power supply block with TPS40322 was designed in accordance to the Application Note as well as the Loop Stability calculator file.
PDFs are attached. Can we count on an stable operation with the chosen values of the components?
The targeted outputs are
1V@8Amps(dual-phase)
0.9V@24Amps(single-phase).TPS40KType III Loop Stability - 0V9.xlstps40322.pdfhttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/TPS40322.7z
