TPS2546: Potable charing.
Part Number: TPS2546
Hi
We are testing it by designing it according to the previous guide.
However, other portable devices can charge, but only the Galaxy S24 won't charge. (The S25 is normally charged.)
May I know what the problem is?
  • Hi David,
    What do you mean by "won't charge"?
    No power draw, no VBUS voltage?
    Does VBUS go to 5-V?
    Can you obtain and share scope captures of VBUS, D+, and D- for working and non-working cases?
    An issue with a single phone indicates a potential issue with the phone. Are you using a type-A to type-C cable? Do you use the same cable between the S24 and S25?
    Thanks and Regards,
    Chris
