TPS2378: TPS2378 No power supply problem
Part Number: TPS2378
Other Parts Discussed in Thread: TPS23861,
HI SIR/ma
 Now the customer  has made a set-top box solution with POE, using TI's TPS2378.Now the problem is that when set-top box‘s HDMI connection to the backend display, TP cc-link POE switches (PSE scheme is TPS23861) is not power, but using TENDA switches (PSE scheme is IP804) and broadcom switches (PSE scheme is broadcom), the two switches can be power supply.When the HDMI cable is not connected, each switch can supply power to the set-top box normally. Please help to analyze. What caused it?
POE(1).pdf
