I'm here to ask about FET control on hardware. Why DSGFET or CHGFET doesn't turn ON/OFF while triggered from BQStudio ? When i toggled ON CHGFET, XCHG register shows green and CHG red. I measured on Vgate, the voltage is 12.38Volts. When i toggled OFF CHGFET, XCHG register shows red and CHG is green, but the voltage doesn't go down to near 0V. I measured it at 12.20 Volts. And it happened same on DSGFET. What is wrong with my design ? Because of grounding or something else ?
Here i attached my design in ZIP file document.
Kindly Please answer this question.
Thank you.
Best Regards
Aji SantosoBQ40Z50 layout.zip
