LM74900-Q1: Disable Rsense
Part Number: LM74900-Q1
As you suggested to keep CS+ and CS- connected to power rail with RSET in place.
LM74900-Q1: Without Rsense functionality - Power management forum - Power management - TI E2E support forums
In this configuration, how should RSET be calculated? Should we still use the value within recommended range 50 Ω to 100 Ω. value as mentioned in the datasheet?
Also, just to confirm—RISCP is not required in this case, correct?
