Other Parts Discussed in Thread: BQ40Z50-R2
Hello TI
Finally I have received the .senc file from our batterymanufacturer. Is this helful for analysis of the problem described in the now closed thread that this links to?
Hello TI
Imre,
For this your battery needs to be characterized at that temperature. Unless this is done, at very low temperatures you will have a reported zero capacity.
Most of the chemistries are characterized for operation between 0C to 50C. Yours is an extreme case. Unless your chemistry data is specifically characterized for your operation, you will not see optimum results.
