Hi team,
Could you pls review the schematic? thanks
Vin 50V
Io= 50A
Hi team,
Vin 50V
Io= 50A
Hi Jimmy,
I am working on this, I will get back to you.
Rishika Patel
Hi Jimmy,
The schematic looks great! Please see the following recommendations:
-CBST is too small as of now. Please use the max total gate charge (worst case scenario) for the calculations (all FETs + pre-charge FET). A sufficient BST capacitor size is critical for proper functionality.
-It is recommended that the 48V net is placed before the TVS diode for transient protection.
-Depending on the output capacitance, please consider adding additional slew rate controls on the gates of the FETs. If you choose to add additional capacitance on the gates, you will have to recalculate the CBST capacitor to make sure it is large enough to support all of the FETs and the additional capacitive loading for inrush control.
-For the diodes on the input and output – please make sure the values are chosen correctly considering any voltage transients and/or negative voltages that the system will experience.
-An RC filter should be placed close to the VS pin to filter out noise if that is a concern.
-If you have EMI concerns, connect ferrite beads to the CS+ and CS- pins.
-Please make sure to use the TPS4811-Q1 calculator to verify your component values.
SLURB09 Calculation tool | TI.com
-Please also use the TPS4811-Q1 FET SOA calculator to verify that your FET selection works.
FET-INRUSH-SOA-CALC Calculation tool | TI.com
Rishika Patel
Hi team,
I used the tool to calculate the SOA of MOS. But the result is a failure.
I also checked the SOA of EVM's FET based on EVM's condition and still failed.
Could you check again? If you result is okay pls send to me. thanks
Hi Jimmy,
The total gate charge for the FET is 339nC max x 4 main FETs = 1356 +3.8nC pre-charge FET = 1359.8nF. CBST needs to be at least 1.3598 uF.
Rishika Patel
Hi Jimmy,
Can you please send the file with the values you entered for your system?
Rishika Patel
Hi Jimmy,
I am checking on this with the internal team, I will get back to you.
Rishika Patel
