Hello TI,
Is there any problem addressing 6 of the TPS40400 devices in parallel? Anything to watch out for?
Dan
Can I ask what you mean by addressing 6 in parallel? If you mean that there are 6x TPS40400 devies on the same bus, then this is OK- just set each one to a different PMBus address.
I would not recommend setting 6 to the same address - they will conflict with each other.
