Part Number: BQ24160
Hello
please let me clear about BQ24160 operation.
<about Output voltage>
1: As my understanding, If IN or USB pin is connected to AC adapter/USB-Vbus, Is System voltage (output form BQ24160) set around 3.7V.
Is it correct?
2: when IN or USB pin is connected and battery voltage is above 3.7V (Vsys), in this case, Does BQ24160 output battery voltage straightly?
<about USB Charging>
Customer will use tow Li-ino battery in parallel (they use tow BQ24160 individually) ,in this use case, please tell us below.
1: Can I use BQ24160 in parallel? if it is OK, are there any problem if D+/D- line divided to each BQ24160?
I think it has some problem in USB-Enumeration process. could you please any advice.
Best regard
Yamane
