Other Parts Discussed in Thread: LM5109
I am using LM5109A to drive IRFU3607(power MOSFET) in a BLDC motor controller. The PWM is generated through a microcontroller. The motor is a rewind motor that takes up the excess liner. The system gets a trigger and motor starts running and then stops.
The problem is that at high throughput (motor start and stops at faster speeds and more frequent) LM5901A and the top MOSFETs die very randomly. I can't find out what is causing this to happen.
I appreciate your help.
