Other Parts Discussed in Thread: TPS22960, TPS22963C
Hi In the above schematic I have used TPS22960 switches for connecting different voltages. But when I am disabling all the voltage sources and connecting external pullup the TPST switch is taking current. That is because when ever the enable pin of TPST switch is at logic zero it connects the output pin to ground. But I don't want that to happen. The TPST switch should not allow the current to pass through it. Is there any other switch with similar specifications.
