Other Parts Discussed in Thread: LM3414, , TPS92513
Hi teams.
I have some question about floating buck topology (Such as TPS92511 or LM3414).
I wondering to know what's the major advantage of floating buck topology compare to conventional buck topology? (besides it don't need high side FET charge pump driver?)
In what LED voltage/ILED/Vin should we choose floating buck topology? (For example, if we need 1.5A LED driver should we choose TPS92513 or LM3414?)
The second question is if we using a LED driver for 100mA LED current, will TPS92511 be a more proper part to apply than TPS92513? (I found TPS92511 need much larger inductor)
The third question is if the customer wants to use extremely small volume capacitor about 10nF-100nF, do we have any solution to achieve this with reasonable current ripple?
