Now I evaluate bq27421 after performing learning cycle at only 25 degC, then I can't good result at 0 degC. Should I perform learning cycle at 0 degC also? Here is the procedure when I got attached log file.
- Perform learning cycle and complete correctly
- Perform charge and discharge test at 25 degC, then I can see good result (1C charge -> 1C discharge -> 1C charge -> 0.5C discharge...)
- After #2, perform the same test at 0 degC, then I can not see good result as attached.
Satoshi / Japan Disty
