Hello Team,
I am Hemaraj, working as a electronic engineer in Duratronics GmbH, Daun, Germany.
We have used TLC6C5712QPWPRQ1 IC in our automobile gear light indicator application
There is an failure occurred in field vehicle. one of the LED in the system was destroyed due to overcurrent ( limit above the LED max current 20mA)
i would like to understand what would be reason for this failure as we are driving thought the LED driver IC(TLC6C5712-Q1) which has current limit set through Dot correction bit.
Dot correction bit was set in the register for all channels to limit current to 10mA max
I would like to know the failure conditions which would allow its IC max current (75mA ) to destroy the LED.
Kindly extend your support. I will provide all relevant details related to the project during further discussion.
