BQ246xx charger application circuit confirm
Other Parts Discussed in Thread: BQ24617
Dears,
I have charger application question, need your help!
I plan to use bq24617 for 3 cell Li-lion battery charge; adapter in =19V, System Voltage spec=12V
since my system need 12V, so I add DC/DC POL after 19V out (19V to 12.6V), then re-connect Battery power path to POL output side.
I attached the circuit that I modify for you reference, please have your recommend on this circuit, is can work normal?
If it can work normal, what I need to noted when circuit design?
Looking for your reply!
BQ24617 application circuit.docx
