Other Parts Discussed in Thread: BQ-BATTERY-PROGRAMMER-SW, MKST-3P-ALT-EV2300
Which BQ-BMS-PROGRAMMER-SW.exe file should i use for BQ27Z746 when programming golden image using MKS-SAI-001?
I tried with Prog27z5.exe and Prog28Z6.exe, but both also not working.
Below is 2 subsequent runs using one of the exe file:
C:\Program Files (x86)\Texas Instruments\BQ-BATTERY-PROGRAMMER-SW\BQ-BMS-PROGRAMMER-SW\CommandLineProgrammers>Prog27z5.exe -i -p 1746_0_01-bq27z746_LearningCycleAttempt1.srec -v
Filename=1746_0_01-bq27z746_LearningCycleAttempt1.srec
Failed to open connection. Windows error code 0x20
Failed to open connection. Windows error code 0x5
Serial = 435
Enabling pullups, option_enablePullups=1
Setting communication mode to I2C
Error: Failed InitializeForProgramming()
Program Prog27z5.exe returned 503
Error 503 Description: 503 ERROR_FAILED_VERIFY_BSL_MODE // Slave not in BSL/ROM mode when expected
Disabling pullups
Serial = 435
Program Prog27z5.exe returned 2
Error 2 Description: 2 CODE_ERR_COMM_NACK_I2C // I2C No acknowledge condition. Code returned by Adapter.
Disabling pullups
Soo San
