Other Parts Discussed in Thread: BQSTUDIO,
hi,
I have follow the
How to use the bq28z610 EVM available at https://e2e.ti.com/support/power_management/battery_management/f/180/t/551498 with EV2300 and the kit manage to charge up the battery.
However, when I remove the power supply and I expect the fully charge battery to kick in and continue to supply to the evaluation board so that I can continue to use the BQstudio to monitor the discharge. What I saw is the I2C connection is disconnected and Bqstudio is not able to detect the eval board? My question is why the fully charge battery cannot use to supply the power to use the eval board? Can I do this?
If cannot, how do I monitor the discharge?
On my own PCB board, I received the error 1470 when I try to program the chemistry. how do I get rid of this message?
Kpk
