Hi team,
My customer has a question on the TPS1H100-Q1.
1. For the B Version of this device, is the minimum external current limit setting 0.5A? Is it possible to set the limit to 0.3A for current limit? If so, how could I accomplish that?
2. I would like to know how thermal will be handled. PT= (VS -Vout )*limit current ? when shorting to GND at Vout
example : VS=12V Vout =11.9 current limit =0.3
short to GND
PT=(12-0)*0.3=4W at TPS1H100-Q1
In my understanding , VCS will be high level into MCU Pin at same time and then Vin disable TPS1H100 immediately in order to protect TPS1H that is not broken .
3. Form datasheet P.19 description :For better protection from the hard short to GND condition
is its meaning to include External programmable current?
Thank you,
Eric Mitchell
