Other Parts Discussed in Thread: TPS54260, TPS62135
Dear all,
I would like to know if you recommend the step-down converter TPS62133 to be used as a power supply of a GSM/GPRS module (3.8V). I saw you have also one TPS54260 but for availability and circuitry cost I may turn to TPS62133 if recommended.
Basically I suppose the main feature to compare is the load regulation as this kind of modules operates at 300mA continuously with peaks till 2A.
Thank you very much in advance for your help.
Sincerely,
