BQ34Z100EVM: bq34z100
Part Number: BQ34Z100EVM
Other Parts Discussed in Thread: BQ34Z100-G1, BQSTUDIO, GPCCHEM
In December 2016 I have a great help from Thomas Cosby from TI in this forum and on the same issue!
Now I will make four more monitor units based on the bq34z100EVM (Farnell 2334116) as I used before!
But I have big problems to calibrate the board from the software tool.
I have attach the list of screens dumps I see when I try to make the connection to the board!
As you can see from the attach pdf. I got a lots of errors messages, but have communication with the board!
Why all these errors and why can I not measure the current?
I have attached the setup file (DPEactive.txt) I have used back in December 2016!
Will it be better to change the controller to the new generation (bq34z100-G1) and use the other software tool BM-studio?
 Please help me out on this as I have tried every think now
 Best regardsbq34z100EVM.pdf
[Header]
bq EVSW Version = 0.9.90
DeviceName = bq34z100 v0.06
Time = 31-08-2016 11:06:21
[Safety(Configuration)]
OT Chg = 55.0
OT Chg Time = 2
OT Chg Recovery = 50.0
OT Dsg = 60.0
OT Dsg Time = 2
OT Dsg Recovery = 55.0
[Charge Inhibit Cfg(Configuration)]
Chg Inhibit Temp Low = 0.0
Chg Inhibit Temp High = 45.0
Temp Hys = 5.0
[Charge(Configuration)]
Suspend Low Temp = -5.0
Suspend High Temp = 55.0
[Charge Termination(Configuration)]
Taper Current = 100
Min Taper Capacity = 25
Cell Taper Voltage = 100
Current Taper Window = 40
TCA Set % = 99
TCA Clear % = 95
FC Set % = 100
FC Clear % = 98
DODatEOC Delta T = 10.0
[Data(Configuration)]
Rem Cap Alarm = 100
Initial Standby = -10
Initial MaxLoad = -500
Manuf Date = 30-aug-2016
Ser. Num. = 0001
Cycle Count = 3
CC Threshold = 900
Design Capacity = 24000
Design Energy = 28800
SOH Load I = -400
TDD SOH Percent = 90
Cell Charge Voltage T1-T2 = 4200
Cell Charge Voltage T2-T3 = 4200
Cell Charge Voltage T3-T4 = 4200
Charge Current T1-T2 = 10
Charge Current T2-T3 = 50
Charge Current T3-T4 = 30
JEITA T1 = 0
JEITA T2 = 10
JEITA T3 = 45
JEITA T4 = 55
ISD Current = 10
ISD I Filter = 127
Min ISD Time = 7
Design Energy Scale = 6
Device Name = bq34z100
Manufacturer Name = Texas Inst.
Device Chemistry = 0100
[Discharge(Configuration)]
SOC1 Set Threshold = 150
SOC1 Clear Threshold = 175
SOCF Set Threshold = 75
SOCF Clear Threshold = 100
Cell BL Set Volt Threshold = 2800
Cell BL Set Volt Time = 2
Cell BL Clear Volt Threshold = 2900
Cell BH Set Volt Threshold = 4300
Cell BH Volt Time = 2
Cell BH Clear Volt Threshold = 4200
[Manufacturer Data(Configuration)]
Pack Lot Code = 0000
PCB Lot Code = 0000
Firmware Version = 0000
Hardware Revision = 0000
Cell Revision = 0000
DF Config Version = 0000
[Integrity Data(Configuration)]
Static Chem DF Checksum = 7D9F
[Lifetime Data(Configuration)]
Lifetime Max Temp = 30.0
Lifetime Min Temp = 20.0
Lifetime Max Chg Current = 0
Lifetime Max Dsg Current = 0
Lifetime Max Pack Voltage = 3200
Lifetime Min Pack Voltage = 3500
[Lifetime Temp Samples(Configuration)]
LT Flash Cnt = 0
[Registers(Configuration)]
Pack Configuration = 0161
Pack Configuration B = FF
Pack Configuration C = 30
LED_Comm Configuration = F3
Alert Configuration = 0000
Number of series cell = 2
[Lifetime Resolution(Configuration)]
LT Temp Res = 1.0
LT Cur Res = 100
LT V Res = 25
LT Update Time = 60
[LED Display(Configuration)]
LED Hold Time = 4
[Power(Configuration)]
Flash Update OK Cell Volt = 2800
Sleep Current = 10
FS Wait = 0
[Manufacturer Info(System Data)]
Block A 0 = 00
Block A 1 = 00
Block A 2 = 00
Block A 3 = 00
Block A 4 = 00
Block A 5 = 00
Block A 6 = 00
Block A 7 = 00
Block A 8 = 00
Block A 9 = 00
Block A 10 = 00
Block A 11 = 00
Block A 12 = 00
Block A 13 = 00
Block A 14 = 00
Block A 15 = 00
Block A 16 = 00
Block A 17 = 00
Block A 18 = 00
Block A 19 = 00
Block A 20 = 00
Block A 21 = 00
Block A 22 = 00
Block A 23 = 00
Block A 24 = 00
Block A 25 = 00
Block A 26 = 00
Block A 27 = 00
Block A 28 = 00
Block A 29 = 00
Block A 30 = 00
Block A 31 = 00
[IT Cfg(Gas Gauging)]
Load Select = 1
Load Mode = 0
Max Res Factor = 15
Min Res Factor = 3
Ra Filter = 500
Fast Qmax Start DOD % = 92
Fast Qmax End DOD % = 96
Fast Qmax Start Volt Delta = 200
Cell Terminate Voltage = 3000
Cell Term V Delta = 50
ResRelax Time = 200
User Rate-mA = 0
User Rate-Pwr = 0
Reserve Cap-mAh = 0
Reserve Energy = 0
Max Scale Back Grid = 4
Cell Max DeltaV = 200
Cell Min DeltaV = 0
Max Sim Rate = 2
Min Sim Rate = 20
Ra Max Delta = 44
Qmax Max Delta % = 5
Cell DeltaV Max Delta = 10
Fast Scale Start SOC = 10
Charge Hys V Shift = 40
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 60
Chg Current Threshold = 75
Quit Current = 40
Dsg Relax Time = 60
Chg Relax Time = 60
Quit Relax Time = 1
Cell Max IR Correct = 400
[State(Gas Gauging)]
Qmax Cell 0 = 24000
Cycle Count = 0
Update Status = 00
Cell V at Chg Term = 4200
Avg I Last Run = -299
Avg P Last Run = -1131
Cell Delta Voltage = 2
T Rise = 20
T Time Constant = 1000
[OCVa Table(OCV Table)]
Chem ID = 0100
[R_a0(Ra Table)]
Cell0 R_a flag = FF55
Cell0 R_a 0 = 38
Cell0 R_a 1 = 41
Cell0 R_a 2 = 43
Cell0 R_a 3 = 44
Cell0 R_a 4 = 42
Cell0 R_a 5 = 42
Cell0 R_a 6 = 45
Cell0 R_a 7 = 48
Cell0 R_a 8 = 49
Cell0 R_a 9 = 52
Cell0 R_a 10 = 56
Cell0 R_a 11 = 64
Cell0 R_a 12 = 74
Cell0 R_a 13 = 128
Cell0 R_a 14 = 378
[R_a0x(Ra Table)]
xCell0 R_a flag = FFFF
xCell0 R_a 0 = 38
xCell0 R_a 1 = 41
xCell0 R_a 2 = 43
xCell0 R_a 3 = 44
xCell0 R_a 4 = 42
xCell0 R_a 5 = 42
xCell0 R_a 6 = 45
xCell0 R_a 7 = 48
xCell0 R_a 8 = 49
xCell0 R_a 9 = 52
xCell0 R_a 10 = 56
xCell0 R_a 11 = 64
xCell0 R_a 12 = 74
xCell0 R_a 13 = 128
xCell0 R_a 14 = 378
[Data(Calibration)]
CC Gain = -9.827
CC Delta = 0
CC Offset = -0.65
Board Offset = 0.03
Int Temp Offset = 0.0
Ext Temp Offset = -2.3
Voltage Divider = 54432
[Current(Calibration)]
Deadband = 5
[Codes(Security)]
Sealed to Unsealed = 36720414
Unsealed to Full = FFFFFFFF
Authen Key3 = 01234567
Authen Key2 = 89ABCDEF
Authen Key1 = FEDCBA98
Authen Key0 = 76543210
Niels
  • Hello Niels,
    Yes, pls update the firmware on the chip to the G1 version and use bqstudio and let me know if you still run into issues.
    thanks
    Onyx
  • Hi Onyx,
    Thanks for your fast reply, I appreciate it!
    Do I have to svop the IC to the G1 version as well?
    Can you send me a link for the fw update procedure? Thanks!
    Niels
  • Hi Niels,
    Chips are the same. No hardware change. Just firmware is different. Link to the new firmware below
    www.ti.com/.../sluc580
    Once you start after installing bqstudio, if it doesn't automatically detect the device, select the the b34z100-g1 from the list of devices, go to the firmware tab of the tool, select the firmware where you stored it on your computer and then hit the program button.
    thanks
    Onyx
  • Hi Onyx,
    Install the new FW and run the bqstudio went fine and the communication works!
    But I miss a user guide for setting my battery data in the bqstudio, where can I find this?
    Can I install my old setup file DPEactive.gg or shall I do this manual and how?
    Niels
  • Hi Niels,
    Follow these steps
    -indentify your chem id using gpcchem. Instructions are straightforward and easy to follow.
    -program the obtained chem id and Configure the data flash following the data sheet.
    -Perform a learning cycle and then
    -Extract your golden srec or bqfs or dffs.
    Let me know if you have questions on any of these steps
    thanks
    Onyx
  • Thanks Onyx,
    I can read and calibrate the board now!
    When I need the 4LED (in the end of the PCB) to indicate the SOC with 25% steps, do I still need to converte to HDQ mode as I did in the past with the old setup?
    /Niels
  • Hi Onyx,
    I can now read all parameters in the bqstudio including the Ah counter when I charge and discharge the battery, but I can not see the correct value of the Ah level at the foure LED A-D!
    I have convert from I2C to HDQ and have made a power cycle of the EVB, but still I only have LED A-B active when I have 100% SOC on the bqstudio monitor!
    In the old vesion I had set the register LED_comm configuation to F3, but how can this be set in the new version?
    I have attach the current setup file, please advice if you can see any problem in this!
    Thanks for your time,
    Niels
    * Texas Instruments Data Flash File
    * File created Tue Oct 10 22:28:40 2017
    * Device Number 100
    * Firmware Version 0.16
    * Build Number not available
    * Order Number not available
    * bqz Device Number 100
    * bqz Firmware Version 0.16
    * bqz Build Number 17
    * Field Order: Class name, Subclass name, Parameter name, Parameter Value, Display Units
    "Configuration","Safety","OT Chg","55.0","1degC"
    "Configuration","Safety","OT Chg Time","2","Seconds"
    "Configuration","Safety","OT Chg Recovery","50.0","1degC"
    "Configuration","Safety","OT Dsg","60.0","1degC"
    "Configuration","Safety","OT Dsg Time","2","Seconds"
    "Configuration","Safety","OT Dsg Recovery","55.0","1degC"
    "Configuration","Charge Inhibit Cfg","Chg Inhibit Temp Low","0","1degC"
    "Configuration","Charge Inhibit Cfg","Chg Inhibit Temp High","45.0","1degC"
    "Configuration","Charge Inhibit Cfg","Temp Hys","5.0","1degC"
    "Configuration","Charge","Suspend Low Temp","-5.0","1degC"
    "Configuration","Charge","Suspend High Temp","55.0","1degC"
    "Configuration","Charge","Pb EFF Efficiency","100","%"
    "Configuration","Charge","Pb Temp Comp","24.960","%"
    "Configuration","Charge","Pb Drop Off Percent","96","%"
    "Configuration","Charge","Pb Reduction Rate","10.000","%"
    "Configuration","Charge Termination","Taper Current","100","mAmp"
    "Configuration","Charge Termination","Min Taper Capacity","25","mAmpHr"
    "Configuration","Charge Termination","Cell Taper Voltage","100","mVolt"
    "Configuration","Charge Termination","Current Taper Window","40","Seconds"
    "Configuration","Charge Termination","TCA Set %","99","Percent"
    "Configuration","Charge Termination","TCA Clear %","95","Percent"
    "Configuration","Charge Termination","FC Set %","100","Percent"
    "Configuration","Charge Termination","FC Clear %","98","Percent"
    "Configuration","Charge Termination","DODatEOC Delta T","10.0","1degC"
    "Configuration","Charge Termination","NiMH Delta Temp","3.0","1degC"
    "Configuration","Charge Termination","NiMH Delta Temp Time","180","Seconds"
    "Configuration","Charge Termination","NiMH Hold Off  Time","100","Seconds"
    "Configuration","Charge Termination","NiMH Hold Off Current","240","mAmp"
    "Configuration","Charge Termination","NiMH Hold Off  Temp","25.0","1degC"
    "Configuration","Charge Termination","NiMH Cell Negative Delta Volt","17","mVolt"
    "Configuration","Charge Termination","NiMH Cell Negative Delta Time","16","Seconds"
    "Configuration","Charge Termination","NiMH Cell Neg Delta Qual Volt","4200","mVolt"
    "Configuration","Data","Manufacture Date","1980-1-1","Day + Mo*32 + (Yr -1980)*256"
    "Configuration","Data","Serial Number","0001","hex"
    "Configuration","Data","Cycle Count","0","Count"
    "Configuration","Data","CC Threshold","900","mAmpHr"
    "Configuration","Data","Max Error Limit","100","%"
    "Configuration","Data","Design Capacity","24000","MilliAmpHour"
    "Configuration","Data","Design Energy","28800","MilliWattHour"
    "Configuration","Data","SOH Load I","-400","MilliAmp"
    "Configuration","Data","Cell Charge Voltage T1-T2","4200","mV"
    "Configuration","Data","Cell Charge Voltage T2-T3","4200","mV"
    "Configuration","Data","Cell Charge Voltage T3-T4","4200","mV"
    "Configuration","Data","Charge Current T1-T2","10","Percent"
    "Configuration","Data","Charge Current  T2-T3","50","Percent"
    "Configuration","Data","Charge Current  T3-T4","30","Percent"
    "Configuration","Data","JEITA T1","0","degC"
    "Configuration","Data","JEITA T2","10","degC"
    "Configuration","Data","JEITA T3","45","degC"
    "Configuration","Data","JEITA T4","55","degC"
    "Configuration","Data","Design Energy Scale","6","Number"
    "Configuration","Data","Device Name","bq34z100","-"
    "Configuration","Data","Manufacturer Name","Texas Inst.","-"
    "Configuration","Data","Device Chemistry","0100","-"
    "Configuration","Discharge","SOC1 Set Threshold","150","mAh"
    "Configuration","Discharge","SOC1 Clear Threshold","175","mAh"
    "Configuration","Discharge","SOCF Set Threshold","75","mAh"
    "Configuration","Discharge","SOCF Clear Threshold","100","mAh"
    "Configuration","Discharge","Cell BL Set Volt Threshold","2800","mVolt"
    "Configuration","Discharge","Cell BL Set Volt Time","2","Seconds"
    "Configuration","Discharge","Cell BL Clear Volt Threshold","2900","mVolt"
    "Configuration","Discharge","Cell BH Set Volt Threshold","4300","mVolt"
    "Configuration","Discharge","Cell BH Volt Time","2","Seconds"
    "Configuration","Discharge","Cell BH  Clear Volt Threshold","4200","mVolt"
    "Configuration","Discharge","Cycle Delta","0.05","%"
    "Configuration","Manufacturer Data","Pack Lot Code","0000","hex"
    "Configuration","Manufacturer Data","PCB Lot Code","0000","hex"
    "Configuration","Manufacturer Data","Firmware Version","0000","hex"
    "Configuration","Manufacturer Data","Hardware Revision","0000","hex"
    "Configuration","Manufacturer Data","Cell Revision","0000","hex"
    "Configuration","Manufacturer Data","DF Config Version","0000","hex"
    "Configuration","Lifetime Data","Lifetime Max Temp","30.0","1degC"
    "Configuration","Lifetime Data","Lifetime Min Temp","20.0","1degC"
    "Configuration","Lifetime Data","Lifetime Max Chg Current","0","mAmp"
    "Configuration","Lifetime Data","Lifetime Max Dsg Current","0","mA"
    "Configuration","Lifetime Data","Lifetime Max Pack Voltage","3200","20mV"
    "Configuration","Lifetime Data","Lifetime Min Pack Voltage","3500","20mV"
    "Configuration","Lifetime Temp Samples","LT Flash Cnt","0","Count"
    "Configuration","Registers","Pack Configuration","01d9","flags"
    "Configuration","Registers","Pack Configuration B","af","flags"
    "Configuration","Registers","Pack Configuration C","37","flags"
    "Configuration","Registers","LED_Comm Configuration","f3","flags"
    "Configuration","Registers","Alert Configuration","0000","flags"
    "Configuration","Registers","Number of series cell","2","num"
    "Configuration","Lifetime Resolution","LT Temp Res","1.0","1degC"
    "Configuration","Lifetime Resolution","LT Cur Res","100","mA"
    "Configuration","Lifetime Resolution","LT V Res","25","20mV"
    "Configuration","Lifetime Resolution","LT Update Time","60","Seconds"
    "Configuration","LED Display","LED Hold Time","4","Num"
    "Configuration","Power","Flash Update OK Cell Volt","2800","mVolt"
    "Configuration","Power","Sleep Current","10","mAmp"
    "Configuration","Power","FS Wait","0","Seconds"
    "System Data","Manufacturer Info","Block A 0","00","hex"
    "System Data","Manufacturer Info","Block A 1","00","hex"
    "System Data","Manufacturer Info","Block A 2","00","hex"
    "System Data","Manufacturer Info","Block A 3","00","hex"
    "System Data","Manufacturer Info","Block A 4","00","hex"
    "System Data","Manufacturer Info","Block A 5","00","hex"
    "System Data","Manufacturer Info","Block A 6","00","hex"
    "System Data","Manufacturer Info","Block A 7","00","hex"
    "System Data","Manufacturer Info","Block A 8","00","hex"
    "System Data","Manufacturer Info","Block A 9","00","hex"
    "System Data","Manufacturer Info","Block A 10","00","hex"
    "System Data","Manufacturer Info","Block A 11","00","hex"
    "System Data","Manufacturer Info","Block A 12","00","hex"
    "System Data","Manufacturer Info","Block A 13","00","hex"
    "System Data","Manufacturer Info","Block A 14","00","hex"
    "System Data","Manufacturer Info","Block A 15","00","hex"
    "System Data","Manufacturer Info","Block A 16","00","hex"
    "System Data","Manufacturer Info","Block A 17","00","hex"
    "System Data","Manufacturer Info","Block A 18","00","hex"
    "System Data","Manufacturer Info","Block A 19","00","hex"
    "System Data","Manufacturer Info","Block A 20","00","hex"
    "System Data","Manufacturer Info","Block A 21","00","hex"
    "System Data","Manufacturer Info","Block A 22","00","hex"
    "System Data","Manufacturer Info","Block A 23","00","hex"
    "System Data","Manufacturer Info","Block A 24","00","hex"
    "System Data","Manufacturer Info","Block A 25","00","hex"
    "System Data","Manufacturer Info","Block A 26","00","hex"
    "System Data","Manufacturer Info","Block A 27","00","hex"
    "System Data","Manufacturer Info","Block A 28","00","hex"
    "System Data","Manufacturer Info","Block A 29","00","hex"
    "System Data","Manufacturer Info","Block A 30","00","hex"
    "System Data","Manufacturer Info","Block A 31","00","hex"
    "Gas Gauging","IT Cfg","Load Select","1","Number"
    "Gas Gauging","IT Cfg","Load Mode","0","Number"
    "Gas Gauging","IT Cfg","Res Current","10","mAmp"
    "Gas Gauging","IT Cfg","Max Res Factor","15","num"
    "Gas Gauging","IT Cfg","Min Res Factor","3","num"
    "Gas Gauging","IT Cfg","Ra Filter","500","num"
    "Gas Gauging","IT Cfg","Min PassedChg NiMH-LA 1st Qmax","50","%"
    "Gas Gauging","IT Cfg","Maximum Qmax Change","100","%"
    "Gas Gauging","IT Cfg","Cell Terminate Voltage","3000","mVolt"
    "Gas Gauging","IT Cfg","Cell Term V Delta","50","mVolt"
    "Gas Gauging","IT Cfg","ResRelax Time","200","Seconds"
    "Gas Gauging","IT Cfg","User Rate-mA","0","MilliAmp"
    "Gas Gauging","IT Cfg","User Rate-Pwr","0","mW/cW"
    "Gas Gauging","IT Cfg","Reserve Cap-mAh","0","MilliAmpHour"
    "Gas Gauging","IT Cfg","Reserve Energy","0","mWh/cWh"
    "Gas Gauging","IT Cfg","Max Scale Back Grid","4","num"
    "Gas Gauging","IT Cfg","Cell Min DeltaV","0","mVolt"
    "Gas Gauging","IT Cfg","Ra Max Delta","44","%"
    "Gas Gauging","IT Cfg","Design Resistance","42","mOhms"
    "Gas Gauging","IT Cfg","Reference Grid","4","-"
    "Gas Gauging","IT Cfg","Qmax Max Delta %","10","mAmpHour"
    "Gas Gauging","IT Cfg","Max Res Scale","32000","Num"
    "Gas Gauging","IT Cfg","Min Res Scale","1","Num"
    "Gas Gauging","IT Cfg","Fast Scale Start SOC","10","%"
    "Gas Gauging","IT Cfg","Charge Hys V Shift","40","mVolt"
    "Gas Gauging","IT Cfg","Smooth Relax Time","1000","s"
    "Gas Gauging","Current Thresholds","Dsg Current Threshold","60","mAmp"
    "Gas Gauging","Current Thresholds","Chg Current Threshold","75","mAmp"
    "Gas Gauging","Current Thresholds","Quit Current","40","mAmp"
    "Gas Gauging","Current Thresholds","Dsg Relax Time","60","Seconds"
    "Gas Gauging","Current Thresholds","Chg Relax Time","60","Seconds"
    "Gas Gauging","Current Thresholds","Cell Max IR Correct","400","mV"
    "Gas Gauging","State","Qmax Cell 0","24000","mAmpHr"
    "Gas Gauging","State","Cycle Count","0","num"
    "Gas Gauging","State","Update Status","00","num"
    "Gas Gauging","State","Cell V at Chg Term","4200","mVolt"
    "Gas Gauging","State","Avg I Last Run","-299","mAmp"
    "Gas Gauging","State","Avg P Last Run","-1131","MilliWattHour"
    "Gas Gauging","State","Cell Delta Voltage","2","mVolt"
    "Gas Gauging","State","T Rise","20","Num"
    "Gas Gauging","State","T Time Constant","1000","Num"
    "Ra Tables","Ra0 Table","Ra Flag","ff55","Hex"
    "Ra Tables","Ra0 Table","Ra 0","38","Num"
    "Ra Tables","Ra0 Table","Ra 1","41","Num"
    "Ra Tables","Ra0 Table","Ra 2","43","Num"
    "Ra Tables","Ra0 Table","Ra 3","44","Num"
    "Ra Tables","Ra0 Table","Ra 4","42","Num"
    "Ra Tables","Ra0 Table","Ra 5","42","Num"
    "Ra Tables","Ra0 Table","Ra 6","45","Num"
    "Ra Tables","Ra0 Table","Ra 7","48","Num"
    "Ra Tables","Ra0 Table","Ra 8","49","Num"
    "Ra Tables","Ra0 Table","Ra 9","52","Num"
    "Ra Tables","Ra0 Table","Ra 10","56","Num"
    "Ra Tables","Ra0 Table","Ra 11","64","Num"
    "Ra Tables","Ra0 Table","Ra 12","74","Num"
    "Ra Tables","Ra0 Table","Ra 13","128","Num"
    "Ra Tables","Ra0 Table","Ra 14","378","Num"
    "Ra Tables","Ra0x Table","Ra Flag","ffff","Hex"
    "Ra Tables","Ra0x Table","Ra 0","38","Num"
    "Ra Tables","Ra0x Table","Ra 1","41","Num"
    "Ra Tables","Ra0x Table","Ra 2","43","Num"
    "Ra Tables","Ra0x Table","Ra 3","44","Num"
    "Ra Tables","Ra0x Table","Ra 4","42","Num"
    "Ra Tables","Ra0x Table","Ra 5","42","Num"
    "Ra Tables","Ra0x Table","Ra 6","45","Num"
    "Ra Tables","Ra0x Table","Ra 7","48","Num"
    "Ra Tables","Ra0x Table","Ra 8","49","Num"
    "Ra Tables","Ra0x Table","Ra 9","52","Num"
    "Ra Tables","Ra0x Table","Ra 10","56","Num"
    "Ra Tables","Ra0x Table","Ra 11","64","Num"
    "Ra Tables","Ra0x Table","Ra 12","74","Num"
    "Ra Tables","Ra0x Table","Ra 13","128","Num"
    "Ra Tables","Ra0x Table","Ra 14","378","Num"
    "Calibration","Data","CC Gain","10.123","mohm"
    "Calibration","Data","CC Delta","10.147","mohm"
    "Calibration","Data","CC Offset","-1490","num"
    "Calibration","Data","Board Offset","0","num"
    "Calibration","Data","Int Temp Offset","-1.1","degC"
    "Calibration","Data","Ext Temp Offset","0","degC"
    "Calibration","Data","Voltage Divider","54432","mVolt"
    "Calibration","Current","Deadband","5","mAmp"
    "Security","Codes","Sealed to Unsealed","36720414","hex"
    "Security","Codes","Unsealed to Full","ffffffff","hex"
    "Security","Codes","Authen Key3","01234567","hex"
    "Security","Codes","Authen Key2","89abcdef","hex"
    "Security","Codes","Authen Key1","fedcba98","hex"
    "Security","Codes","Authen Key0","76543210","hex"
  • Hi Niels,
    Sorry, i wasn't able to get back to this. Are there still any open items that needs to be addressed?
    thanks
    Onyx
  • OK Onyx!
    I had some problems with calibrating the voltage, but it seem to work now!
    I must admit I find it very hard to work with this EV-board, with a very poor documentation for the setup procedure.
    A updated documentation will be appreciated :-)
    But thanks for your support up to now !
    /Niels
  • Thanks Niels, I have passed accross your observations to the systems Engineer who owns the device. I anticipate they will update the documentation in the near future.
    regards
    Onyx
