LMG3100R017: Low side switching only
Part Number: LMG3100R017
Dear Support team,
I want to use the LMG3100Rxxx as a low side switch, pulling a load to GND.
I do not need the secondary power supply and I got a bit confuse with the HS pin liked to VIN in the datasheet. I also understand that this is internally linked to SRC and so to GND in my case.
Question 1 - What should I connect HS to in case of a low side switch only? My guess is nothing right?
Question 2 - I could not find the impedance of the input LI in the datasheet, I could not calculate anything as the current drawn by the input seems to be missing as well. Can you clarify the impedance of the LI pin?
Question 3 - I saw in the forum that you could share a Spice model of the device but could not find it as a direct download, could you please share the spice model with me?
Thanks in advance for your help and with my Br.
Mathieu
