Part Number: BQ27220
Hi Team
do you have any low cost replacement for RT9426A?
Below is datasheet.
BRs
Brian
Hi Team
Below is datasheet.
BRs
Brian
Hello Brian,
The low cost replacement for the RT9426A is dependent on your replacement you need from your battery gauge system, however the image below is a good start point for your investigation.
Thank you,
Alan
Hi Alan
could you help me check do we have any gauge can support below battery?
the capacity is 50mAh but I search our solution can only support 100mAh.
BRs
Brian
Hello Brain,
Our Gauge aren't able to support 50mAh cell and we can only go down to 100mAh cell.
Thank you,
Alan
