LM64460APPQRYFRQ1_24Vto1.5V.pdf
Hi team,
I am using LM64460APPQRYFRQ1 voltage regulator for generating output of 1.5V@6A. Please provide your valuable feedback and suggestions on:
1. Please verify the above schematic attached with the values of the components used.
2. Additionally, kindly confirm if this Voltage regulator supports variable input voltage that mean if I change the input voltage from 24V to 28V, keeping the output voltage same as 1.5V, do I need to change the value of other components in the schematic.
Thanks & Regards.
