TPS628501: Review of LMR604305SRAKRQ1_TPS628502QDRLRQ1_TPS628501QDRLRQ1
Part Number: TPS628501
Texas_Instruments_LMR604305SRAKRQ1_TPS628502QDRLRQ1_.pptx
Hi Experts,
Wanted your review for the above circuits.
Attaching the circuits and layout for the same.
Please review and let us know any improvements
  • Hello Vinyas,
    I will review it by tomorrow.
    Farheen
  • Hello Vinyas,
    For U63002:
    I have same comment as U63001.
    Schematic Review:
    • MODE/SYNC either should be connected to EN for high level or to GND for low level.
    • Feedforward cap looks big 470pF. It is out of recommended limit. Has the customer tested control loop stability?
    Layout review:
    • FB pin is very sensitive node. It is recommended to keep it short. In the layout, it is very long. I will recommend  to move the feedback divider closer.
    • Please also connect the bottom resistor of feedback network with IC GND to avoid any GND bouncing issue.
    • Also it is recommended to keep the snubber on the same layer as inductor.
    Farheen
