TPS92520-Q1: LED current accuracy improvement by offset compenstaion
Part Number: TPS92520-Q1
Hello Team,
With offset compensation, to what extent can the LED current error be improved?
Ideally, Rcs is assumed to have no tolerance.
For example, when ILED_REF_DACx = 512, the percentage error from the typical value to the minimum or maximum is ±6.21%.
Could you please clarify what portion of this ±6.21% error is attributed to the offset error?
Thank you for your insights and support.
