Other Parts Discussed in Thread: TPS3852-Q1, TPS3850, TPS3852
Confirmation about TPS3850-Q1 and TPS3852-Q1.
Q1.
It is confirmation about TPS3850-Q1.
I want to confirm the chamfer size of the thermal pad.
However, the chamfer size is not described in the TPS 3850-Q1 datasheet.
Could you teach about chamfer size of TPS3850-Q1?
The TPS3850 datasheet described the chamfer size. (C 0.30)
Is TPS3850-Q1 the same as this?
Q2.
It is confirmation about TPS3852-Q1.
I want to confirm the size,shape and chamfer size of thermal pad.
However, none are described on the TPS3852-Q1 datasheet.
Could you teach about size,shape and chamfer size of thermal pad?
-Harukawa
(TPS3850_52-Q1)About size,shape and chamfering of thermal pad.pdf
