How to configure the BQ41Z90 to operate with the I²C interface on PIn47&Pin48 ?
Thank you.
Thank you.
This question has been assigned and will be reviewed when possible.
Thank you,
Alan
Hi :
Thank you for your reply. Could you please let me know if there is an estimated release date?
Thank you for your response. So at the moment, I can only use pins 34/35 for I2C, So it is not possible to use SMBus on pins 34/35 and I2C on pins 47/48 at the same time, correct? Also, what is the protocol configuration for using 34/35 as I2C?
Thank you!
I can not share that information over e2e unfortunately.
Correct, there are no bits that need to be changed to use i2c
Diego
