
    2025-05-27 14:52:06.913,3749,3750,3740,3744,-10637,-10638,-10632,-10630,30.0,28.9,29.3,29.8,51
    2025-05-27 14:52:11.919,3748,3750,3740,3743,-10638,-10633,-10630,-10630,30.1,28.9,29.3,29.8,51
    2025-05-27 14:52:17.237,3747,3749,3739,3742,-10633,-10626,-10631,-10634,29.9,28.8,29.3,29.8,51
    2025-05-27 14:52:21.935,3747,3748,3738,3742,-10635,-10635,-10632,-10630,30.0,28.9,29.3,29.8,51
    2025-05-27 14:52:26.944,3746,3747,3737,3741,-10629,-10633,-10631,-10630,30.1,29.0,29.4,29.8,51
    2025-05-27 14:52:31.947,3745,3747,3736,3740,-10630,-10632,-10634,-10631,30.1,29.0,29.4,29.7,50
    2025-05-27 14:52:37.299,3744,3746,3736,3740,-10631,-10625,-10629,-10633,30.1,29.0,29.4,29.9,50
    2025-05-27 14:52:41.958,3743,3745,3735,3738,-10629,-10632,-10636,-10630,30.1,29.0,29.4,29.8,50
    2025-05-27 14:52:46.968,3742,3744,3734,3738,-10631,-10634,-10632,-10633,30.1,29.0,29.4,29.8,50
    2025-05-27 14:52:51.981,3741,3744,3733,3737,-10635,-10633,-10631,-10629,30.2,29.0,29.4,29.8,50
    2025-05-27 14:52:57.346,3741,3743,3733,3737,-10639,-10631,-10631,-10640,30.1,29.0,29.3,29.9,49
    2025-05-27 14:53:02.003,3740,3742,3732,3736,-10631,-10628,-10631,-10635,30.2,29.0,29.4,29.9,49
    2025-05-27 14:53:07.013,3739,3741,3731,3735,-10632,-10631,-10630,-10638,30.2,29.1,29.5,29.9,49
    2025-05-27 14:53:12.024,3739,3740,3730,3734,-10629,-10630,-10636,-10639,30.2,29.1,29.5,29.9,49
    2025-05-27 14:53:17.407,3738,3740,3730,3733,-10629,-10632,-10631,-10642,30.2,29.0,29.4,30.1,49
    2025-05-27 14:53:22.043,3737,3739,3729,3733,-10625,-10634,-10637,-10636,30.3,29.1,29.5,30.0,48
    2025-05-27 14:53:27.052,3737,3738,3728,3732,-10625,-10640,-10635,-10641,30.2,29.1,29.5,29.9,48
    2025-05-27 14:53:32.065,3736,3738,3727,3732,-10625,-10631,-10632,-10633,30.2,29.1,29.5,30.0,48
    2025-05-27 14:53:37.470,3735,3737,3727,3730,-10630,-10626,-10633,-10645,30.2,29.1,29.5,30.1,48
    2025-05-27 14:53:42.081,3734,3736,3726,3730,-10633,-10635,-10630,-10638,30.2,29.2,29.5,30.1,48
    2025-05-27 14:53:47.091,3734,3736,3725,3729,-10633,-10636,-10631,-10636,30.2,29.1,29.5,30.0,48
    2025-05-27 14:53:52.099,3733,3735,3724,3729,-10636,-10641,-10631,-10637,30.3,29.2,29.5,30.1,47
    2025-05-27 14:53:57.533,3732,3735,3724,3727,-10633,-10628,-10640,-10637,30.2,29.1,29.6,30.2,47
    2025-05-27 14:54:02.115,3731,3734,3723,3727,-10633,-10628,-10634,-10631,30.3,29.2,29.6,30.1,47
    2025-05-27 14:54:07.127,3731,3733,3722,3727,-10624,-10630,-10634,-10630,30.3,29.2,29.6,30.1,47
    2025-05-27 14:54:12.133,3730,3732,3721,3726,-10623,-10631,-10639,-10631,30.3,29.2,29.6,30.1,47
    2025-05-27 14:54:17.137,3729,3731,3721,3725,-10623,-10633,-10639,-10630,30.4,29.2,29.6,30.2,46
    2025-05-27 14:54:22.139,3729,3731,3720,3724,-10626,-10633,-10637,-10634,30.4,29.2,29.7,30.2,46
    2025-05-27 14:54:27.149,3728,3730,3719,3724,-10632,-10633,-10638,-10634,30.4,29.2,29.6,30.2,46
    2025-05-27 14:54:32.159,3728,3730,3719,3723,-10633,-10633,-10638,-10638,30.4,29.3,29.6,30.2,46
    2025-05-27 14:54:37.163,3727,3729,3718,3721,-10631,-10639,-10631,-10634,30.5,29.3,29.7,30.2,46
    2025-05-27 14:54:42.172,3726,3728,3717,3722,-10636,-10629,-10637,-10636,30.5,29.3,29.7,30.2,45
    2025-05-27 14:54:47.186,3726,3728,3717,3721,-10632,-10627,-10635,-10638,30.5,29.3,29.7,30.2,45
    2025-05-27 14:54:52.194,3725,3727,3716,3721,-10627,-10623,-10637,-10637,30.5,29.3,29.7,30.3,45
    2025-05-27 14:54:57.205,3724,3726,3715,3720,-10626,-10626,-10635,-10637,30.5,29.3,29.8,30.3,45
    2025-05-27 14:55:02.206,3724,3726,3715,3719,-10626,-10628,-10635,-10639,30.5,29.3,29.7,30.3,45
    2025-05-27 14:55:07.214,3723,3725,3714,3719,-10630,-10631,-10632,-10631,30.5,29.4,29.8,30.3,44
    2025-05-27 14:55:12.227,3723,3725,3714,3718,-10629,-10631,-10630,-10634,30.5,29.3,29.8,30.3,44
    2025-05-27 14:55:17.229,3722,3724,3713,3718,-10633,-10628,-10638,-10638,30.5,29.4,29.8,30.3,44
    2025-05-27 14:55:22.238,3721,3723,3712,3717,-10632,-10630,-10634,-10633,30.5,29.4,29.8,30.3,44
    2025-05-27 14:55:27.244,3721,3723,3712,3716,-10630,-10639,-10632,-10632,30.6,29.4,29.9,30.3,44
    2025-05-27 14:55:32.253,3720,3722,3711,3716,-10630,-10631,-10636,-10640,30.6,29.4,29.8,30.3,43
    2025-05-27 14:55:37.257,3720,3722,3711,3715,-10631,-10631,-10635,-10640,30.6,29.4,29.9,30.4,43
    2025-05-27 14:55:42.261,3719,3721,3710,3715,-10634,-10629,-10632,-10640,30.6,29.4,29.9,30.4,43
    2025-05-27 14:55:47.273,3718,3721,3709,3714,-10634,-10628,-10636,-10637,30.6,29.4,29.9,30.4,43
    2025-05-27 14:55:52.285,3718,3720,3709,3714,-10637,-10632,-10633,-10632,30.6,29.5,29.9,30.4,43
    2025-05-27 14:55:57.291,3717,3720,3708,3713,-10638,-10629,-10631,-10636,30.7,29.4,29.9,30.4,42
    2025-05-27 14:56:02.299,3717,3719,3708,3712,-10638,-10628,-10631,-10637,30.7,29.5,29.9,30.4,42
    2025-05-27 14:56:07.307,3716,3718,3707,3712,-10638,-10634,-10631,-10637,30.7,29.5,29.9,30.5,42
    2025-05-27 14:56:12.314,3716,3718,3707,3711,-10638,-10633,-10632,-10637,30.7,29.5,29.9,30.4,42
    2025-05-27 14:56:17.321,3715,3718,3706,3711,-10634,-10632,-10631,-10636,30.7,29.5,30.0,30.5,42
    2025-05-27 14:56:22.324,3715,3717,3706,3710,-10635,-10637,-10633,-10636,30.7,29.6,30.0,30.5,41
    2025-05-27 14:56:27.334,3714,3716,3705,3710,-10637,-10637,-10631,-10635,30.8,29.6,30.1,30.5,41
    2025-05-27 14:56:32.340,3713,3716,3704,3709,-10636,-10640,-10632,-10638,30.8,29.6,30.0,30.5,41
    2025-05-27 14:56:37.349,3713,3716,3704,3709,-10636,-10640,-10634,-10635,30.8,29.6,30.1,30.6,41
    2025-05-27 14:56:42.355,3712,3715,3703,3708,-10635,-10637,-10630,-10635,30.8,29.6,30.1,30.6,41
    2025-05-27 14:56:47.368,3712,3715,3703,3708,-10633,-10636,-10633,-10632,30.8,29.6,30.1,30.6,40
    2025-05-27 14:56:52.371,3712,3714,3702,3707,-10628,-10635,-10634,-10632,30.9,29.6,30.2,30.6,40
    2025-05-27 14:56:57.378,3711,3714,3702,3707,-10636,-10636,-10638,-10635,30.9,29.6,30.2,30.6,40
    2025-05-27 14:57:02.385,3711,3713,3701,3706,-10633,-10633,-10639,-10637,30.9,29.6,30.2,30.6,40
    2025-05-27 14:57:07.389,3710,3713,3701,3706,-10630,-10634,-10640,-10637,30.9,29.6,30.2,30.7,40
    2025-05-27 14:57:12.400,3710,3712,3701,3705,-10635,-10636,-10643,-10637,30.9,29.7,30.2,30.7,39
    2025-05-27 14:57:17.414,3709,3712,3700,3705,-10635,-10637,-10640,-10637,30.9,29.7,30.2,30.7,39
    2025-05-27 14:57:22.424,3709,3712,3699,3704,-10632,-10634,-10635,-10638,31.0,29.7,30.2,30.7,39
    2025-05-27 14:57:27.432,3709,3711,3699,3704,-10636,-10634,-10635,-10638,31.0,29.8,30.2,30.7,39
    2025-05-27 14:57:32.442,3708,3711,3699,3704,-10639,-10632,-10638,-10641,31.0,29.7,30.2,30.7,39
    2025-05-27 14:57:37.452,3708,3711,3698,3702,-10638,-10635,-10638,-10631,31.0,29.8,30.2,30.8,39
    2025-05-27 14:57:42.461,3707,3711,3698,3703,-10641,-10634,-10639,-10642,31.0,29.8,30.2,30.8,38
    2025-05-27 14:57:47.465,3707,3710,3698,3703,-10638,-10640,-10638,-10642,31.0,29.8,30.2,30.8,38
    2025-05-27 14:57:52.475,3707,3710,3697,3702,-10637,-10637,-10635,-10639,31.1,29.8,30.3,30.8,38
    2025-05-27 14:57:57.482,3706,3710,3697,3702,-10636,-10635,-10634,-10637,31.1,29.8,30.2,30.8,38
    2025-05-27 14:58:02.494,3706,3709,3697,3701,-10638,-10640,-10631,-10637,31.1,29.9,30.2,30.9,38
    2025-05-27 14:58:07.495,3706,3709,3696,3701,-10639,-10643,-10631,-10638,31.1,29.8,30.3,30.9,37
    2025-05-27 14:58:12.506,3706,3708,3696,3701,-10636,-10643,-10631,-10643,31.2,29.9,30.3,30.9,37
    2025-05-27 14:58:17.515,3705,3708,3695,3701,-10639,-10640,-10638,-10645,31.2,29.9,30.3,30.9,37
    2025-05-27 14:58:22.525,3705,3708,3695,3700,-10640,-10637,-10640,-10641,31.2,29.9,30.4,30.9,37
    2025-05-27 14:58:27.530,3704,3708,3695,3700,-10640,-10634,-10635,-10635,31.2,30.0,30.4,31.0,37
    2025-05-27 14:58:32.539,3704,3708,3695,3700,-10643,-10637,-10635,-10636,31.2,29.9,30.4,31.0,36
    2025-05-27 14:58:37.544,3704,3707,3694,3699,-10641,-10638,-10640,-10634,31.2,30.0,30.4,31.0,36
    2025-05-27 14:58:42.556,3704,3707,3694,3699,-10641,-10642,-10643,-10635,31.3,29.9,30.5,31.0,36
    2025-05-27 14:58:47.566,3703,3707,3694,3701,-10638,-10639,-10643,-10640,31.3,30.1,30.5,31.0,36
    2025-05-27 14:58:52.578,3703,3706,3693,3699,-10637,-10637,-10641,-10637,31.3,30.1,30.5,31.1,36
    2025-05-27 14:58:57.590,3703,3706,3693,3698,-10635,-10641,-10635,-10635,31.3,30.1,30.5,31.1,35
    2025-05-27 14:59:02.597,3702,3706,3693,3698,-10636,-10644,-10638,-10640,31.4,30.1,30.6,31.1,35
    2025-05-27 14:59:07.607,3702,3705,3693,3698,-10635,-10642,-10641,-10639,31.4,30.1,30.6,31.1,35
    2025-05-27 14:59:12.613,3702,3705,3692,3697,-10638,-10642,-10637,-10642,31.4,30.2,30.7,31.2,35
    2025-05-27 14:59:17.623,3702,3705,3692,3697,-10640,-10643,-10636,-10645,31.4,30.2,30.7,31.1,35
    2025-05-27 14:59:22.630,3701,3704,3692,3697,-10638,-10638,-10638,-10642,31.5,30.2,30.7,31.1,34
    2025-05-27 14:59:27.636,3701,3704,3691,3698,-10640,-10641,-10638,-10640,31.5,30.2,30.7,31.2,34
    2025-05-27 14:59:32.646,3701,3704,3691,3696,-10641,-10636,-10641,-10640,31.5,30.2,30.7,31.2,34
    2025-05-27 14:59:37.655,3700,3704,3691,3698,-10634,-10638,-10641,-10638,31.6,30.3,30.7,31.2,34
    2025-05-27 14:59:42.667,3700,3703,3690,3698,-10641,-10640,-10644,-10637,31.7,30.2,30.7,31.3,34
    2025-05-27 14:59:47.679,3700,3703,3690,3697,-10640,-10641,-10640,-10635,31.7,30.2,30.8,31.3,33
    2025-05-27 14:59:52.689,3699,3703,3690,3695,-10638,-10641,-10638,-10639,31.7,30.2,30.8,31.3,33
    2025-05-27 14:59:57.697,3699,3702,3689,3697,-10642,-10641,-10644,-10637,31.7,30.2,30.8,31.3,33
    2025-05-27 15:00:02.702,3699,3702,3689,3696,-10638,-10641,-10641,-10640,31.7,30.2,30.9,31.4,33
    2025-05-27 15:00:07.714,3699,3702,3689,3696,-10640,-10639,-10643,-10642,31.8,30.3,30.9,31.4,33
    2025-05-27 15:00:12.723,3698,3701,3688,3696,-10636,-10642,-10643,-10643,31.8,30.3,30.9,31.5,32
    2025-05-27 15:00:17.733,3698,3701,3688,3695,-10637,-10638,-10644,-10644,31.8,30.4,30.9,31.4,32
    2025-05-27 15:00:22.738,3698,3701,3688,3695,-10640,-10642,-10643,-10642,31.8,30.4,30.9,31.5,32
    2025-05-27 15:00:27.745,3697,3700,3688,3695,-10639,-10642,-10641,-10642,31.8,30.4,30.9,31.5,32
    2025-05-27 15:00:32.749,3697,3700,3687,3694,-10641,-10640,-10644,-10640,31.8,30.5,31.0,31.5,32
    2025-05-27 15:00:37.759,3697,3700,3687,3694,-10639,-10642,-10638,-10643,31.9,30.5,31.0,31.6,31
    2025-05-27 15:00:42.764,3697,3700,3687,3694,-10640,-10635,-10641,-10643,31.9,30.5,31.0,31.6,31
    2025-05-27 15:00:47.774,3696,3700,3687,3690,-10639,-10642,-10641,-10650,31.9,30.5,31.1,31.7,31
    2025-05-27 15:00:52.788,3696,3699,3686,3693,-10633,-10636,-10639,-10643,31.9,30.5,31.1,31.7,31
    2025-05-27 15:00:57.797,3696,3698,3685,3693,-10642,-10639,-10640,-10643,31.9,30.5,31.1,31.7,31
    2025-05-27 15:01:02.810,3695,3698,3685,3693,-10635,-10639,-10640,-10640,31.9,30.6,31.2,31.8,30
    2025-05-27 15:01:07.820,3695,3698,3685,3692,-10638,-10639,-10639,-10643,32.0,30.6,31.2,31.8,30
    2025-05-27 15:01:12.835,3695,3698,3685,3692,-10641,-10639,-10636,-10643,32.1,30.7,31.2,31.9,30
    2025-05-27 15:01:17.841,3694,3697,3684,3692,-10637,-10638,-10638,-10643,32.1,30.7,31.2,31.9,30
    2025-05-27 15:01:22.847,3694,3697,3684,3692,-10644,-10642,-10632,-10644,32.1,30.7,31.2,31.9,30
    2025-05-27 15:01:27.853,3694,3697,3683,3691,-10639,-10641,-10632,-10647,32.2,30.7,31.3,31.9,30
    2025-05-27 15:01:32.862,3693,3696,3683,3691,-10644,-10635,-10634,-10644,32.2,30.7,31.3,31.9,29
    2025-05-27 15:01:37.871,3693,3696,3683,3690,-10641,-10641,-10637,-10642,32.2,30.7,31.3,31.9,29
    2025-05-27 15:01:42.884,3693,3696,3682,3690,-10637,-10643,-10637,-10641,32.2,30.8,31.3,31.9,29
    2025-05-27 15:01:47.895,3693,3695,3682,3690,-10639,-10639,-10638,-10643,32.2,30.8,31.3,31.9,29
    2025-05-27 15:01:52.902,3692,3695,3682,3689,-10640,-10639,-10640,-10639,32.2,30.8,31.4,32.0,29
    2025-05-27 15:01:57.911,3692,3695,3681,3689,-10639,-10641,-10638,-10636,32.3,30.9,31.4,31.9,28
    2025-05-27 15:02:02.915,3692,3694,3681,3690,-10637,-10641,-10645,-10636,32.4,30.9,31.4,32.0,28
    2025-05-27 15:02:07.921,3691,3694,3681,3687,-10637,-10643,-10638,-10639,32.4,30.9,31.5,32.1,28
    2025-05-27 15:02:12.935,3691,3693,3680,3687,-10637,-10642,-10638,-10643,32.4,30.9,31.5,32.1,28
    2025-05-27 15:02:17.945,3690,3693,3680,3686,-10639,-10643,-10640,-10641,32.4,31.0,31.5,32.2,28
    2025-05-27 15:02:22.949,3690,3693,3679,3688,-10644,-10640,-10639,-10637,32.4,31.0,31.5,32.2,27
    2025-05-27 15:02:27.961,3690,3692,3679,3686,-10644,-10634,-10644,-10640,32.5,31.0,31.6,32.2,27
    2025-05-27 15:02:32.967,3689,3692,3678,3686,-10644,-10641,-10644,-10643,32.5,31.0,31.6,32.2,27
    2025-05-27 15:02:37.981,3689,3691,3678,3686,-10643,-10642,-10642,-10645,32.5,31.1,31.6,32.3,27
    2025-05-27 15:02:42.992,3688,3691,3678,3686,-10640,-10644,-10642,-10646,32.5,31.1,31.7,32.4,27
    2025-05-27 15:02:47.997,3688,3691,3677,3685,-10639,-10641,-10645,-10646,32.5,31.1,31.7,32.4,26
    2025-05-27 15:02:53.007,3688,3690,3677,3685,-10644,-10640,-10645,-10646,32.5,31.1,31.7,32.4,26
    2025-05-27 15:02:58.014,3688,3690,3676,3684,-10645,-10640,-10642,-10647,32.5,31.1,31.8,32.4,26
    2025-05-27 15:03:03.024,3687,3689,3676,3685,-10645,-10643,-10644,-10648,32.6,31.2,31.8,32.4,26
    2025-05-27 15:03:08.037,3687,3689,3675,3683,-10643,-10644,-10645,-10643,32.6,31.2,31.8,32.4,26
    2025-05-27 15:03:13.040,3686,3688,3675,3683,-10644,-10645,-10644,-10645,32.6,31.2,31.8,32.4,25
    2025-05-27 15:03:18.046,3686,3688,3675,3682,-10644,-10644,-10646,-10647,32.7,31.3,31.9,32.4,25
    2025-05-27 15:03:23.058,3685,3687,3674,3683,-10644,-10642,-10645,-10644,32.8,31.3,31.9,32.5,25
    2025-05-27 15:03:28.065,3685,3687,3673,3681,-10641,-10646,-10645,-10645,32.8,31.3,31.9,32.6,25
    2025-05-27 15:03:33.070,3685,3686,3673,3681,-10642,-10645,-10643,-10641,32.8,31.3,31.9,32.6,25
    2025-05-27 15:03:38.077,3684,3686,3672,3680,-10645,-10643,-10645,-10643,32.9,31.3,32.0,32.6,24
    2025-05-27 15:03:43.089,3684,3685,3672,3681,-10645,-10645,-10648,-10649,32.9,31.3,31.9,32.6,24
    2025-05-27 15:03:48.102,3683,3685,3671,3679,-10646,-10645,-10640,-10647,32.9,31.4,31.9,32.6,24
    2025-05-27 15:03:53.111,3683,3685,3671,3679,-10647,-10646,-10645,-10648,33.0,31.4,32.0,32.7,24
    2025-05-27 15:03:58.124,3682,3684,3670,3678,-10641,-10645,-10642,-10646,33.0,31.4,32.1,32.8,23
    2025-05-27 15:04:03.135,3682,3683,3670,3679,-10641,-10645,-10647,-10648,33.0,31.4,32.1,32.8,23
    2025-05-27 15:04:08.147,3681,3683,3670,3677,-10643,-10644,-10645,-10645,33.0,31.5,32.2,32.8,23
    2025-05-27 15:04:13.151,3681,3682,3669,3676,-10636,-10643,-10642,-10647,33.1,31.5,32.2,32.8,23
    2025-05-27 15:04:18.160,3680,3682,3668,3676,-10641,-10644,-10645,-10647,33.2,31.6,32.2,32.8,23
    2025-05-27 15:04:23.167,3680,3681,3668,3677,-10639,-10643,-10646,-10648,33.1,31.5,32.2,32.8,22
    2025-05-27 15:04:28.178,3679,3681,3667,3675,-10639,-10642,-10647,-10642,33.2,31.6,32.3,32.8,22
    2025-05-27 15:04:33.190,3679,3680,3667,3675,-10642,-10642,-10645,-10645,33.3,31.6,32.3,32.9,22
    2025-05-27 15:04:38.198,3678,3680,3666,3674,-10644,-10645,-10643,-10646,33.3,31.6,32.3,32.9,22
    2025-05-27 15:04:43.210,3678,3679,3666,3675,-10643,-10647,-10645,-10643,33.3,31.7,32.3,33.0,22
    2025-05-27 15:04:48.214,3677,3678,3665,3673,-10640,-10641,-10645,-10645,33.3,31.7,32.3,33.0,21
    2025-05-27 15:04:53.226,3677,3678,3664,3672,-10641,-10641,-10645,-10647,33.3,31.8,32.3,33.0,21
    2025-05-27 15:04:58.226,3676,3677,3664,3671,-10646,-10641,-10645,-10646,33.4,31.7,32.4,33.1,21
    2025-05-27 15:05:03.230,3675,3676,3664,3672,-10650,-10644,-10646,-10649,33.4,31.8,32.4,33.1,21
    2025-05-27 15:05:08.237,3675,3676,3662,3670,-10649,-10644,-10646,-10647,33.5,31.8,32.5,33.2,21
    2025-05-27 15:05:13.245,3674,3675,3662,3669,-10649,-10644,-10643,-10644,33.5,31.9,32.5,33.2,20
    2025-05-27 15:05:18.254,3674,3674,3661,3669,-10649,-10646,-10641,-10651,33.5,31.9,32.5,33.2,20
    2025-05-27 15:05:23.262,3673,3674,3662,3669,-10649,-10643,-10641,-10653,33.5,31.9,32.5,33.3,20
    2025-05-27 15:05:28.264,3673,3673,3660,3668,-10645,-10643,-10641,-10648,33.6,31.9,32.6,33.3,20
    2025-05-27 15:05:33.277,3672,3672,3659,3667,-10645,-10645,-10644,-10647,33.6,31.9,32.6,33.4,20
    2025-05-27 15:05:38.289,3671,3672,3658,3666,-10646,-10649,-10646,-10650,33.7,31.9,32.6,33.4,19
    2025-05-27 15:05:43.314,3671,3671,3659,3667,-10647,-10651,-10655,-10648,33.7,31.9,32.6,33.4,19
    2025-05-27 15:05:48.305,3670,3670,3657,3665,-10646,-10645,-10646,-10649,33.7,32.0,32.8,33.4,19
    2025-05-27 15:05:53.313,3669,3669,3656,3665,-10643,-10647,-10646,-10647,33.7,32.0,32.8,33.5,19
    2025-05-27 15:05:58.323,3669,3669,3655,3664,-10642,-10647,-10645,-10656,33.7,32.1,32.8,33.5,19
    2025-05-27 15:06:03.379,3668,3668,3655,3664,-10648,-10647,-10649,-10654,33.8,32.1,32.8,33.5,18
    2025-05-27 15:06:08.341,3667,3667,3654,3662,-10650,-10649,-10655,-10655,33.8,32.1,32.8,33.5,18
    2025-05-27 15:06:13.349,3666,3666,3653,3662,-10650,-10647,-10650,-10657,33.8,32.1,32.8,33.5,18
    2025-05-27 15:06:18.362,3666,3665,3652,3661,-10648,-10647,-10653,-10655,33.8,32.2,32.8,33.6,18
    2025-05-27 15:06:23.438,3665,3665,3652,3660,-10647,-10647,-10652,-10656,33.9,32.2,32.9,33.6,18
    2025-05-27 15:06:28.380,3664,3664,3650,3659,-10647,-10648,-10650,-10653,33.9,32.2,32.9,33.6,17
    2025-05-27 15:06:33.388,3663,3663,3649,3658,-10645,-10648,-10652,-10652,34.0,32.3,32.9,33.7,17
    2025-05-27 15:06:38.401,3662,3662,3649,3657,-10646,-10647,-10646,-10650,34.0,32.3,33.0,33.7,17
    2025-05-27 15:06:43.485,3662,3662,3648,3657,-10647,-10651,-10650,-10654,34.0,32.3,33.0,33.7,17
    2025-05-27 15:06:48.406,3661,3660,3647,3655,-10647,-10649,-10648,-10659,34.1,32.3,33.0,33.7,17
    2025-05-27 15:06:53.421,3660,3659,3646,3654,-10647,-10647,-10647,-10654,34.1,32.3,33.0,33.8,16
    2025-05-27 15:06:58.424,3659,3658,3645,3653,-10655,-10649,-10646,-10656,34.1,32.4,33.1,33.8,16
    2025-05-27 15:07:03.516,3659,3658,3645,3653,-10653,-10652,-10647,-10652,34.1,32.4,33.1,33.9,16
    2025-05-27 15:07:08.440,3657,3656,3643,3651,-10649,-10648,-10649,-10652,34.1,32.5,33.2,33.9,16
    2025-05-27 15:07:13.449,3657,3655,3642,3651,-10653,-10648,-10649,-10652,34.2,32.5,33.2,33.8,16
    2025-05-27 15:07:18.454,3656,3654,3641,3650,-10654,-10648,-10651,-10652,34.3,32.5,33.3,33.9,15
    2025-05-27 15:07:23.560,3655,3654,3640,3649,-10652,-10651,-10655,-10653,34.3,32.5,33.3,33.9,15
    2025-05-27 15:07:28.474,3654,3651,3638,3648,-10650,-10650,-10652,-10648,34.3,32.5,33.3,33.9,15
    2025-05-27 15:07:33.485,3652,3650,3637,3647,-10648,-10648,-10648,-10651,34.3,32.6,33.4,34.0,15
    2025-05-27 15:07:38.495,3652,3649,3636,3645,-10648,-10649,-10650,-10653,34.4,32.6,33.4,34.0,15
    2025-05-27 15:07:43.610,3651,3648,3635,3645,-10651,-10649,-10650,-10653,34.5,32.6,33.4,34.1,14
    2025-05-27 15:07:48.516,3649,3646,3634,3643,-10655,-10651,-10648,-10659,34.5,32.7,33.4,34.2,14
    2025-05-27 15:07:53.520,3648,3645,3632,3642,-10651,-10652,-10647,-10660,34.5,32.7,33.4,34.2,14
    2025-05-27 15:07:58.530,3647,3644,3631,3641,-10653,-10648,-10648,-10658,34.5,32.8,33.5,34.2,14
    2025-05-27 15:08:03.656,3646,3643,3631,3640,-10655,-10653,-10655,-10656,34.5,32.8,33.5,34.2,14
    2025-05-27 15:08:08.545,3645,3641,3629,3638,-10652,-10652,-10652,-10655,34.5,32.8,33.5,34.2,13
    2025-05-27 15:08:13.559,3643,3639,3627,3637,-10653,-10648,-10651,-10652,34.7,32.8,33.6,34.3,13
    2025-05-27 15:08:18.567,3642,3637,3626,3635,-10656,-10653,-10653,-10655,34.7,32.8,33.6,34.4,13
    2025-05-27 15:08:23.686,3641,3637,3626,3635,-10655,-10654,-10653,-10655,34.7,32.8,33.6,34.4,13
    2025-05-27 15:08:28.582,3639,3634,3624,3632,-10662,-10651,-10654,-10653,34.7,32.9,33.6,34.4,12
    2025-05-27 15:08:33.587,3638,3632,3623,3631,-10659,-10654,-10651,-10653,34.7,32.9,33.7,34.4,12
    2025-05-27 15:08:38.599,3636,3631,3621,3629,-10659,-10658,-10655,-10659,34.7,32.9,33.7,34.4,12
    2025-05-27 15:08:43.751,3635,3630,3620,3628,-10657,-10655,-10658,-10660,34.8,32.9,33.8,34.5,12
    2025-05-27 15:08:48.613,3633,3627,3619,3626,-10656,-10658,-10656,-10653,34.8,33.0,33.8,34.5,12
    2025-05-27 15:08:53.628,3631,3626,3617,3625,-10655,-10660,-10654,-10657,34.9,33.0,33.8,34.6,11
    2025-05-27 15:08:58.640,3630,3624,3616,3623,-10653,-10660,-10656,-10655,34.9,33.0,33.8,34.6,11
    2025-05-27 15:09:03.780,3629,3622,3615,3622,-10660,-10659,-10661,-10656,34.9,33.1,33.8,34.7,11
    2025-05-27 15:09:08.655,3626,3620,3613,3620,-10660,-10662,-10658,-10656,35.0,33.1,33.9,34.7,11
    2025-05-27 15:09:13.655,3625,3618,3611,3618,-10658,-10660,-10654,-10656,35.0,33.2,33.9,34.7,11
    2025-05-27 15:09:18.668,3623,3616,3611,3617,-10655,-10661,-10653,-10656,35.0,33.2,33.9,34.8,10
    2025-05-27 15:09:23.829,3622,3614,3608,3615,-10655,-10655,-10657,-10657,35.0,33.2,34.0,34.8,10
    2025-05-27 15:09:28.681,3619,3612,3606,3611,-10656,-10655,-10656,-10659,35.0,33.3,34.0,34.9,10
    2025-05-27 15:09:33.693,3617,3609,3605,3612,-10657,-10658,-10660,-10658,35.1,33.3,34.0,34.8,10
    2025-05-27 15:09:38.701,3615,3607,3603,3610,-10657,-10656,-10664,-10658,35.1,33.3,34.0,34.8,10
    2025-05-27 15:09:43.876,3614,3605,3601,3608,-10656,-10660,-10656,-10657,35.1,33.3,34.1,34.9,9
    2025-05-27 15:09:48.723,3611,3602,3599,3606,-10656,-10653,-10659,-10658,35.2,33.4,34.1,35.0,9
    2025-05-27 15:09:53.730,3609,3599,3597,3604,-10658,-10653,-10657,-10661,35.2,33.4,34.1,35.0,9
    2025-05-27 15:09:58.735,3607,3597,3594,3600,-10660,-10653,-10659,-10663,35.2,33.4,34.1,34.9,9
    2025-05-27 15:10:03.922,3605,3595,3592,3600,-10660,-10661,-10655,-10659,35.2,33.4,34.2,35.0,9
    2025-05-27 15:10:08.755,3602,3591,3589,3596,-10660,-10654,-10659,-10670,35.3,33.4,34.3,35.0,8
    2025-05-27 15:10:13.766,3599,3588,3587,3595,-10660,-10654,-10657,-10665,35.3,33.4,34.3,35.1,8
    2025-05-27 15:10:18.774,3597,3584,3584,3593,-10662,-10659,-10660,-10667,35.4,33.5,34.3,35.1,8
    2025-05-27 15:10:23.966,3595,3582,3581,3590,-10657,-10659,-10656,-10656,35.4,33.5,34.4,35.1,8
    2025-05-27 15:10:28.788,3591,3578,3578,3586,-10657,-10662,-10658,-10662,35.4,33.5,34.4,35.1,8
    2025-05-27 15:10:33.794,3588,3575,3575,3583,-10658,-10659,-10658,-10661,35.4,33.6,34.4,35.0,7
    2025-05-27 15:10:38.801,3585,3571,3571,3580,-10661,-10662,-10652,-10665,35.4,33.6,34.4,35.0,7
    2025-05-27 15:10:44.031,3583,3567,3568,3579,-10658,-10658,-10659,-10660,35.4,33.6,34.4,35.1,7
    2025-05-27 15:10:48.821,3579,3564,3564,3574,-10663,-10660,-10657,-10663,35.4,33.6,34.4,35.0,7
    2025-05-27 15:10:53.829,3576,3560,3560,3570,-10663,-10662,-10660,-10665,35.4,33.6,34.4,35.1,7
    2025-05-27 15:10:58.834,3572,3556,3556,3567,-10663,-10659,-10655,-10665,35.4,33.6,34.5,35.1,6
    2025-05-27 15:11:04.077,3569,3553,3552,3566,-10657,-10657,-10661,-10655,35.4,33.7,34.5,35.1,6
    2025-05-27 15:11:08.855,3565,3549,3548,3560,-10662,-10659,-10659,-10661,35.5,33.7,34.5,35.2,6
    2025-05-27 15:11:13.865,3561,3545,3544,3556,-10662,-10661,-10661,-10663,35.5,33.7,34.5,35.2,6
    2025-05-27 15:11:18.874,3558,3541,3539,3552,-10662,-10664,-10663,-10664,35.6,33.7,34.5,35.2,6
    2025-05-27 15:11:24.127,3554,3537,3534,3550,-10661,-10661,-10662,-10664,35.5,33.7,34.5,35.2,5
    2025-05-27 15:11:28.895,3550,3533,3530,3546,-10659,-10664,-10659,-10661,35.5,33.7,34.5,35.2,5
    2025-05-27 15:11:33.904,3546,3529,3526,3540,-10663,-10666,-10659,-10664,35.5,33.7,34.5,35.2,5
    2025-05-27 15:11:38.919,3542,3525,3521,3536,-10658,-10666,-10657,-10667,35.5,33.7,34.5,35.3,5
    2025-05-27 15:11:44.173,3539,3521,3516,3532,-10660,-10659,-10654,-10663,35.6,33.8,34.7,35.4,4
    2025-05-27 15:11:48.936,3535,3517,3511,3528,-10665,-10661,-10661,-10666,35.5,33.8,34.7,35.4,4
    2025-05-27 15:11:53.947,3530,3513,3506,3524,-10663,-10660,-10662,-10668,35.6,33.8,34.7,35.4,4
    2025-05-27 15:11:58.958,3527,3509,3501,3519,-10664,-10659,-10664,-10668,35.6,33.8,34.7,35.4,4
    2025-05-27 15:12:04.216,3523,3505,3495,3517,-10660,-10655,-10662,-10658,35.5,33.7,34.7,35.4,4
    2025-05-27 15:12:08.968,3519,3501,3490,3513,-10661,-10659,-10664,-10661,35.5,33.8,34.7,35.4,3
    2025-05-27 15:12:13.979,3515,3496,3485,3506,-10660,-10664,-10663,-10663,35.6,33.8,34.7,35.4,3
    2025-05-27 15:12:18.991,3511,3492,3479,3501,-10662,-10661,-10659,-10661,35.6,33.8,34.7,35.4,3
    2025-05-27 15:12:24.279,3507,3487,3473,3497,-10662,-10662,-10657,-10659,35.6,33.8,34.8,35.4,3
    2025-05-27 15:12:29.008,3502,3483,3468,3492,-10659,-10663,-10658,-10664,35.6,33.8,34.7,35.4,3
    2025-05-27 15:12:34.014,3498,3478,3462,3487,-10661,-10661,-10661,-10666,35.6,33.8,34.7,35.4,2
    2025-05-27 15:12:39.026,3494,3474,3455,3482,-10655,-10662,-10659,-10667,35.5,33.8,34.8,35.4,2
    2025-05-27 15:12:44.328,3490,3468,3448,3477,-10665,-10660,-10661,-10661,35.6,33.8,34.8,35.3,2
    2025-05-27 15:12:49.036,3486,3464,3442,3472,-10666,-10662,-10660,-10672,35.6,33.9,34.8,35.3,2
    2025-05-27 15:12:54.044,3481,3458,3435,3466,-10663,-10663,-10662,-10666,35.5,33.9,34.8,35.4,1
    2025-05-27 15:12:59.055,3477,3453,3428,3460,-10663,-10659,-10662,-10665,35.5,33.9,34.8,35.3,1
    2025-05-27 15:13:04.360,3472,3447,3420,3455,-10668,-10660,-10657,-10660,35.6,33.9,34.8,35.4,1
    2025-05-27 15:13:09.070,3467,3441,3413,3448,-10661,-10655,-10661,-10664,35.6,33.9,34.8,35.4,1
    2025-05-27 15:13:14.078,3462,3434,3405,3442,-10666,-10659,-10661,-10666,35.6,33.9,34.8,35.4,0
    2025-05-27 15:13:19.088,3457,3428,3397,3435,-10663,-10656,-10664,-10667,35.5,33.9,34.8,35.4,0
    2025-05-27 15:13:24.407,3452,3421,3387,3427,-10666,-10670,-10662,-10662,35.5,33.9,34.9,35.4,0
    2025-05-27 15:13:29.109,3447,3414,3379,3423,-10664,-10659,-10661,-10666,35.5,33.9,34.8,35.4,0
    2025-05-27 15:13:34.115,3441,3406,3369,3413,-10665,-10661,-10659,-10668,35.6,33.9,34.9,35.4,0
    2025-05-27 15:13:39.126,3435,3398,3360,3405,-10664,-10661,-10657,-10666,35.6,34.0,34.9,35.4,0
    2025-05-27 15:13:44.439,3428,3390,3349,3396,-10665,-10671,-10660,-10660,35.5,34.0,34.9,35.4,0
    2025-05-27 15:13:49.141,3422,3381,3339,3388,-10665,-10658,-10657,-10663,35.5,34.0,34.9,35.4,0
    2025-05-27 15:13:54.151,3415,3373,3328,3380,-10662,-10663,-10660,-10666,35.5,34.0,34.9,35.4,0
    2025-05-27 15:13:59.166,3408,3363,3317,3370,-10664,-10665,-10656,-10667,35.5,34.0,34.9,35.4,0
    2025-05-27 15:14:04.469,3400,3353,3304,3360,-10662,-10666,-10666,-10665,35.5,34.0,34.9,35.4,0
    2025-05-27 15:14:09.178,3393,3343,3292,3351,-10663,-10668,-10661,-10667,35.4,34.0,34.9,35.4,0
    2025-05-27 15:14:14.185,3384,3333,3279,3340,-10664,-10665,-10663,-10667,35.4,34.0,35.0,35.4,0
    2025-05-27 15:14:19.186,3376,3322,3265,3329,-10660,-10666,-10666,-10665,35.4,34.0,35.0,35.4,0
    2025-05-27 15:14:24.517,3367,3310,3250,3317,-10661,-10664,-10664,-10664,35.4,34.0,35.0,35.5,0
    2025-05-27 15:14:29.205,3358,3298,3236,3306,-10662,-10664,-10662,-10661,35.5,34.1,35.0,35.4,0
    2025-05-27 15:14:34.219,3348,3286,3219,3293,-10665,-10662,-10661,-10667,35.5,34.1,35.0,35.4,0
    2025-05-27 15:14:39.229,3338,3273,3202,3280,-10663,-10669,-10663,-10666,35.5,34.1,35.0,35.4,0
    2025-05-27 15:14:44.524,3327,3258,3183,3268,-10663,-10660,-10670,-10672,35.5,34.1,35.0,35.4,0
    2025-05-27 15:14:49.255,3317,3244,3164,3252,-10669,-10663,-10664,-10664,35.6,34.1,35.0,35.5,0
    2025-05-27 15:14:54.264,3305,3228,3142,3237,-10664,-10661,-10666,-10663,35.6,34.1,35.0,35.5,0
    2025-05-27 15:14:59.267,3293,3211,3119,3221,-10665,-10658,-10667,-10665,35.6,34.2,35.0,35.5,0
    2025-05-27 15:15:04.564,3280,3193,3092,3205,-10662,-10666,-10665,-10667,35.7,34.1,35.1,35.6,0
    2025-05-27 15:15:09.286,3267,3175,3065,3185,-10664,-10668,-10664,-10665,35.8,34.2,35.1,35.6,0
    2025-05-27 15:15:14.297,3254,3155,3033,3166,-10663,-10669,-10662,-10668,35.8,34.3,35.1,35.7,0
    2025-05-27 15:15:19.305,3239,3133,2996,3145,-10665,-10667,-10664,-10672,35.7,34.3,35.1,35.7,0
    2025-05-27 15:15:24.626,3223,3108,2949,3121,-10667,-10670,-10665,-10666,35.7,34.3,35.2,35.7,0
    2025-05-27 15:15:29.317,3207,3083,2894,3098,-10671,-10665,-10665,-10671,35.8,34.3,35.2,35.7,0
    2025-05-27 15:15:34.325,3190,3054,2810,3071,-10669,-10663,-10661,-10669,35.8,34.3,35.1,35.7,0
    2025-05-27 15:15:39.336,,,,,,,,,,,,,
    2025-05-27 15:15:44.659,3230,3085,2766,3103,25956,,,,,34.3,35.2,35.7,0
    2025-05-27 19:35:38.210,4165,4144,4181,4181,0,0,0,0,26.4,26.3,26.1,26.5,100
    2025-05-27 19:35:43.214,4165,4144,4181,4181,0,0,0,0,26.4,26.2,26.0,26.4,100
    2025-05-27 19:35:48.217,4113,4097,4123,4120,-10486,-10485,-10484,-10486,26.4,26.3,26.1,26.4,100
    2025-05-27 19:35:53.228,4105,4089,4115,4112,-10490,-10488,-10494,-10490,26.4,26.3,26.1,26.5,100
    2025-05-27 19:35:58.233,4100,4083,4110,4108,-10493,-10489,-10494,-10489,26.4,26.3,26.1,26.5,100
    2025-05-27 19:36:03.234,4096,4079,4106,4104,-10496,-10496,-10496,-10491,26.4,26.3,26.2,26.5,99
    2025-05-27 19:36:08.249,4093,4075,4103,4100,-10498,-10497,-10497,-10493,26.5,26.3,26.2,26.5,99
    2025-05-27 19:36:13.250,4090,4072,4100,4097,-10502,-10501,-10499,-10503,26.5,26.4,26.2,26.5,99
    2025-05-27 19:36:18.253,4087,4070,4097,4095,-10500,-10504,-10506,-10507,26.5,26.4,26.2,26.6,99
    2025-05-27 19:36:23.255,4085,4067,4095,4092,-10505,-10507,-10511,-10503,26.5,26.4,26.3,26.6,99
    2025-05-27 19:36:28.258,4083,4065,4093,4092,-10510,-10510,-10510,-10506,26.5,26.5,26.3,26.6,98
    2025-05-27 19:36:33.263,4080,4062,4091,4089,-10511,-10510,-10513,-10508,26.6,26.5,26.3,26.7,98
    2025-05-27 19:36:38.268,4078,4060,4088,4087,-10513,-10513,-10510,-10510,26.6,26.5,26.3,26.7,98
    2025-05-27 19:36:43.273,4076,4058,4086,4085,-10515,-10509,-10513,-10515,26.7,26.5,26.4,26.7,98
    2025-05-27 19:36:48.280,4074,4056,4084,4083,-10517,-10512,-10513,-10513,26.7,26.6,26.4,26.8,98
    2025-05-27 19:36:53.291,4072,4054,4082,4081,-10517,-10515,-10514,-10519,26.7,26.6,26.4,26.8,97
    2025-05-27 19:36:58.304,4070,4052,4080,4079,-10518,-10512,-10514,-10517,26.8,26.6,26.5,26.8,97
    2025-05-27 19:37:03.313,4068,4050,4078,4077,-10520,-10515,-10518,-10522,26.8,26.7,26.5,26.9,97
    2025-05-27 19:37:08.322,4066,4047,4076,4075,-10516,-10523,-10518,-10521,26.8,26.7,26.5,26.9,97
    2025-05-27 19:37:13.331,4064,4045,4074,4073,-10521,-10523,-10521,-10522,26.9,26.7,26.6,26.9,97
    2025-05-27 19:37:18.346,4062,4044,4073,4070,-10524,-10524,-10522,-10521,26.9,26.7,26.6,27.0,96
    2025-05-27 19:37:23.356,4060,4042,4071,4068,-10527,-10529,-10521,-10525,27.0,26.8,26.6,27.0,96
    2025-05-27 19:37:28.368,4058,4040,4069,4066,-10522,-10528,-10529,-10525,27.0,26.8,26.6,27.0,96
    2025-05-27 19:37:33.380,4057,4038,4067,4064,-10524,-10521,-10527,-10530,27.0,26.8,26.7,27.1,96
    2025-05-27 19:37:38.387,4055,4036,4065,4062,-10524,-10521,-10527,-10528,27.1,26.9,26.7,27.1,96
    2025-05-27 19:37:43.394,4053,4034,4063,4060,-10525,-10522,-10532,-10528,27.1,26.9,26.7,27.1,95
    2025-05-27 19:37:48.400,4051,4032,4061,4058,-10527,-10522,-10527,-10533,27.1,26.9,26.8,27.2,95
    2025-05-27 19:37:53.413,4049,4030,4059,4056,-10532,-10526,-10526,-10528,27.2,27.0,26.8,27.2,95
    2025-05-27 19:37:58.414,4047,4029,4057,4054,-10530,-10528,-10525,-10528,27.2,27.0,26.8,27.3,95
    2025-05-27 19:38:03.416,4045,4027,4055,4052,-10532,-10529,-10526,-10526,27.3,27.0,26.8,27.3,95
    2025-05-27 19:38:08.428,4043,4025,4053,4051,-10530,-10524,-10527,-10530,27.3,27.0,26.9,27.4,94
    2025-05-27 19:38:13.435,4042,4024,4052,4049,-10529,-10536,-10524,-10533,27.4,27.1,26.9,27.4,94
    2025-05-27 19:38:18.447,4040,4022,4050,4047,-10531,-10531,-10532,-10528,27.4,27.1,26.9,27.4,94
    2025-05-27 19:38:23.451,4038,4021,4048,4045,-10533,-10531,-10529,-10529,27.4,27.1,27.0,27.5,94
    2025-05-27 19:38:28.461,4036,4019,4046,4043,-10534,-10530,-10533,-10531,27.5,27.2,27.0,27.5,94
    2025-05-27 19:38:33.466,4034,4018,4044,4041,-10536,-10534,-10536,-10536,27.5,27.2,27.0,27.5,93
    2025-05-27 19:38:38.470,4033,4017,4042,4040,-10535,-10529,-10536,-10537,27.5,27.2,27.1,27.6,93
    2025-05-27 19:38:43.474,4031,4015,4041,4037,-10538,-10533,-10534,-10540,27.6,27.3,27.1,27.6,93
    2025-05-27 19:38:48.484,4029,4014,4039,4036,-10536,-10537,-10538,-10542,27.6,27.4,27.1,27.6,93
    2025-05-27 19:38:53.488,4027,4013,4037,4034,-10533,-10537,-10536,-10541,27.6,27.4,27.1,27.7,93
    2025-05-27 19:38:58.494,4025,4012,4035,4032,-10536,-10543,-10537,-10539,27.7,27.4,27.2,27.6,93
    2025-05-27 19:39:03.507,4024,4010,4033,4030,-10538,-10539,-10539,-10542,27.6,27.5,27.2,27.7,92
    2025-05-27 19:39:08.518,4022,4009,4031,4029,-10538,-10535,-10533,-10539,27.6,27.5,27.2,27.7,92
    2025-05-27 19:39:13.533,4020,4007,4030,4027,-10538,-10535,-10539,-10537,27.8,27.6,27.2,27.8,92
    2025-05-27 19:39:18.544,4019,4006,4028,4025,-10538,-10532,-10540,-10535,27.8,27.6,27.4,27.8,92
    2025-05-27 19:39:23.548,4018,4004,4026,4024,-10540,-10535,-10540,-10540,27.8,27.6,27.4,27.8,92
    2025-05-27 19:39:28.562,4016,4002,4024,4022,-10538,-10538,-10542,-10541,27.9,27.7,27.4,27.9,91
    2025-05-27 19:39:33.571,4015,4001,4022,4020,-10535,-10541,-10543,-10545,27.9,27.7,27.4,27.9,91
    2025-05-27 19:39:38.579,4014,3999,4021,4020,-10538,-10542,-10542,-10545,27.9,27.8,27.5,27.9,91
    2025-05-27 19:39:43.594,4012,3997,4019,4018,-10543,-10538,-10543,-10542,28.0,27.8,27.4,28.0,91
    2025-05-27 19:39:48.602,4011,3994,4017,4017,-10541,-10546,-10534,-10544,28.0,27.9,27.5,28.0,91
    2025-05-27 19:39:53.605,4010,3992,4016,4015,-10540,-10547,-10543,-10544,28.1,27.9,27.5,28.0,90
    2025-05-27 19:39:58.608,4009,3990,4014,4013,-10543,-10547,-10544,-10541,28.1,27.9,27.5,28.1,90
    2025-05-27 19:40:03.610,4008,3987,4012,4012,-10545,-10545,-10540,-10542,28.2,27.9,27.6,28.1,90
    2025-05-27 19:40:08.615,4007,3985,4011,4010,-10544,-10542,-10541,-10545,28.2,28.0,27.6,28.2,90
    2025-05-27 19:40:13.628,4005,3982,4009,4009,-10549,-10543,-10543,-10552,28.2,28.0,27.6,28.2,90
    2025-05-27 19:40:18.641,4004,3979,4008,4007,-10544,-10543,-10546,-10549,28.3,28.1,27.7,28.2,89
    2025-05-27 19:40:23.646,4003,3976,4007,4006,-10546,-10543,-10548,-10545,28.3,28.1,27.7,28.3,89
    2025-05-27 19:40:28.652,4001,3973,4006,4004,-10546,-10548,-10545,-10545,28.4,28.1,27.7,28.3,89
    2025-05-27 19:40:33.663,3999,3970,4005,4002,-10546,-10546,-10547,-10548,28.4,28.2,27.8,28.3,89
    2025-05-27 19:40:38.668,3998,3967,4003,4001,-10544,-10546,-10545,-10551,28.5,28.2,27.8,28.4,89
    2025-05-27 19:40:43.677,3996,3965,4002,4000,-10547,-10549,-10543,-10551,28.6,28.2,27.8,28.4,88
    2025-05-27 19:40:48.686,3994,3962,4001,3999,-10549,-10548,-10546,-10553,28.5,28.2,27.9,28.5,88
    2025-05-27 19:40:53.692,3992,3959,4000,3998,-10546,-10544,-10544,-10546,28.6,28.2,27.9,28.5,88
    2025-05-27 19:40:58.693,3990,3956,3999,3997,-10547,-10549,-10543,-10544,28.6,28.2,28.0,28.6,88
    2025-05-27 19:41:03.697,3988,3954,3997,3996,-10548,-10549,-10548,-10546,28.7,28.2,28.0,28.6,88
    2025-05-27 19:41:08.708,3985,3951,3996,3994,-10553,-10549,-10548,-10544,28.7,28.2,28.0,28.6,87
    2025-05-27 19:41:13.715,3983,3948,3995,3993,-10552,-10547,-10550,-10543,28.7,28.3,28.1,28.7,87
    2025-05-27 19:41:18.721,3980,3946,3993,3991,-10552,-10551,-10550,-10547,28.7,28.3,28.1,28.7,87
    2025-05-27 19:41:23.735,3977,3943,3992,3991,-10546,-10551,-10549,-10549,28.8,28.3,28.2,28.7,87
    2025-05-27 19:41:28.750,3974,3941,3990,3988,-10548,-10552,-10551,-10551,28.8,28.3,28.2,28.7,87
    2025-05-27 19:41:33.765,3971,3938,3988,3986,-10546,-10549,-10551,-10551,28.8,28.3,28.2,28.8,86
    2025-05-27 19:41:38.780,3969,3936,3986,3984,-10547,-10552,-10549,-10550,28.8,28.3,28.3,28.9,86
    2025-05-27 19:41:43.781,3966,3934,3984,3982,-10548,-10549,-10554,-10553,28.9,28.3,28.3,29.0,86
    2025-05-27 19:41:48.788,3963,3931,3982,3980,-10551,-10546,-10554,-10555,28.9,28.3,28.4,29.0,86
    2025-05-27 19:41:53.796,3960,3929,3979,3977,-10548,-10549,-10554,-10550,28.9,28.3,28.4,29.0,86
    2025-05-27 19:41:58.808,3957,3927,3977,3975,-10553,-10551,-10554,-10553,29.0,28.3,28.5,29.1,86
    2025-05-27 19:42:03.821,3954,3925,3974,3973,-10556,-10554,-10554,-10553,29.0,28.3,28.5,29.1,85
    2025-05-27 19:42:08.837,3952,3923,3971,3970,-10556,-10553,-10554,-10552,29.0,28.3,28.6,29.1,85
    2025-05-27 19:42:13.842,3949,3922,3969,3967,-10550,-10552,-10552,-10552,29.0,28.3,28.5,29.2,85
    2025-05-27 19:42:18.856,3947,3920,3966,3964,-10553,-10555,-10548,-10553,29.0,28.3,28.5,29.2,85
    2025-05-27 19:42:23.859,3944,3918,3963,3961,-10554,-10560,-10549,-10554,29.0,28.3,28.6,29.2,85
    2025-05-27 19:42:28.864,3942,3916,3960,3958,-10557,-10556,-10559,-10553,29.0,28.3,28.6,29.2,84
    2025-05-27 19:42:33.872,3939,3914,3957,3955,-10550,-10556,-10560,-10552,29.0,28.3,28.6,29.2,84
    2025-05-27 19:42:38.874,3937,3913,3954,3953,-10554,-10555,-10559,-10554,29.0,28.3,28.6,29.3,84
    2025-05-27 19:42:43.884,3935,3911,3951,3950,-10561,-10552,-10557,-10557,29.0,28.3,28.6,29.3,84
    2025-05-27 19:42:48.897,3933,3909,3948,3947,-10556,-10557,-10557,-10559,29.0,28.3,28.6,29.3,84
    2025-05-27 19:42:53.909,3930,3908,3946,3944,-10560,-10556,-10561,-10561,29.0,28.3,28.7,29.3,83
    2025-05-27 19:42:58.916,3928,3906,3943,3943,-10560,-10558,-10558,-10564,29.0,28.3,28.7,29.3,83
    2025-05-27 19:43:03.924,3926,3905,3940,3941,-10556,-10560,-10557,-10563,29.0,28.3,28.7,29.3,83
    2025-05-27 19:43:08.933,3924,3903,3938,3938,-10560,-10553,-10556,-10560,29.0,28.3,28.7,29.3,83
    2025-05-27 19:43:13.946,3923,3902,3935,3936,-10555,-10555,-10551,-10560,29.0,28.3,28.7,29.3,83
    2025-05-27 19:43:18.955,3921,3901,3933,3933,-10558,-10553,-10555,-10560,28.9,28.3,28.7,29.3,82
    2025-05-27 19:43:23.961,3919,3899,3930,3931,-10556,-10553,-10555,-10556,29.0,28.3,28.7,29.3,82
    2025-05-27 19:43:28.963,3917,3898,3928,3928,-10556,-10554,-10555,-10560,28.9,28.3,28.7,29.3,82
    2025-05-27 19:43:33.972,3916,3896,3926,3927,-10556,-10561,-10560,-10561,29.0,28.3,28.7,29.3,82
    2025-05-27 19:43:38.983,3914,3895,3924,3924,-10553,-10558,-10556,-10563,28.9,28.3,28.7,29.3,82
    2025-05-27 19:43:43.991,3912,3894,3922,3921,-10556,-10554,-10551,-10562,29.0,28.3,28.7,29.3,81
    2025-05-27 19:43:48.994,3910,3892,3920,3919,-10560,-10558,-10553,-10560,28.9,28.3,28.7,29.3,81
    2025-05-27 19:43:53.998,3909,3891,3918,3917,-10560,-10555,-10555,-10560,28.9,28.3,28.7,29.3,81
    2025-05-27 19:43:59.003,3908,3890,3916,3915,-10560,-10553,-10557,-10557,28.9,28.2,28.7,29.3,81
    2025-05-27 19:44:04.005,3906,3888,3914,3913,-10560,-10557,-10556,-10560,28.9,28.2,28.7,29.3,81
    2025-05-27 19:44:09.020,3905,3887,3912,3912,-10556,-10560,-10561,-10556,28.9,28.2,28.7,29.2,80
    2025-05-27 19:44:14.032,3904,3886,3910,3910,-10555,-10560,-10557,-10561,29.0,28.2,28.6,29.2,80
    2025-05-27 19:44:19.035,3902,3885,3908,3908,-10555,-10560,-10555,-10561,28.9,28.2,28.6,29.3,80
    2025-05-27 19:44:24.047,3901,3884,3907,3906,-10562,-10562,-10556,-10557,28.9,28.2,28.6,29.2,80
    2025-05-27 19:44:29.051,3900,3882,3905,3905,-10560,-10562,-10558,-10559,28.8,28.2,28.6,29.2,80
    2025-05-27 19:44:34.058,3898,3881,3904,3903,-10558,-10562,-10558,-10560,28.8,28.2,28.6,29.2,79
    2025-05-27 19:44:39.068,3897,3879,3902,3902,-10556,-10558,-10557,-10562,28.8,28.2,28.6,29.1,79
    2025-05-27 19:44:44.075,3896,3878,3901,3900,-10561,-10559,-10561,-10563,28.8,28.2,28.6,29.1,79
    2025-05-27 19:44:49.081,3895,3877,3899,3899,-10558,-10559,-10558,-10560,28.8,28.2,28.6,29.1,79
    2025-05-27 19:44:54.083,3894,3875,3898,3897,-10560,-10558,-10556,-10557,28.8,28.2,28.6,29.1,79
    2025-05-27 19:44:59.097,3892,3874,3896,3896,-10559,-10556,-10555,-10559,28.7,28.2,28.6,29.1,78
    2025-05-27 19:45:04.101,3891,3872,3895,3895,-10558,-10558,-10556,-10558,28.7,28.2,28.6,29.1,78
    2025-05-27 19:45:09.116,3890,3871,3893,3893,-10555,-10558,-10556,-10558,28.7,28.2,28.6,29.1,78
    2025-05-27 19:45:14.128,3889,3870,3892,3892,-10562,-10559,-10560,-10559,28.7,28.3,28.6,29.1,78
    2025-05-27 19:45:19.135,3888,3868,3891,3891,-10562,-10559,-10562,-10563,28.7,28.3,28.6,29.1,78
    2025-05-27 19:45:24.144,3887,3867,3890,3890,-10565,-10559,-10558,-10559,28.7,28.2,28.6,29.1,78
    2025-05-27 19:45:29.157,3885,3866,3888,3888,-10552,-10558,-10560,-10559,28.7,28.3,28.5,29.1,77
    2025-05-27 19:45:34.172,3884,3864,3887,3887,-10553,-10558,-10558,-10560,28.7,28.3,28.5,29.0,77
    2025-05-27 19:45:39.179,3883,3863,3886,3886,-10554,-10559,-10556,-10559,28.7,28.3,28.5,29.0,77
    2025-05-27 19:45:44.192,3882,3862,3885,3885,-10556,-10561,-10558,-10556,28.7,28.3,28.5,29.0,77
    2025-05-27 19:45:49.206,3880,3860,3884,3884,-10555,-10561,-10559,-10563,28.7,28.3,28.5,28.9,77
    2025-05-27 19:45:54.220,3879,3859,3882,3883,-10558,-10560,-10563,-10560,28.7,28.3,28.6,29.0,76
    2025-05-27 19:45:59.227,3878,3857,3881,3882,-10559,-10560,-10561,-10556,28.7,28.3,28.5,28.9,76
    2025-05-27 19:46:04.231,3877,3856,3880,3880,-10556,-10555,-10563,-10559,28.7,28.4,28.5,28.9,76
    2025-05-27 19:46:09.239,3875,3854,3879,3879,-10558,-10552,-10563,-10560,28.7,28.4,28.5,28.9,76
    2025-05-27 19:46:14.243,3874,3853,3878,3880,-10560,-10557,-10562,-10559,28.8,28.4,28.5,28.8,76
    2025-05-27 19:46:19.256,3873,3852,3877,3879,-10558,-10556,-10565,-10563,28.8,28.4,28.5,28.8,75
    2025-05-27 19:46:24.261,3871,3851,3876,3878,-10558,-10559,-10560,-10564,28.8,28.4,28.5,28.8,75
    2025-05-27 19:46:29.264,3870,3849,3874,3876,-10561,-10563,-10563,-10564,28.8,28.5,28.5,28.9,75
    2025-05-27 19:46:34.275,3869,3848,3873,3875,-10561,-10563,-10558,-10561,28.8,28.5,28.5,28.9,75
    2025-05-27 19:46:39.289,3867,3846,3872,3874,-10559,-10559,-10564,-10563,28.8,28.5,28.4,28.8,75
    2025-05-27 19:46:44.294,3866,3845,3870,3873,-10561,-10555,-10562,-10562,28.8,28.5,28.4,28.8,74
    2025-05-27 19:46:49.307,3864,3844,3869,3871,-10564,-10555,-10564,-10564,28.8,28.6,28.4,28.9,74
    2025-05-27 19:46:54.322,3863,3842,3868,3869,-10568,-10558,-10562,-10565,28.9,28.5,28.4,28.9,74
    2025-05-27 19:46:59.336,3862,3841,3867,3868,-10566,-10561,-10560,-10570,28.9,28.5,28.4,28.8,74
    2025-05-27 19:47:04.351,3861,3840,3866,3867,-10568,-10561,-10562,-10567,29.0,28.5,28.5,28.8,74
    2025-05-27 19:47:09.355,3859,3838,3864,3866,-10570,-10561,-10560,-10567,29.0,28.5,28.5,28.8,73
    2025-05-27 19:47:14.366,3858,3837,3863,3864,-10562,-10561,-10558,-10566,29.0,28.6,28.4,28.8,73
    2025-05-27 19:47:19.374,3857,3835,3862,3863,-10557,-10561,-10558,-10566,29.0,28.6,28.4,28.9,73
    2025-05-27 19:47:24.384,3855,3835,3861,3861,-10556,-10567,-10560,-10565,29.0,28.6,28.5,28.9,73
    2025-05-27 19:47:29.394,3854,3833,3859,3860,-10561,-10563,-10560,-10567,29.0,28.6,28.5,28.9,73
    2025-05-27 19:47:34.405,3852,3832,3857,3859,-10563,-10562,-10559,-10565,29.1,28.6,28.5,28.9,72
    2025-05-27 19:47:39.417,3851,3830,3856,3857,-10564,-10556,-10566,-10558,29.1,28.6,28.5,29.0,72
    2025-05-27 19:47:44.422,3850,3829,3855,3856,-10563,-10559,-10563,-10563,29.1,28.6,28.5,29.0,72
    2025-05-27 19:47:49.425,3848,3828,3853,3855,-10566,-10555,-10561,-10559,29.1,28.6,28.5,29.0,72
    2025-05-27 19:47:54.427,3847,3826,3852,3853,-10562,-10562,-10559,-10558,29.2,28.7,28.5,29.0,72
    2025-05-27 19:47:59.430,3846,3825,3851,3852,-10563,-10563,-10567,-10561,29.2,28.7,28.5,29.1,71
    2025-05-27 19:48:04.442,3845,3824,3850,3851,-10558,-10562,-10559,-10560,29.2,28.7,28.5,29.1,71
    2025-05-27 19:48:09.446,3843,3823,3848,3849,-10563,-10563,-10564,-10565,29.2,28.7,28.5,29.1,71
    2025-05-27 19:48:14.457,3842,3821,3847,3848,-10564,-10559,-10560,-10565,29.2,28.7,28.5,29.1,71
    2025-05-27 19:48:19.463,3840,3820,3845,3847,-10563,-10563,-10556,-10563,29.2,28.7,28.6,29.1,71
    2025-05-27 19:48:24.474,3839,3819,3845,3846,-10565,-10562,-10557,-10563,29.2,28.7,28.6,29.1,71
    2025-05-27 19:48:29.476,3838,3818,3843,3844,-10559,-10566,-10567,-10560,29.2,28.7,28.6,29.2,70
    2025-05-27 19:48:34.483,3836,3817,3842,3843,-10564,-10562,-10561,-10560,29.2,28.8,28.6,29.2,70
    2025-05-27 19:48:39.490,3835,3816,3840,3842,-10568,-10565,-10566,-10565,29.3,28.8,28.6,29.2,70
    2025-05-27 19:48:44.516,3834,3814,3839,3840,-10562,-10562,-10561,-10565,29.3,28.8,28.6,29.2,70
    2025-05-27 19:48:49.519,3833,3813,3838,3839,-10563,-10565,-10566,-10568,29.3,28.8,28.7,29.2,70
    2025-05-27 19:48:54.531,3831,3812,3836,3838,-10563,-10563,-10563,-10567,29.3,28.8,28.7,29.2,69
    2025-05-27 19:48:59.536,3830,3811,3835,3836,-10559,-10564,-10564,-10567,29.3,28.8,28.7,29.3,69
    2025-05-27 19:49:04.561,3829,3810,3834,3835,-10557,-10564,-10565,-10565,29.3,28.8,28.7,29.3,69
    2025-05-27 19:49:09.542,3827,3808,3832,3834,-10565,-10562,-10561,-10563,29.3,28.8,28.7,29.3,69
    2025-05-27 19:49:14.551,3826,3807,3831,3833,-10562,-10562,-10557,-10564,29.3,28.9,28.7,29.3,69
    2025-05-27 19:49:19.558,3825,3806,3830,3831,-10564,-10562,-10559,-10565,29.3,28.9,28.8,29.3,68
    2025-05-27 19:49:24.618,3824,3805,3829,3830,-10565,-10559,-10560,-10566,29.3,28.9,28.8,29.3,68
    2025-05-27 19:49:29.566,3822,3804,3827,3829,-10564,-10562,-10562,-10565,29.3,29.0,28.8,29.3,68
    2025-05-27 19:49:34.579,3821,3803,3826,3827,-10563,-10561,-10562,-10565,29.4,29.0,28.8,29.4,68
    2025-05-27 19:49:39.580,3820,3802,3825,3828,-10555,-10562,-10561,-10562,29.4,28.9,28.8,29.3,68
    2025-05-27 19:49:44.667,3819,3801,3824,3826,-10572,-10567,-10562,-10562,29.4,29.0,28.8,29.4,67
    2025-05-27 19:49:49.597,3818,3799,3822,3825,-10557,-10566,-10566,-10562,29.4,29.0,28.8,29.4,67
    2025-05-27 19:49:54.610,3816,3798,3821,3824,-10563,-10564,-10566,-10562,29.4,29.0,28.9,29.4,67
    2025-05-27 19:49:59.625,3815,3797,3820,3823,-10565,-10559,-10562,-10564,29.4,29.0,28.9,29.4,67
    2025-05-27 19:50:04.687,3814,3796,3819,3822,-10560,-10559,-10564,-10564,29.5,29.0,28.9,29.4,67
    2025-05-27 19:50:09.645,3813,3795,3817,3820,-10562,-10556,-10562,-10566,29.5,29.0,28.9,29.5,66
    2025-05-27 19:50:14.651,3812,3794,3816,3819,-10562,-10558,-10566,-10567,29.5,29.0,29.0,29.4,66
    2025-05-27 19:50:19.653,3810,3793,3815,3818,-10562,-10561,-10564,-10566,29.5,29.1,29.0,29.5,66
    2025-05-27 19:50:24.719,3809,3792,3814,3817,-10567,-10563,-10561,-10570,29.5,29.1,29.0,29.5,66
    2025-05-27 19:50:29.669,3808,3791,3812,3816,-10568,-10565,-10565,-10565,29.5,29.1,29.0,29.5,66
    2025-05-27 19:50:34.679,3807,3790,3811,3813,-10564,-10561,-10559,-10566,29.6,29.1,29.0,29.5,65
    2025-05-27 19:50:39.681,3806,3789,3810,3812,-10562,-10570,-10560,-10568,29.6,29.1,29.0,29.6,65
    2025-05-27 19:50:44.765,3805,3788,3809,3810,-10569,-10562,-10560,-10566,29.6,29.1,29.0,29.6,65
    2025-05-27 19:50:49.690,3803,3787,3808,3809,-10560,-10568,-10561,-10563,29.6,29.1,29.1,29.6,65
    2025-05-27 19:50:54.705,3802,3786,3806,3808,-10563,-10564,-10571,-10564,29.6,29.1,29.1,29.6,65
    2025-05-27 19:50:59.719,3801,3785,3805,3807,-10563,-10570,-10569,-10562,29.6,29.1,29.1,29.6,64
    2025-05-27 19:51:04.843,3800,3784,3804,3806,-10567,-10569,-10568,-10562,29.7,29.2,29.1,29.7,64
    2025-05-27 19:51:09.740,3799,3783,3803,3805,-10562,-10566,-10568,-10565,29.6,29.2,29.1,29.7,64
    2025-05-27 19:51:14.743,3798,3782,3802,3803,-10570,-10560,-10568,-10567,29.7,29.2,29.1,29.7,64
    2025-05-27 19:51:19.751,3797,3781,3801,3802,-10568,-10562,-10568,-10568,29.7,29.2,29.2,29.7,64
    2025-05-27 19:51:24.875,3796,3780,3800,3802,-10566,-10562,-10566,-10568,29.7,29.2,29.2,29.7,63
    2025-05-27 19:51:29.772,3795,3779,3798,3800,-10561,-10567,-10569,-10572,29.7,29.2,29.2,29.7,63
    2025-05-27 19:51:34.775,3794,3778,3797,3799,-10561,-10566,-10566,-10572,29.7,29.2,29.2,29.7,63
    2025-05-27 19:51:39.782,3793,3777,3796,3798,-10563,-10569,-10563,-10570,29.7,29.2,29.2,29.7,63
    2025-05-27 19:51:44.923,3792,3776,3795,3797,-10569,-10567,-10566,-10570,29.7,29.3,29.2,29.8,63
    2025-05-27 19:51:49.797,3790,3775,3794,3796,-10566,-10565,-10568,-10565,29.7,29.3,29.2,29.7,63
    2025-05-27 19:51:54.807,3789,3774,3793,3795,-10569,-10565,-10568,-10565,29.8,29.3,29.2,29.8,62
    2025-05-27 19:51:59.810,3788,3773,3792,3793,-10566,-10563,-10566,-10567,29.8,29.3,29.2,29.8,62
    2025-05-27 19:52:04.985,3788,3773,3791,3792,-10565,-10564,-10566,-10566,29.8,29.3,29.3,29.8,62
    2025-05-27 19:52:09.832,3786,3771,3790,3791,-10570,-10564,-10569,-10565,29.8,29.3,29.3,29.8,62
    2025-05-27 19:52:14.839,3785,3770,3788,3790,-10562,-10569,-10566,-10566,29.8,29.3,29.3,29.8,62
    2025-05-27 19:52:19.846,3784,3769,3787,3789,-10566,-10569,-10567,-10567,29.8,29.3,29.3,29.9,61
    2025-05-27 19:52:25.048,3783,3768,3787,3788,-10563,-10572,-10565,-10563,29.8,29.3,29.3,29.9,61
    2025-05-27 19:52:29.860,3782,3767,3785,3787,-10570,-10566,-10563,-10569,29.8,29.4,29.3,29.9,61
    2025-05-27 19:52:34.868,3781,3766,3784,3786,-10569,-10566,-10571,-10562,29.9,29.4,29.3,29.9,61
    2025-05-27 19:52:39.870,3782,3768,3783,3785,-10570,-10570,-10572,-10566,29.9,29.4,29.3,29.9,61
    2025-05-27 19:52:45.109,3779,3765,3782,3784,-10569,-10564,-10566,-10567,29.9,29.4,29.4,30.0,60
    2025-05-27 19:52:49.882,3778,3764,3781,3784,-10569,-10568,-10572,-10569,29.9,29.4,29.4,29.9,60
    2025-05-27 19:52:54.885,3777,3763,3780,3783,-10567,-10571,-10567,-10566,29.9,29.4,29.4,30.0,60
    2025-05-27 19:52:59.900,3776,3762,3779,3782,-10565,-10572,-10566,-10571,29.9,29.4,29.4,30.1,60
    2025-05-27 19:53:05.156,3775,3761,3778,3779,-10569,-10565,-10569,-10566,29.9,29.4,29.4,30.0,60
    2025-05-27 19:53:09.915,3776,3762,3779,3780,-10570,-10569,-10570,-10572,29.9,29.5,29.4,30.0,59
    2025-05-27 19:53:14.921,3773,3759,3776,3779,-10565,-10569,-10569,-10572,29.9,29.5,29.4,30.0,59
    2025-05-27 19:53:19.928,3772,3758,3775,3778,-10567,-10570,-10571,-10572,29.9,29.5,29.4,30.1,59
    2025-05-27 19:53:25.203,3771,3758,3774,3775,-10569,-10566,-10571,-10568,30.0,29.5,29.5,30.0,59
    2025-05-27 19:53:29.942,3770,3757,3773,3776,-10567,-10567,-10571,-10568,30.0,29.5,29.5,30.1,59
    2025-05-27 19:53:34.943,3770,3756,3772,3775,-10567,-10570,-10566,-10572,30.0,29.5,29.5,30.1,58
    2025-05-27 19:53:39.948,3768,3755,3771,3772,-10574,-10567,-10570,-10574,30.1,29.5,29.5,30.1,58
    2025-05-27 19:53:45.250,3768,3754,3770,3773,-10570,-10572,-10572,-10569,30.1,29.6,29.5,30.1,58
    2025-05-27 19:53:49.955,3767,3753,3769,3770,-10567,-10570,-10571,-10569,30.1,29.6,29.5,30.2,58
    2025-05-27 19:53:54.960,3766,3753,3768,3769,-10563,-10568,-10569,-10567,30.1,29.6,29.5,30.2,58
    2025-05-27 19:53:59.966,3765,3752,3767,3768,-10564,-10570,-10566,-10572,30.1,29.6,29.6,30.2,57
    2025-05-27 19:54:05.264,3764,3751,3766,3769,-10573,-10571,-10567,-10577,30.1,29.6,29.6,30.2,57
    2025-05-27 19:54:09.986,3763,3750,3765,3766,-10561,-10568,-10569,-10573,30.1,29.6,29.6,30.2,57
    2025-05-27 19:54:14.994,3762,3749,3764,3765,-10567,-10567,-10569,-10567,30.1,29.7,29.6,30.2,57
    2025-05-27 19:54:20.006,3761,3748,3763,3765,-10568,-10565,-10569,-10566,30.1,29.6,29.6,30.2,57
    2025-05-27 19:54:25.329,3760,3747,3762,3765,-10572,-10570,-10568,-10566,30.1,29.7,29.6,30.2,56
    2025-05-27 19:54:30.017,3759,3747,3761,3763,-10567,-10564,-10569,-10572,30.1,29.7,29.6,30.2,56
    2025-05-27 19:54:35.032,3759,3746,3760,3762,-10569,-10564,-10570,-10570,30.2,29.7,29.7,30.2,56
    2025-05-27 19:54:40.048,3758,3745,3759,3761,-10570,-10563,-10571,-10572,30.2,29.7,29.7,30.2,56
    2025-05-27 19:54:45.360,3757,3745,3758,3760,-10567,-10574,-10570,-10569,30.2,29.7,29.7,30.2,56
    2025-05-27 19:54:50.056,3756,3744,3757,3759,-10572,-10573,-10567,-10572,30.2,29.7,29.7,30.2,55
    2025-05-27 19:54:55.056,3755,3743,3757,3758,-10568,-10578,-10564,-10572,30.3,29.7,29.7,30.2,55
    2025-05-27 19:55:00.070,3754,3742,3755,3757,-10567,-10569,-10570,-10568,30.2,29.7,29.7,30.2,55
    2025-05-27 19:55:05.404,3754,3741,3755,3756,-10571,-10568,-10566,-10575,30.3,29.8,29.7,30.2,55
    2025-05-27 19:55:10.083,3753,3741,3754,3755,-10566,-10572,-10576,-10572,30.2,29.8,29.7,30.2,55
    2025-05-27 19:55:15.087,3752,3740,3753,3754,-10568,-10573,-10574,-10572,30.2,29.8,29.7,30.3,55
    2025-05-27 19:55:20.088,3751,3739,3752,3754,-10570,-10571,-10578,-10571,30.2,29.8,29.8,30.3,54
    2025-05-27 19:55:25.437,3750,3738,3751,3753,-10572,-10568,-10564,-10570,30.2,29.9,29.8,30.3,54
    2025-05-27 19:55:30.094,3749,3737,3750,3752,-10568,-10572,-10574,-10568,30.2,29.8,29.8,30.3,54
    2025-05-27 19:55:35.095,3749,3737,3750,3751,-10574,-10570,-10576,-10573,30.3,29.9,29.8,30.3,54
    2025-05-27 19:55:40.099,3748,3736,3748,3750,-10566,-10570,-10574,-10573,30.3,29.9,29.8,30.4,54
    2025-05-27 19:55:45.488,3747,3735,3748,3749,-10573,-10575,-10571,-10569,30.3,29.9,29.8,30.4,53
    2025-05-27 19:55:50.100,3746,3735,3747,3748,-10565,-10570,-10568,-10564,30.3,29.9,29.9,30.4,53
    2025-05-27 19:55:55.105,3745,3734,3746,3748,-10568,-10569,-10567,-10565,30.3,29.9,29.9,30.4,53
    2025-05-27 19:56:00.109,3745,3733,3745,3747,-10569,-10572,-10569,-10569,30.4,29.9,29.9,30.4,53
    2025-05-27 19:56:05.532,3744,3733,3745,3746,-10570,-10574,-10571,-10569,30.4,30.0,29.9,30.4,53
    2025-05-27 19:56:10.114,3743,3732,3743,3746,-10570,-10574,-10572,-10569,30.4,30.0,29.9,30.5,52
    2025-05-27 19:56:15.115,3742,3731,3742,3745,-10570,-10574,-10572,-10571,30.4,30.0,29.9,30.5,52
    2025-05-27 19:56:20.121,3742,3730,3742,3744,-10575,-10570,-10568,-10568,30.3,30.1,29.9,30.4,52
    2025-05-27 19:56:25.122,3741,3729,3741,3743,-10571,-10569,-10575,-10574,30.3,30.1,29.9,30.5,52
    2025-05-27 19:56:30.129,3740,3729,3740,3743,-10574,-10570,-10574,-10572,30.4,30.1,29.9,30.5,52
    2025-05-27 19:56:35.134,3740,3728,3739,3742,-10569,-10572,-10576,-10572,30.4,30.1,30.0,30.6,51
    2025-05-27 19:56:40.136,3739,3727,3739,3741,-10570,-10568,-10577,-10573,30.4,30.2,30.1,30.6,51
    2025-05-27 19:56:45.143,3738,3727,3738,3739,-10569,-10570,-10574,-10570,30.5,30.2,30.1,30.6,51
    2025-05-27 19:56:50.157,3737,3726,3737,3738,-10566,-10574,-10567,-10575,30.5,30.2,30.0,30.6,51
    2025-05-27 19:56:55.163,3736,3725,3736,3738,-10568,-10574,-10567,-10568,30.5,30.2,30.1,30.6,51
    2025-05-27 19:57:00.178,3736,3724,3735,3737,-10573,-10570,-10568,-10577,30.5,30.2,30.1,30.6,50
    2025-05-27 19:57:05.191,3735,3724,3735,3736,-10573,-10571,-10569,-10577,30.5,30.2,30.1,30.7,50
    2025-05-27 19:57:10.204,3734,3723,3734,3735,-10572,-10571,-10568,-10577,30.6,30.2,30.1,30.6,50
    2025-05-27 19:57:15.214,3734,3722,3733,3735,-10568,-10567,-10571,-10575,30.6,30.3,30.2,30.6,50
    2025-05-27 19:57:20.227,3733,3722,3732,3734,-10570,-10567,-10572,-10572,30.6,30.2,30.2,30.7,50
    2025-05-27 19:57:25.237,3732,3721,3732,3733,-10571,-10566,-10570,-10569,30.6,30.2,30.2,30.7,49
    2025-05-27 19:57:30.239,3731,3720,3731,3732,-10573,-10568,-10568,-10569,30.6,30.3,30.2,30.7,49
    2025-05-27 19:57:35.247,3731,3720,3730,3732,-10571,-10573,-10571,-10564,30.6,30.3,30.2,30.7,49
    2025-05-27 19:57:40.263,3730,3719,3729,3731,-10571,-10573,-10569,-10567,30.7,30.3,30.2,30.7,49
    2025-05-27 19:57:45.265,3729,3719,3728,3730,-10573,-10575,-10570,-10573,30.7,30.3,30.2,30.8,49
    2025-05-27 19:57:50.277,3729,3718,3728,3730,-10573,-10572,-10571,-10570,30.7,30.3,30.3,30.7,48
    2025-05-27 19:57:55.283,3728,3717,3727,3729,-10575,-10573,-10572,-10573,30.7,30.4,30.2,30.7,48
    2025-05-27 19:58:00.289,3727,3717,3727,3728,-10572,-10572,-10572,-10570,30.7,30.3,30.3,30.8,48
    2025-05-27 19:58:05.294,3727,3716,3725,3727,-10570,-10577,-10575,-10570,30.7,30.4,30.2,30.8,48
    2025-05-27 19:58:10.303,3726,3715,3725,3727,-10569,-10575,-10572,-10571,30.7,30.4,30.2,30.8,48
    2025-05-27 19:58:15.312,3725,3715,3724,3726,-10574,-10573,-10572,-10574,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:20.321,3725,3714,3724,3725,-10574,-10571,-10574,-10577,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:25.326,3724,3714,3723,3724,-10567,-10571,-10570,-10576,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:30.335,3724,3713,3722,3724,-10568,-10572,-10575,-10577,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:35.340,3723,3712,3722,3723,-10577,-10572,-10575,-10578,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:40.356,3722,3712,3721,3722,-10578,-10575,-10574,-10576,30.8,30.5,30.3,30.8,47
    2025-05-27 19:58:45.363,3722,3711,3720,3722,-10577,-10574,-10573,-10574,30.8,30.6,30.3,30.8,46
    2025-05-27 19:58:50.374,3721,3710,3720,3721,-10574,-10571,-10571,-10575,30.8,30.6,30.4,30.9,46
    2025-05-27 19:58:55.389,3720,3710,3719,3720,-10575,-10577,-10573,-10573,30.8,30.6,30.4,30.9,46
    2025-05-27 19:59:00.399,3720,3709,3718,3720,-10576,-10580,-10574,-10575,30.9,30.6,30.4,30.9,46
    2025-05-27 19:59:05.411,3720,3709,3717,3719,-10574,-10578,-10571,-10574,30.9,30.7,30.5,30.9,46
    2025-05-27 19:59:10.424,3719,3708,3717,3718,-10576,-10578,-10575,-10576,30.9,30.7,30.5,30.9,45
    2025-05-27 19:59:15.433,3718,3708,3716,3718,-10578,-10580,-10574,-10571,30.9,30.7,30.5,31.0,45
    2025-05-27 19:59:20.442,3718,3707,3715,3717,-10574,-10577,-10575,-10576,30.9,30.7,30.5,31.0,45
    2025-05-27 19:59:25.452,3717,3707,3715,3718,-10579,-10577,-10577,-10575,30.9,30.7,30.5,31.0,45
    2025-05-27 19:59:30.461,3717,3706,3714,3717,-10576,-10578,-10580,-10576,31.0,30.8,30.6,31.0,45
    2025-05-27 19:59:35.471,3716,3705,3714,3716,-10575,-10576,-10582,-10576,30.9,30.8,30.6,31.0,44
    2025-05-27 19:59:40.478,3716,3705,3713,3716,-10575,-10577,-10580,-10575,31.0,30.8,30.6,31.1,44
    2025-05-27 19:59:45.488,3715,3704,3712,3715,-10571,-10579,-10577,-10575,31.0,30.8,30.6,31.1,44
    2025-05-27 19:59:50.497,3714,3704,3712,3715,-10566,-10575,-10578,-10575,31.0,30.8,30.6,31.1,44
    2025-05-27 19:59:55.505,3714,3703,3711,3714,-10567,-10574,-10577,-10577,31.1,30.9,30.7,31.1,44
    2025-05-27 20:00:00.510,3713,3703,3711,3713,-10571,-10577,-10571,-10569,31.1,30.9,30.7,31.2,43
    2025-05-27 20:00:05.516,3713,3703,3710,3713,-10579,-10577,-10574,-10575,31.1,30.9,30.7,31.2,43
    2025-05-27 20:00:10.520,3712,3702,3709,3712,-10576,-10574,-10576,-10575,31.1,30.9,30.7,31.2,43
    2025-05-27 20:00:15.526,3712,3702,3709,3710,-10579,-10572,-10578,-10574,31.1,31.0,30.7,31.2,43
    2025-05-27 20:00:20.538,3711,3701,3708,3710,-10575,-10572,-10581,-10575,31.1,31.0,30.7,31.2,43
    2025-05-27 20:00:25.548,3711,3701,3708,3709,-10578,-10571,-10580,-10574,31.2,31.0,30.7,31.2,42
    2025-05-27 20:00:30.557,3710,3700,3707,3709,-10574,-10581,-10578,-10576,31.2,31.0,30.7,31.2,42
    2025-05-27 20:00:35.567,3710,3700,3707,3708,-10573,-10578,-10573,-10577,31.2,31.1,30.8,31.2,42
    2025-05-27 20:00:40.574,3710,3699,3706,3708,-10578,-10577,-10574,-10580,31.3,31.1,30.8,31.2,42
    2025-05-27 20:00:45.583,3709,3699,3705,3707,-10577,-10580,-10574,-10581,31.3,31.1,30.8,31.3,42
    2025-05-27 20:00:50.587,3709,3698,3705,3707,-10578,-10578,-10577,-10578,31.3,31.2,30.8,31.2,41
    2025-05-27 20:00:55.603,3709,3698,3704,3706,-10582,-10576,-10579,-10576,31.2,31.2,30.8,31.3,41
    2025-05-27 20:01:00.609,3708,3697,3704,3706,-10578,-10574,-10579,-10574,31.2,31.2,30.9,31.2,41
    2025-05-27 20:01:05.617,3708,3697,3703,3705,-10578,-10575,-10577,-10575,31.3,31.2,30.9,31.3,41
    2025-05-27 20:01:10.627,3707,3697,3703,3705,-10578,-10576,-10582,-10577,31.3,31.3,30.9,31.3,41
    2025-05-27 20:01:15.635,3707,3696,3702,3704,-10580,-10576,-10580,-10577,31.3,31.3,30.9,31.4,40
    2025-05-27 20:01:20.637,3706,3695,3702,3704,-10579,-10581,-10578,-10579,31.3,31.3,30.9,31.3,40
    2025-05-27 20:01:25.645,3706,3695,3702,3703,-10579,-10581,-10575,-10582,31.4,31.3,30.9,31.4,40
    2025-05-27 20:01:30.653,3706,3695,3701,3703,-10578,-10573,-10578,-10581,31.4,31.4,31.0,31.4,40
    2025-05-27 20:01:35.657,3705,3694,3700,3702,-10577,-10572,-10576,-10579,31.5,31.4,31.0,31.5,40
    2025-05-27 20:01:40.664,3705,3694,3700,3702,-10576,-10575,-10578,-10578,31.5,31.4,31.0,31.5,39
    2025-05-27 20:01:45.665,3704,3693,3699,3702,-10579,-10576,-10578,-10574,31.5,31.5,31.0,31.5,39
    2025-05-27 20:01:50.670,3704,3693,3699,3701,-10579,-10576,-10574,-10575,31.5,31.5,31.0,31.5,39
    2025-05-27 20:01:55.683,3704,3692,3699,3701,-10576,-10576,-10576,-10574,31.5,31.5,31.1,31.5,39
    2025-05-27 20:02:00.693,3704,3692,3698,3700,-10577,-10575,-10574,-10574,31.5,31.6,31.1,31.5,39
    2025-05-27 20:02:05.698,3703,3691,3698,3700,-10577,-10576,-10575,-10576,31.6,31.6,31.1,31.6,39
    2025-05-27 20:02:10.700,3703,3691,3697,3700,-10579,-10578,-10577,-10578,31.6,31.7,31.1,31.6,38
    2025-05-27 20:02:15.701,3703,3690,3697,3699,-10576,-10578,-10577,-10577,31.6,31.7,31.2,31.7,38
    2025-05-27 20:02:20.711,3702,3689,3697,3699,-10577,-10578,-10578,-10581,31.7,31.7,31.2,31.6,38
    2025-05-27 20:02:25.720,3702,3689,3696,3699,-10576,-10579,-10576,-10577,31.7,31.8,31.2,31.7,38
    2025-05-27 20:02:30.733,3701,3688,3696,3698,-10578,-10581,-10581,-10579,31.8,31.8,31.2,31.7,38
    2025-05-27 20:02:35.741,3701,3688,3696,3698,-10575,-10578,-10578,-10583,31.8,31.8,31.2,31.8,37
    2025-05-27 20:02:40.749,3701,3687,3695,3698,-10573,-10574,-10579,-10583,31.8,31.9,31.2,31.8,37
    2025-05-27 20:02:45.759,3701,3687,3695,3697,-10572,-10579,-10579,-10581,31.8,31.9,31.3,31.8,37
    2025-05-27 20:02:50.767,3700,3686,3694,3698,-10571,-10584,-10584,-10584,31.9,31.9,31.3,31.8,37
    2025-05-27 20:02:55.779,3700,3686,3694,3697,-10576,-10578,-10581,-10581,31.9,31.9,31.3,31.8,37
    2025-05-27 20:03:00.792,3699,3685,3694,3697,-10578,-10575,-10580,-10581,31.9,31.9,31.3,31.9,36
    2025-05-27 20:03:05.804,3699,3684,3693,3697,-10581,-10576,-10579,-10581,31.9,31.9,31.4,31.9,36
    2025-05-27 20:03:10.809,3699,3684,3693,3697,-10580,-10583,-10584,-10580,32.0,32.1,31.4,31.9,36
    2025-05-27 20:03:15.819,3699,3683,3693,3697,-10579,-10582,-10584,-10582,31.9,32.1,31.5,31.9,36
    2025-05-27 20:03:20.826,3698,3682,3692,3696,-10576,-10581,-10581,-10581,31.9,32.1,31.5,31.9,36
    2025-05-27 20:03:25.833,3698,3682,3692,3696,-10575,-10580,-10582,-10579,32.0,32.1,31.5,31.9,35
    2025-05-27 20:03:30.838,3697,3682,3692,3696,-10580,-10581,-10584,-10582,32.1,32.2,31.5,31.9,35
    2025-05-27 20:03:35.854,3697,3681,3691,3696,-10573,-10581,-10581,-10582,32.1,32.2,31.6,31.9,35
    2025-05-27 20:03:40.856,3697,3680,3691,3695,-10580,-10581,-10588,-10584,32.1,32.2,31.6,32.0,35
    2025-05-27 20:03:45.861,3696,3680,3691,3694,-10584,-10581,-10585,-10580,32.1,32.3,31.6,32.1,35
    2025-05-27 20:03:50.869,3696,3679,3690,3694,-10580,-10579,-10583,-10582,32.1,32.3,31.7,32.1,34
    2025-05-27 20:03:55.883,3696,3678,3690,3693,-10582,-10576,-10582,-10584,32.2,32.4,31.7,32.1,34
    2025-05-27 20:04:00.889,3695,3677,3690,3693,-10584,-10575,-10583,-10589,32.2,32.4,31.7,32.1,34
    2025-05-27 20:04:05.900,3695,3677,3689,3693,-10581,-10581,-10581,-10589,32.3,32.4,31.8,32.2,34
    2025-05-27 20:04:10.907,3695,3676,3689,3692,-10580,-10583,-10582,-10586,32.3,32.4,31.8,32.2,34
    2025-05-27 20:04:15.913,3694,3675,3689,3692,-10580,-10584,-10580,-10585,32.4,32.5,31.8,32.3,33
    2025-05-27 20:04:20.928,3694,3675,3688,3692,-10578,-10583,-10580,-10578,32.4,32.5,31.9,32.2,33
    2025-05-27 20:04:25.928,3693,3674,3688,3692,-10580,-10581,-10578,-10585,32.4,32.5,31.9,32.3,33
    2025-05-27 20:04:30.928,3693,3674,3688,3691,-10580,-10584,-10581,-10576,32.4,32.6,31.9,32.3,33
    2025-05-27 20:04:35.931,3693,3673,3687,3691,-10580,-10579,-10582,-10576,32.4,32.6,31.9,32.3,33
    2025-05-27 20:04:40.946,3692,3672,3687,3691,-10581,-10578,-10582,-10580,32.5,32.6,32.0,32.4,32
    2025-05-27 20:04:45.953,3692,3671,3686,3690,-10584,-10579,-10583,-10580,32.5,32.7,31.9,32.4,32
    2025-05-27 20:04:50.959,3692,3670,3686,3690,-10580,-10584,-10577,-10582,32.5,32.7,31.9,32.4,32
    2025-05-27 20:04:55.964,3691,3669,3686,3690,-10584,-10585,-10580,-10578,32.6,32.8,32.1,32.5,32
    2025-05-27 20:05:00.973,3691,3669,3685,3689,-10582,-10585,-10579,-10582,32.6,32.8,32.1,32.5,31
    2025-05-27 20:05:05.979,3690,3668,3685,3689,-10584,-10583,-10582,-10584,32.6,32.8,32.1,32.6,31
    2025-05-27 20:05:10.991,3690,3667,3684,3689,-10584,-10581,-10582,-10579,32.7,32.8,32.1,32.6,31
    2025-05-27 20:05:16.006,3689,3666,3684,3689,-10588,-10582,-10582,-10582,32.8,32.9,32.2,32.7,31
    2025-05-27 20:05:21.007,3689,3666,3684,3688,-10584,-10582,-10585,-10583,32.8,32.9,32.2,32.7,31
    2025-05-27 20:05:26.014,3689,3665,3684,3688,-10584,-10583,-10586,-10581,32.8,32.9,32.2,32.8,31
    2025-05-27 20:05:31.015,3688,3664,3683,3688,-10585,-10582,-10585,-10581,32.8,32.9,32.2,32.7,30
    2025-05-27 20:05:36.028,3688,3663,3683,3687,-10587,-10588,-10585,-10585,32.8,33.0,32.3,32.8,30
    2025-05-27 20:05:41.037,3687,3662,3682,3687,-10586,-10588,-10584,-10585,32.8,33.0,32.3,32.8,30
    2025-05-27 20:05:46.048,3687,3661,3682,3687,-10583,-10583,-10587,-10583,32.9,33.1,32.3,32.8,30
    2025-05-27 20:05:51.049,3686,3661,3681,3686,-10584,-10582,-10587,-10583,32.9,33.2,32.4,32.8,30
    2025-05-27 20:05:56.052,3686,3660,3681,3686,-10583,-10582,-10586,-10586,32.9,33.2,32.4,32.8,29
    2025-05-27 20:06:01.065,3685,3659,3681,3686,-10583,-10583,-10585,-10581,33.0,33.2,32.5,32.9,29
    2025-05-27 20:06:06.067,3685,3658,3680,3686,-10583,-10583,-10585,-10579,33.0,33.2,32.5,32.9,29
    2025-05-27 20:06:11.067,3685,3657,3680,3685,-10583,-10586,-10589,-10581,33.0,33.3,32.4,32.9,29
    2025-05-27 20:06:16.071,3684,3656,3679,3685,-10585,-10583,-10586,-10580,33.1,33.3,32.6,32.9,29
    2025-05-27 20:06:21.078,3683,3655,3679,3684,-10585,-10583,-10583,-10585,33.1,33.3,32.6,33.0,28
    2025-05-27 20:06:26.089,3683,3654,3678,3685,-10587,-10586,-10583,-10588,33.2,33.3,32.6,33.0,28
    2025-05-27 20:06:31.092,3682,3653,3678,3685,-10579,-10585,-10580,-10586,33.2,33.4,32.6,33.0,28
    2025-05-27 20:06:36.099,3682,3652,3677,3684,-10581,-10585,-10587,-10586,33.2,33.4,32.7,33.1,28
    2025-05-27 20:06:41.100,3681,3651,3677,3684,-10583,-10587,-10587,-10587,33.3,33.5,32.8,33.0,28
    2025-05-27 20:06:46.109,3681,3650,3676,3683,-10582,-10585,-10587,-10588,33.3,33.5,32.8,33.1,27
    2025-05-27 20:06:51.111,3680,3649,3676,3683,-10584,-10588,-10592,-10585,33.3,33.5,32.8,33.1,27
    2025-05-27 20:06:56.116,3679,3648,3675,3683,-10584,-10588,-10586,-10589,33.4,33.5,32.8,33.2,27
    2025-05-27 20:07:01.127,3679,3647,3675,3682,-10584,-10588,-10585,-10587,33.4,33.6,32.8,33.3,27
    2025-05-27 20:07:06.135,3678,3646,3675,3682,-10589,-10588,-10590,-10589,33.5,33.6,32.8,33.3,27
    2025-05-27 20:07:11.136,3678,3645,3674,3682,-10585,-10583,-10588,-10590,33.5,33.6,32.9,33.3,26
    2025-05-27 20:07:16.139,3677,3644,3674,3680,-10586,-10583,-10585,-10590,33.5,33.7,32.9,33.3,26
    2025-05-27 20:07:21.155,3676,3643,3673,3680,-10590,-10583,-10588,-10590,33.5,33.7,33.0,33.4,26
    2025-05-27 20:07:26.158,3676,3642,3672,3679,-10590,-10587,-10590,-10593,33.6,33.7,33.0,33.4,26
    2025-05-27 20:07:31.161,3675,3641,3672,3679,-10592,-10595,-10586,-10590,33.6,33.7,33.0,33.4,25
    2025-05-27 20:07:36.176,3675,3640,3671,3679,-10590,-10592,-10586,-10593,33.7,33.8,33.1,33.4,25
    2025-05-27 20:07:41.186,3674,3639,3671,3678,-10587,-10596,-10588,-10588,33.6,33.8,33.2,33.5,25
    2025-05-27 20:07:46.199,3673,3638,3670,3678,-10589,-10592,-10589,-10589,33.7,33.8,33.2,33.5,25
    2025-05-27 20:07:51.208,3673,3637,3670,3677,-10586,-10588,-10591,-10591,33.8,33.8,33.2,33.5,25
    2025-05-27 20:07:56.213,3672,3636,3669,3677,-10589,-10588,-10593,-10589,33.8,33.9,33.2,33.6,24
    2025-05-27 20:08:01.227,3671,3636,3669,3677,-10588,-10590,-10592,-10591,33.8,33.9,33.3,33.6,24
    2025-05-27 20:08:06.235,3670,3635,3668,3676,-10589,-10593,-10595,-10590,33.8,33.9,33.3,33.7,24
    2025-05-27 20:08:11.244,3670,3635,3667,3676,-10588,-10592,-10592,-10590,33.9,34.0,33.3,33.7,24
    2025-05-27 20:08:16.254,3669,3633,3667,3675,-10588,-10592,-10591,-10591,33.9,34.0,33.4,33.8,24
    2025-05-27 20:08:21.267,3668,3633,3666,3675,-10590,-10593,-10594,-10591,33.9,34.0,33.4,33.8,23
    2025-05-27 20:08:26.274,3667,3632,3665,3674,-10589,-10595,-10588,-10593,34.0,34.1,33.4,33.7,23
    2025-05-27 20:08:31.282,3667,3631,3665,3674,-10588,-10590,-10590,-10590,34.0,34.1,33.4,33.7,23
    2025-05-27 20:08:36.289,3666,3630,3664,3673,-10589,-10590,-10595,-10594,34.0,34.1,33.5,33.7,23
    2025-05-27 20:08:41.298,3665,3630,3664,3673,-10585,-10593,-10589,-10590,34.0,34.1,33.5,33.8,23
    2025-05-27 20:08:46.299,3664,3629,3663,3672,-10590,-10588,-10587,-10585,34.0,34.2,33.6,33.9,22
    2025-05-27 20:08:51.304,3664,3628,3662,3672,-10591,-10589,-10591,-10587,34.0,34.2,33.6,33.9,22
    2025-05-27 20:08:56.319,3663,3628,3661,3671,-10591,-10589,-10591,-10585,34.0,34.3,33.6,33.9,22
    2025-05-27 20:09:01.322,3662,3627,3661,3671,-10595,-10588,-10593,-10589,34.1,34.3,33.6,34.0,22
    2025-05-27 20:09:06.329,3661,3626,3660,3670,-10590,-10589,-10593,-10593,34.3,34.3,33.7,34.0,22
    2025-05-27 20:09:11.333,3660,3625,3659,3669,-10591,-10588,-10592,-10591,34.3,34.4,33.7,34.0,22
    2025-05-27 20:09:16.333,3659,3624,3659,3669,-10593,-10594,-10591,-10592,34.3,34.4,33.7,34.1,21
    2025-05-27 20:09:21.340,3659,3623,3658,3668,-10595,-10593,-10591,-10592,34.3,34.4,33.8,34.1,21
    2025-05-27 20:09:26.348,3658,3622,3657,3668,-10596,-10591,-10590,-10590,34.4,34.4,33.8,34.1,21
    2025-05-27 20:09:31.353,3657,3621,3656,3667,-10596,-10592,-10588,-10594,34.4,34.5,33.8,34.2,21
    2025-05-27 20:09:36.360,3656,3620,3655,3667,-10598,-10594,-10588,-10593,34.4,34.5,33.9,34.3,21
    2025-05-27 20:09:41.366,3655,3619,3655,3666,-10593,-10591,-10595,-10592,34.5,34.5,33.9,34.3,20
    2025-05-27 20:09:46.377,3655,3619,3655,3665,-10592,-10592,-10599,-10591,34.5,34.5,33.9,34.3,20
    2025-05-27 20:09:51.405,3653,3617,3653,3665,-10594,-10600,-10596,-10594,34.5,34.5,34.0,34.4,20
    2025-05-27 20:09:56.392,3652,3615,3652,3664,-10592,-10596,-10600,-10594,34.5,34.5,34.0,34.4,20
    2025-05-27 20:10:01.395,3651,3614,3651,3664,-10589,-10599,-10594,-10596,34.5,34.5,34.0,34.4,19
    2025-05-27 20:10:06.401,3650,3612,3650,3664,-10591,-10594,-10596,-10596,34.5,34.6,34.0,34.5,19
    2025-05-27 20:10:11.455,3649,3611,3650,3663,-10598,-10597,-10594,-10596,34.6,34.7,34.1,34.5,19
    2025-05-27 20:10:16.414,3648,3610,3650,3663,-10596,-10595,-10598,-10598,34.7,34.7,34.1,34.5,19
    2025-05-27 20:10:21.424,3646,3607,3648,3661,-10592,-10594,-10598,-10599,34.7,34.7,34.2,34.5,19
    2025-05-27 20:10:26.433,3645,3605,3647,3661,-10597,-10596,-10595,-10602,34.7,34.7,34.2,34.5,18
    2025-05-27 20:10:31.485,3644,3603,3646,3661,-10599,-10594,-10596,-10597,34.7,34.8,34.3,34.5,18
    2025-05-27 20:10:36.447,3643,3600,3645,3659,-10597,-10597,-10591,-10597,34.7,34.8,34.3,34.5,18
    2025-05-27 20:10:41.458,3642,3598,3644,3659,-10596,-10597,-10597,-10597,34.8,34.8,34.4,34.6,18
    2025-05-27 20:10:46.467,3641,3595,3643,3658,-10601,-10597,-10597,-10599,34.9,34.9,34.4,34.7,18
    2025-05-27 20:10:51.563,3639,3592,3642,3657,-10603,-10597,-10595,-10595,34.9,34.9,34.4,34.8,17
    2025-05-27 20:10:56.482,3638,3588,3641,3655,-10596,-10596,-10597,-10592,34.9,34.9,34.4,34.8,17
    2025-05-27 20:11:01.493,3637,3585,3640,3654,-10597,-10597,-10595,-10592,35.0,34.9,34.5,34.8,17
    2025-05-27 20:11:06.501,3636,3581,3638,3653,-10597,-10597,-10592,-10597,35.1,35.0,34.5,34.8,17
    2025-05-27 20:11:11.577,3635,3577,3638,3653,-10603,-10595,-10594,-10600,35.1,35.0,34.5,34.9,17
    2025-05-27 20:11:16.524,3633,3572,3636,3652,-10591,-10599,-10599,-10597,35.1,35.1,34.5,35.0,16
    2025-05-27 20:11:21.529,3632,3567,3636,3651,-10594,-10599,-10594,-10597,35.1,35.1,34.5,35.0,16
    2025-05-27 20:11:26.539,3631,3562,3634,3650,-10594,-10600,-10599,-10596,35.1,35.1,34.6,35.0,16
    2025-05-27 20:11:31.622,3630,3556,3633,3649,-10594,-10597,-10600,-10597,35.1,35.1,34.7,35.0,16
    2025-05-27 20:11:36.553,3629,3550,3633,3648,-10597,-10598,-10602,-10599,35.2,35.1,34.7,35.0,16
    2025-05-27 20:11:41.560,3628,3543,3631,3647,-10597,-10598,-10597,-10596,35.2,35.2,34.7,35.0,15
    2025-05-27 20:11:46.569,3627,3536,3630,3646,-10597,-10597,-10597,-10598,35.2,35.2,34.7,35.0,15
    2025-05-27 20:11:51.672,3626,3529,3630,3646,-10596,-10593,-10597,-10599,35.2,35.3,34.8,35.1,15
    2025-05-27 20:11:56.599,3625,3521,3628,3644,-10595,-10594,-10600,-10598,35.3,35.3,34.8,35.1,15
    2025-05-27 20:12:01.605,3624,3513,3627,3643,-10596,-10596,-10597,-10602,35.3,35.3,34.9,35.1,15
    2025-05-27 20:12:06.617,3623,3504,3626,3642,-10595,-10600,-10595,-10599,35.3,35.4,34.9,35.1,14
    2025-05-27 20:12:11.719,3622,3496,3625,3641,-10601,-10597,-10600,-10599,35.4,35.4,34.9,35.2,14
    2025-05-27 20:12:16.622,3620,3486,3624,3640,-10596,-10602,-10600,-10598,35.4,35.4,34.9,35.2,14
    2025-05-27 20:12:21.626,3619,3476,3623,3638,-10598,-10600,-10606,-10600,35.4,35.4,35.0,35.2,14
    2025-05-27 20:12:26.626,3618,3467,3622,3637,-10598,-10602,-10603,-10598,35.4,35.5,35.0,35.3,14
    2025-05-27 20:12:31.767,3617,3456,3621,3636,-10600,-10599,-10596,-10602,35.4,35.6,35.0,35.3,13
    2025-05-27 20:12:36.633,3615,3445,3620,3635,-10600,-10600,-10603,-10602,35.4,35.6,35.1,35.3,13
    2025-05-27 20:12:41.641,3614,3434,3619,3634,-10601,-10598,-10602,-10600,35.4,35.6,35.1,35.4,13
    2025-05-27 20:12:46.648,3612,3422,3618,3632,-10601,-10598,-10600,-10605,35.5,35.7,35.1,35.4,13
    2025-05-27 20:12:51.812,3611,3409,3617,3631,-10602,-10600,-10602,-10599,35.4,35.7,35.2,35.4,13
    2025-05-27 20:12:56.677,3609,3397,3615,3630,-10606,-10600,-10602,-10604,35.4,35.8,35.2,35.4,12
    2025-05-27 20:13:01.679,3608,3383,3614,3628,-10595,-10603,-10600,-10608,35.5,35.8,35.2,35.4,12
    2025-05-27 20:13:06.680,3606,3369,3613,3627,-10596,-10605,-10602,-10604,35.6,35.9,35.3,35.4,12
    2025-05-27 20:13:11.845,3604,3354,3611,3625,-10600,-10603,-10599,-10599,35.6,35.9,35.3,35.4,12
    2025-05-27 20:13:16.689,3602,3339,3610,3624,-10603,-10601,-10602,-10602,35.7,35.9,35.4,35.5,12
    2025-05-27 20:13:21.690,3600,3323,3608,3623,-10605,-10599,-10605,-10599,35.7,35.9,35.4,35.5,11
    2025-05-27 20:13:26.693,3597,3307,3607,3621,-10601,-10598,-10603,-10601,35.7,36.0,35.4,35.5,11
    2025-05-27 20:13:31.892,3595,3288,3605,3620,-10603,-10606,-10601,-10604,35.7,36.0,35.4,35.5,11
    2025-05-27 20:13:36.708,3592,3270,3603,3619,-10601,-10600,-10603,-10599,35.7,36.0,35.4,35.6,11
    2025-05-27 20:13:41.710,3589,3250,3601,3617,-10605,-10598,-10603,-10602,35.8,36.0,35.4,35.6,11
    2025-05-27 20:13:46.720,3586,3228,3599,3616,-10605,-10600,-10603,-10605,35.8,36.1,35.5,35.6,10
    2025-05-27 20:13:51.939,3583,3204,3598,3613,-10597,-10603,-10603,-10601,35.8,36.1,35.5,35.6,10
    2025-05-27 20:13:56.729,3580,3180,3595,3613,-10602,-10603,-10605,-10605,35.8,36.1,35.6,35.7,10
    2025-05-27 20:14:01.731,3577,3154,3593,3611,-10603,-10608,-10602,-10606,35.8,36.2,35.6,35.7,10
    2025-05-27 20:14:06.743,3573,3126,3590,3609,-10603,-10608,-10602,-10603,35.8,36.2,35.6,35.8,10
    2025-05-27 20:14:11.999,3569,3092,3587,3607,-10604,-10604,-10601,-10605,35.9,36.2,35.6,35.8,9
    2025-05-27 20:14:16.756,3565,3057,3585,3605,-10605,-10607,-10600,-10604,35.9,36.2,35.6,35.7,9
    2025-05-27 20:14:21.762,3560,3014,3582,3603,-10606,-10605,-10603,-10608,35.9,36.2,35.7,35.9,9
    2025-05-27 20:14:26.774,3556,2960,3579,3601,-10605,-10602,-10603,-10608,36.0,36.3,35.7,35.9,9
    2025-05-27 20:14:32.048,3551,2888,3575,3599,-10605,-10601,-10605,-10604,36.0,36.3,35.7,35.9,8
    2025-05-27 20:14:36.795,3546,2799,3572,3596,-10604,-10602,-10606,-10605,36.0,36.3,35.7,36.0,8
    2025-05-27 20:14:41.802,,,,,,,,,,36.3,,,
    2025-05-27 20:14:46.813,3543,2624,3571,3597,-10624,-10626,-10616,-10597,36.0,36.3,35.8,36.0,0
    2025-05-27 20:14:52.111,3578,2657,3610,3637,0,0,0,0,36.0,36.4,35.9,36.0,0
    2025-05-27 20:14:56.831,3544,2505,3573,3600,-10590,-10590,-10590,-10585,36.0,36.4,35.8,36.0,0
    2025-05-27 20:15:01.831,3585,2653,3617,3644,0,0,0,0,36.0,36.4,35.9,36.1,0
    2025-05-27 20:15:06.846,3555,2545,3585,3610,-10422,-2601,,-2608,36.0,36.4,35.8,36.1,0
    2025-05-27 20:15:12.142,3586,2606,3619,3646,0,0,0,0,35.9,36.4,35.8,36.0,0
    2025-05-27 20:15:16.866,,,,,,,,,,,,,
    2025-05-27 20:15:21.872,3594,2681,3627,3653,-33,1,5,-1,35.5,36.5,35.8,35.8,0
    2) Ra update
    Then I understand that we can do only one time ? Flags modifications are not mentionned in procedure GPC guide sluubc9
    Do I write flags manually to 0xFFFF before doing procedure ?
    CM
  • Hi Cedric,
    Sorry for the delay, for the information attached:
    I've made logs for GPC Maker, I don't know if it contains the information you want. What data do you want in the log (to redo it)?
    If bqStudio is being used, please use the logging functionality in the top right corner of the registers page. This will read out all the important registers needed for debug:
    I believe these should be overwritten to 0xFF55 when the chemID is programmed, and should not need to be written manually. If the flags do not appear as this once the chemID is programmed, please write the 0xFF55.
    Anthony
    OK, I understand, you were talking about the "live" register log and not the data in Watch Windows.
    - By default, everything is checked. What are the parameters you want to log?
    - And regarding a previous question, which also applies here, how do you save (and recall) a Watch Windows configuration?
    Regarding the Ra table, the very first use does indeed allow you to perform GPC Maker (initializing the flags), but then it's blocked, apparently by these flags. My question was whether I could do it again. I wanted to try, not knowing the cause of the SoH, which isn't 100%, even though it's on initialization. I'm waiting for the exact explanation, which I hope you'll identify.
    As soon as I create a log again (according to your recommendations), I will also try the manipulation with the manually entered flags.
    CM
