BQ41Z90: LED Configuration
Part Number: BQ41Z90
I have a related question to the thread ( BQ41Z90: LED Configuration for 5-LED RSOC Display. ) which was closed without a public answer.
I’m planning to use an external hardware protector, so I intend to use pins 20 and 21 of the BQ41Z90 to control the external MOSFETs.
At the same time, I would like to implement a 5-LED RSOC display, but according to the datasheet, pins 20 and 21 are also used for two of the LEDs.
Is it possible to use all 5 LEDs by repurposing other GPIO pins for LED control?
If so, does the “LED Display” function still work correctly in this configuration?
