TPS65217: TPS65217: no voltage on output pins
Part Number: TPS65217
My product is the TPS65217CRSLT from TPS65217 Power Management IC.
I have a case where VSYS and PB_IN works (VSYS has 1V1 and PB_IN has 5V0).
But I don't have any output signal (LDO, LS, DCDC).
Have you any recommendation to debug this problem?
Thank's for your help!
  • Hi Adjivas,
    Which power on condition are you using (PB_IN falling edge, AC rising edge, or USB rising edge)?
    Also, are you pulling PWR_EN high?
    You can see the state diagram in Figure 24 in the datasheet.
    Please note that this is a holiday weekend in the United States, so next response will likely be on Tuesday.
