I am student at Istanbul University. And we want to monitor and balance battery packs in our project.
I have 80 series lithium polymer battery pack. That means 336 Volts . My first problem is about grounding. "16-Cell EV/HEV Integrated Battery Monitor and Protector with Passive Balancing Reference Design" in this design AGND1 , AGND2, AGND3 ,DGND1, DGND2 and DGND3 tied together. I think these ground pins must be seperated. Because AGND1 and AGND2 must be tied to lowest battery cathode in row and other ground pins should tie to external power supply ground. I am confused between reference design and datasheet.
Other problem is datasheet doesn't give enough information about external power supply?
Should I connect TOP pin when i use external power supply?
Can i supply VDIG and VIO pins with 3.3 Volts?
Should i NPNB pin float?
Thanks.
