I am planning to use LM5069MM-1 as a bidirectional switch controller driving 2 anti-serial or back-to-back MOSFETs, the sources of both FETs are connected together and to OUT pin, while both gates are connected together to GATE pin.
My intention is the following:
Current flowing from VIN to VOUT: Have all functions working (UVLO, OVLO, Current limit, Power limit)
Current flowing from VOUT to VIN: Keep only current limit and Power limit
In reverse current, the VIN-SENSE will be negative but will not exceed the absolute max of +/-0.3V. Can the controller turn off the MOSFETs on current limit for either forward or reverse current flow?
