Other Parts Discussed in Thread: BQ77PL900
So there's some confusion when I'm reading the datasheet for the BQ77PL900 battery protector on how to commence shutdown. In both cases you have to be in Host Control mode I get that but page 9 says to shut off the DSG FET and then send the shutdown command and page 38 says to just send the shutdown command. So which way is the correct way so I don't end up with a protection circuit still in normal mode until the batteries drain?
And any help on the best way to code this would be great. I'm attempting to use an Arduino Uno and the Arduino IDE to send the commands. It's what we've used before when initially programming the UV and OV for the protector but the process of doing that was detailed step by step on page 37. Help?
