Hi Team,
For the LATCH fault case as STB and Reverse-current, it needs FAULTS has to be removed and EN toggling for normal OUTPUT operation.
If there's no fault removed and just EN toggling until those fault was removed, what happen at the IC side? any physical damage it has?
(just for case customer can't detect fault was removed or not or SENSE pin voltage value read-out)
BR.
Lenny.
