We have a problem with the attached power supply, which was designed using your specs as reference.
- When a rail is not enabled we measure essentially 0V on the output
- Whatever value we select for Vout (including 0V), when we enable any rail, the Vout voltage changes to 1.1V
- This happens for any or all rails.
We believe we programmed the UCD9244 correctly (no errors during programming).
Please review the attached schematic to confirm if we might have overlooked something.
