Hey there,
Im using the TPS61030 Boost converter to make 5.2 Volts out of LIpo Battery.
I layoutet everything and soldered the chip to the PCB. The problem is that the output voltage is the same as the input voltage.
If there is no input voltage the chip is high impedant from input to output.
any suggestions? can I send you the eagle files if I connected everything right?
Many thanks in advance
Felix
