BQ24780SEVM-583: The DisCharge current value is set to 512ma but the actual discharge current reading shows more than that
Part Number: BQ24780SEVM-583
When I enter Discharge Current limit in the BqStudio does it limit the discharge current actually ? I was setting the discharge current to different values but the current pulled by the load doesnt change based on the limit i set it to be . Kindly let me know if i need to change any registers . I enabled the discharge current limit register as mentioned in the manual .Thanks.
Naveesh
