If we want to use the "default" settings, where CT = 0pF. Would we connect the CT pin to ground or leave open?
Otherwise, what would happen shorting this pin to ground?
Mark
Mark
Hi Mark,
In this case, you would want to leave the CT pin floating. This pin directly affects the gate voltage of the FET, so grounding it may prevent the pass FET from being able to turn on.
Alek Kaknevicius
Hi Alek,
This does make me wonder. Would leaving the pin open, act like infinite capacitance? Creating an infinite rise time?
Mark
Hi Mark,
Good question. Actually this would be a very small capacitance because the gate capacitance of the FET would be the only capacitance on that node.
Alek Kaknevicius
