Hi Expert,
Customer wants to control FET automatically. When go into shutdown, need disable FET. When exit shutdown, need enable FET automatically.
Could you tell which registers need to configure by OTP operation?
Hi Expert,
You must set Settings:Manufacturing:Mfg Status Init[FET_EN] bit to one in the OTP. After OTP has been programmed, then your device can operate autonomously.
Make sure FET Options[FET_CTRL_EN] is defaulted to 1 and FET Options[FET_INIT_OFF] is defaulted to 0 as well.
Please let me know if this solves your issue.
Rohin Nair
