Other Parts Discussed in Thread: TDA4VM, SK-TDA4VM
Hi TPS6594 series champ for TDA4VM !
My customer built a circuit almost identical to the SK-TDA4VM board.
However, when the main power is applied, even though VCC-3.3V is supplied to the PMIC, except for some LDOs, the buck-boost DCDC converters do not output at all.
We removed the PMIC (TPS65941111/TPS65941213) from the SK-TDA4VM board and installed it on a newly assembled custom board, but the result was the same.
The nPWRON/ENABLE signal goes high, but it does not function normally. If the PMIC does not start, should I first check the capacitors on the PMIC input side or the output side?
Please advise on how to debug this.
Attached their PMIC part of the schematic.
Thanks.
Jack
