I'm turning around the tools and documents and I cannot find how to write the golden pack .DFI using bq20z65-r1.
The bqTester is not compatible with this IC.
Can I simply load the file using the data flash screen and write into the device memory? At which stage? Should I first go through the normal steps up to calibration before enabling the IT algorithm?
Many thanks!
