TPS62913-IBB-EVM: Replacement of Q2
Part Number: TPS62913-IBB-EVM
Other Parts Discussed in Thread: TPS62913
the recommended part SI1029X-T1-GE3 for the TPS62913-IBB-EVM is EOL, I will need to replace it with a new part. May I know if DMG1029SVG is suitable as a replacement? Datasheet as attached.DMG1029SVG.pdf My desgin for the TPS62913 Inverting Buck Boost as below:
Input Voltage: +5V
Output Voltage: -5V
VCC: +5V
Angie
